1982 GPZ 550 BATT Warning Light Question - Kawasaki Motorcycle Forums
post #1 of 20 (permalink) Old 05-07-2017, 11:30 PM Thread Starter
Junior Member
My new to me 1982 GPZ 550 is flashing the gauge "BATT" warning light and the "WARNING" light too. Why is it doing this, what does this mean? It's on a smart charger and starts and runs fine.
crwiseman is offline
Sponsored Links
Advertisement
post #2 of 20 (permalink) Old 05-08-2017, 02:48 PM
Senior Member
martin-csr's Avatar
Your bike probably has (or had) a battery sensor of some sort.
When the sensor isn't used, the warning light flashes. I don't know the simplest way to disable it.
The 82 750-R1 battery sensor has a pink wire that needs to be connected to a switched 12 VDC source.
The brown wire circuit would be one way to do it; the horn is usually on that circuit.
The brown wiring coming from the ignition switch has a bullet connector, so maybe a double connector could be used there to attach the pink wire.
martin-csr is offline
post #3 of 20 (permalink) Old 05-08-2017, 02:59 PM Thread Starter
Junior Member
It's bone stock, had it for a week. Rode it for the first time Sunday and noticed the BATT light was now flashing
. . . as simple as topping off the battery?
post #4 of 20 (permalink) Old 05-09-2017, 12:24 AM Thread Starter
Junior Member
Apparently, it means low battery acid levels.
post #5 of 20 (permalink) Old 05-09-2017, 09:09 AM
Senior Member
martin-csr's Avatar
Yes. I've never heard of anyone actually using the thing & it doesn't work on AGM batteries.
Most guys just want a permanent way to stop the battery light from blinking. hee.
ps: I would check the battery & load test it. The bike needs a good, fully charged battery to run right.
post #6 of 20 (permalink) Old 05-12-2017, 05:39 PM
Machinist For Sale/Rent
Bob Myers's Avatar
Try filling the battery with distilled water, if that does not squelch the warning light i can easily tell you how to wire the sensor so that it is not a warning. Whatever you do, DO NOT FOR ANY REASON attach the sensor wire to an12 volt circuit, it is meant to sense app 6 volts from the center of the battery, 12 v will damage the onboard diagnostic center
IBA#34911
Bob Myers is offline
post #7 of 20 (permalink) Old 05-14-2017, 10:45 AM
Bob Myers's Avatar
Don't you love it when some one ask a question that gets answers and then never replies again? Seems like the membership on this site has dwindled drastically.
IBA#34911
post #8 of 20 (permalink) Old 05-14-2017, 12:30 PM Thread Starter
Junior Member
Bob: After refilling it earlier in the week, the darn thing is on again. How do you wire it so it doesn't go off anymore?
post #9 of 20 (permalink) Old 05-14-2017, 06:35 PM
Bob Myers's Avatar
is battery still full? If it is overcharging and boiling the electrolyte out of the battery then the warning is a good thing
IBA#34911
post #10 of 20 (permalink) Old 05-14-2017, 06:36 PM
Bob Myers's Avatar
The sensor wire is in one of the center cavities?
IBA#34911
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
