1980 KZ250 Shifting Issues...Stumped - Kawasaki Motorcycle Forums
post #1 of 29 (permalink) Old 03-30-2017, 07:12 PM Thread Starter
Junior Member
Ben Tosto's Avatar
Hey all, I've been lurking here for a while, and much of what's been said has helped me tremendously, so thank you all for that! Unfortunately, I'm absolutely stumped with my bike.
Abstract: 1980 KZ250 suddenly developed erratic inability to shift properly, most notably down, and especially past third. Replaced gear shift lever, transmission, shift forks, shift drum. Experienced variety of small improvements or retrogressions, however the problem persists.
Backstory: I bought it last summer, and at first it was a wonderful little around town bike. I needed a commuter bike, and I rode it to work daily for several months with no real issues. Sure, the previous owner had stripped its air system and put those godforsaken Air Pods on it so that I can't get the damned carb tuned right and so it sputters and cuts out once you're running it at 5k RPM's or 45mph, but I don't need to go faster than 40mph most days anyhow - if only it didn't soot up the spark plugs and cake up the exhaust with carbon, I'd just as soon forget about it, but that's an issue for another post! One day on my way to work, however, I was downshifting on an approach to a roundabout, and found that I couldn't get down into second. I pulled over and fussed for a bit, and found that I was able to, with some gentle caresses, get it back down into neutral. This didn't fix the problem though. I ended up limping home in 3rd and - as it was my only form of transportation at the time - this was followed by months of bicycling to work which I did not relish.
I am mechanically inclined and well supplied with metalworking tools (I'm a blacksmith by trade), but in no way knowledgable. Prior to this, the most complicated thing I've done is replace the rear main seal on a Jeep Cherokee. Thankfully the bike came with a manual, and I've relied on it, you guys, friends, and all but one of the motorcycle repair shops in my city for advice and support through this, and I've run out of locals to harangue about this, so I put it in your hands.
Process: The first diagnosis pointed to the gear shift lever, which showed some signs of wear, and there was some scoring where it travelled up against the right side of the crankcase. I started by tacking some weld onto the tips of the lever and then profiling them down to what looked like it might have been its original shape. This definitely changed the nature of the shifting, and seemed like a slight improvement, lending credence to the diagnosis.
I purchased a NOS gear shift lever off eBay, which ended up being slightly different than the original, but had the same part number and seemed to be identical where it mattered (i.e. where it came into contact with the bike in any way).
New shift lever on right, old on left
Unfortunately, this seemed to make the shifting worse. Local advice convinced me that the problem must lay deeper in that case, and that the shift lever was merely a symptom of a larger issue - likely the forks or the drum.
Thus I tore out the engine, stripped it down, split the crankcase, and got at the transmission. Here I found nothing that looked particularly amiss. There was a bit of wear on the forks, a bit on the gears, but nothing chipped, broken or otherwise. The drum was the most suspicious part - with the forks out, spinning it free on its bearing, there was a perceptible wobble to its oscillating when viewed from the right side of the crankcase. There was also a very very slight catch, a small amount of friction in its rotation at one point. Local advice said that might be it, or it might be that there was enough wear in the drum's grooves that it was overly difficult for the forks to travel over the humps.
Old forks
In any case, the drum cost as much as the drum and transmission together, so I fetched them both and installed both hoping to avoid breaking back into the crankcase. The only thing of note here is that once again, the parts had the right numbers, but arrived very slightly different from the originals. The lobes on the drums looked ever so slightly rounder on the replacement drum, and the K was stamped on a different lobe. The drive shaft on the original had a long gear milled into the right-most end where the new one had a free-spinning collar which seemed to slot into the clutch assembly, if anything, more nicely than the original. The new output shaft had a whole extra gear at its right-most end which nestled into a gap that went unfilled on the old one. I wasn't sure what to make of all that, but I took it as a good sign that the crankcase at least seemed to be designed to accommodate these deviations.
New gears on top, old on bottom
I buttoned everything back up, taking the opportunity to replace the gobs of blue Permatex I encountered along the way with some very expensive paper gaskets, and dealt with a supremely annoying outbreak of electrical issues (which traced back to an intermittently reliable spark plug cable), and got it running once more.
Conclusion: The problem seems to have been restored to its original state, with the added bonus that I can't seem to convince it to leave 3rd at all now, and that the entire shift lever will sometimes skip of the shifting palls and skate downward unchecked.
As far as I can tell, I've replaced every single piece of the transmission and its accoutrements except for the shift shaft, shift peg, and the springs associated with the external shift mechanism.
I read on another forum someone with a similar issue had a bent shift shaft, which I neglected to thoroughly inspect while I had it out, but I had had it out several times and I think I would have noticed if it had been anything but straight. It certainly slides through the crankcase without any apparent problems or friction.
Anyway, I'm completely stumped. I put it to you, dear reader. Many thanks for your thoughts!
https://goo.gl/photos/eMVQBhttS8mCwqpj9
P.S. Here's a photo album of all the documentation I made of the project while I was working on it, including the many many note-to-self videos I made so as to not forget what was what. There have been a number of small differences between my bike and the manual's, but the VIN checks out against it so whatever I guess.
1980 KZ250
Ben Tosto is offline
Sponsored Links
Advertisement
post #2 of 29 (permalink) Old 03-31-2017, 10:13 AM
Senior Member
martin-csr's Avatar
Did you try replacing the clutch cable?
I'm not familiar with the 250 & it has a different clutch release mechanism than most KZs. It appears to be kinda similar to some of the KZ shaft drive models. On the shaft drive models, a stretched clutch cable can cause shifting problems, but the problems would probably be through all the gears.
martin-csr is offline
post #3 of 29 (permalink) Old 03-31-2017, 10:45 AM Thread Starter
Junior Member
Ben Tosto's Avatar
I haven't, however, the problem is obvious even with the motor off, with the engine removed, and the right engine cover off. You can see the shift lever try to grab the pawl, and then skip off it. It's like there's not enough pressure against the backside of the shift lever.
EDIT: That is to say, even if the clutch isn't even on the bike, you can still observe the problem.
1980 KZ250
post #4 of 29 (permalink) Old 03-31-2017, 10:49 AM Thread Starter
Junior Member
Ben Tosto's Avatar
For reference, here's where I'm getting my parts numbers from:
https://www.kawasaki.com/Parts/Parts.../1980/KZ250-D1
And here's the external shifting mechanism diagram:
1980 KZ250
post #5 of 29 (permalink) Old 04-02-2017, 11:58 PM
Senior Member
Jimray23's Avatar
Did u replace the case bearings for the trans
Jimmy
1979 kz1000 ltd
Jimray23 is offline
post #6 of 29 (permalink) Old 04-03-2017, 01:13 PM Thread Starter
Junior Member
Ben Tosto's Avatar
Jimmy
1979 kz1000 ltd
I took them out and inspected them, but they seemed fine. What should I have seen if they need replacing?
1980 KZ250
post #7 of 29 (permalink) Old 04-05-2017, 06:50 PM
Senior Member
Jimray23's Avatar
Just the shaft would be a little loose in the bearing or the bearing loose in the case.
Jimmy
1979 kz1000 ltd
Jimray23 is offline
post #8 of 29 (permalink) Old 04-05-2017, 07:12 PM
Senior Member
Jimray23's Avatar
Or excess slop in the bearing itself, maybe maybe chips, nicks or heat marks in the bearing.
Jimmy
1979 kz1000 ltd
Jimray23 is offline
post #9 of 29 (permalink) Old 04-06-2017, 11:46 AM Thread Starter
Junior Member
Ben Tosto's Avatar
Naw, everything seemed pretty tight and ship-shape. The only thing that seemed amiss in that area was that the shift drum didn't seem centered on its bearings, but it may have just been from all the messing about I did before noticing that. Either way, it was definitely centered, spinning easy, and tight as tight before I buttoned up the crankcase.
I feel pretty confident saying there isn't anything obviously mechanically damaged or worn in the transmission. The issue seems completely centered around the external shift mechanism, but I have no idea what to do to correct it. Could it just be as simple as a tired spring? If you look here: https://www.kawasaki.com/Parts/Parts.../1980/KZ250-D1 the spring labeled 7 (92081-149) is the only thing providing back-pressure to the gear shift lever. I tried shimming it with a washer (both to put a little more pressure on the spring and because it's tricky to get the circlip back on without one), but if it changed anything, I didn't notice the difference.
1980 KZ250
post #10 of 29 (permalink) Old 04-06-2017, 02:20 PM
Senior Member
Can you shift up and down, by fingers, at shift drum? You may have to rock bike back and forth to do so.
sfair is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
