Old 04-10-2006   #1 (permalink)
Bish
GPZ-500
Bish's Avatar
Default gpz 500 starting motor problem
Hi i have a 1991 gpz- 500 american import it only has 1100 miles on it and has been a dream bike until now,the problem is the starting motor is turning but i am getting no compression at all,i have a haynes manual and it suggests that the problem is the starting motor clutch i removed the casing but then it said i need a special tool to remove the alternator rotor is there any other way to do this??also one of the magnets on the rotor was broken in a few pieces,will the rotor need replacing??Thanks
Bish is offline   Reply With Quote
Old 04-10-2006   #2 (permalink)
Tbone800b
Skullhead Donkey Puncher
Tbone800b's Avatar
I'm no expert but that doesn't sound good about the rotor. Welcome and I'm sure someone with experience will respond soon.
Tbone800b is offline   Reply With Quote
Old 04-10-2006   #3 (permalink)
Bish
GPZ-500
Bish's Avatar
Yeah didnt think it looked too good myself , had a 125 before this and could strip it ok but it only had a kick start no electric one,its all new to me but got to learn sometime..
Old 04-10-2006   #4 (permalink)
Fixion
Sit speling cheker
Fixion's Avatar
I had to remove that on my EX500 (same engine I believe), I just bought a bolt from fastenall and screwed it in with an impact wrench. That worked well for me, but I had the impact wrench, if you can keep the rotor from rotating, you could probably do this with a regular wrench.
Fixion is offline   Reply With Quote
GPZ 500 K reg breaking/for sale updated AcE@thetop Streetbikes Buy/Sell/Trade 1 09-14-2005 12:36 PM
Service and Repair manual for EX500 / GPZ 500 S sw@mp The Mechanics Corner 5 03-26-2005 12:37 PM
Service and Repair manual for EX500 / GPZ 500 S sw@mp Kawasaki Streetbikes/Sportbikes 4 03-24-2005 10:49 PM
Ninja 500 has hard time starting in the cold ZZX The Mechanics Corner 4 01-19-2005 06:30 AM
lowering ninja 500..and starting question greglikes8ball Kawasaki Streetbikes/Sportbikes 4 12-28-2004 08:53 PM
