I bought some replacement lights for my 500R. The connectors did not fit so I reconnected the stock lights. Now the lights do not come on but the signals work. There are only two connectors per light (as apposed to 3 in the front). The front lights are fine. Any ideas? Fuse? Connector?
Banned
You might go straight to Freakinout but you should only have two wires one for turn signal and one for ground...the only time that they are on is when your turn signal is on... I'm not "positive", only fools are positive, but I'm pretty sure. PM to Freakinout and ask him
#5 (permalink) |
Banned
First take a good dual filament bulb and find a good ground and then tape the ground around the base of the bulb...youo can use a piece of wire for this....then take the two wires and while the bike is running touch one of the two wires at a time to the bulb at a time...the one that works is your running light...then while you have that figured out you could test the other one to see that the turn signal wire works to...
Although both running lights may have the same color wire, testing is still the best. IF you don't have any luck there check the fuses... |
| 500R: zx600 rear wheel project almost done... | orbital5280 | Kawasaki Streetbikes/Sportbikes | 7 | 02-15-2009 10:47 PM |
| LED running lights in turn signal, on 05' ZZR???? | WilbersUSA | Kawasaki Streetbikes/Sportbikes | 0 | 09-20-2005 12:21 AM |
| Removing / Replacing 500R Rear Wheel | Neo | Kawasaki Streetbikes/Sportbikes | 2 | 07-18-2005 05:06 PM |
| Rear sprocket torque 500R | Villaven | Kawasaki Streetbikes/Sportbikes | 1 | 07-02-2005 01:07 AM |
| V1600 Rear Turn Signals....Why are they not running lights? | BigRed | Kawasaki Cruisers | 9 | 11-23-2004 07:32 AM |
