Old 05-22-2006   #1 (permalink)
gabester76
Finally Got Into First Gear
Unhappy Serious Problem? Starting problem need advice
I have a 1994 Kawasaki 900 and runs great normally. This morning I tried to start my bike and it just cranks but does not want to start. I have a new fresh fully charged battery. Lghts come on.
This happend only one other time, last week. I was super low on gas but it eventually started and I filled up. Well today my gas tank is half full so I know that isn't the problem.
I am thinking a spark plug related issue? any suggestions
gabester76 is offline   Reply With Quote
Old 05-22-2006   #2 (permalink)
cudaosix
Guitar nerd
cudaosix's Avatar
Send a message via Yahoo to cudaosix
Look at the plus, if their black (carbon fouled) it wont start. New plugs, then you need to find the reason why your running so rich. Also rechange the battery, after cranking it so much it drains the battery. Eventhough the lights come on it might not be strong enough to start you bike with.
Over 40 MegaFonzies and rising
1980 KZ1000
cudaosix is offline   Reply With Quote
Old 05-22-2006   #3 (permalink)
gabester76
I am gonna charge the battery right now see what happens.
Old 05-22-2006   #4 (permalink)
cudaosix
Guitar nerd
cudaosix's Avatar
Check the plugs before you start cranking it or you'll only drain the battery.
1980 KZ1000
Old 05-22-2006   #5 (permalink)
gabester76
shoot! that means I have to remove the tank. Why shouldn't I just charge the battery and if it starts then, theres my problem.
Old 05-22-2006   #6 (permalink)
cudaosix
Guitar nerd
cudaosix's Avatar
You could, and then just charge it again. You sure your petcock is in the right position and kill switch is on?
1980 KZ1000
Old 05-22-2006   #7 (permalink)
gabester76
well I just charged it only took about 15 minutes and the bike starts right up. The bike was sitting for about two or three days we just had a storm here in california which is unusuall for this time of year. Any way I think my petcock was in the wrong position. Ijust read this article about petcocks. I put mine in the on position
http://www.obairlann.net/~reaper/mot...serve-faq.html
Old 05-22-2006   #8 (permalink)
cudaosix
Guitar nerd
cudaosix's Avatar
Cool...isnt it nice when the solution is simple and doesnt cost anything?
1980 KZ1000
Old 05-22-2006   #9 (permalink)
gabester76
on another day Off I think I will change all my plugs just to be on the safe side. after all it is an older bike. thanks
Old 05-22-2006   #10 (permalink)
wiredgeorge
Vintage Motor Mechanic!
I doubt you could have had your petcock in the wrong position as it will start in any position, prime, on or reserve. Good luck.
wiredgeorge
Mico, TX
wiredgeorge is offline   Reply With Quote
'98 zx7r starting problem tanktime The Mechanics Corner 12 04-30-2006 10:53 PM
ZX6D Starting circuit problem link? canigetin The Mechanics Corner 0 02-15-2006 02:48 AM
Cold starting problem jesse1 The Mechanics Corner 4 05-03-2005 12:23 PM
98 KX starting problem used98KX Kawasaki Motocross and Offroad 9 03-01-2005 06:22 PM
Another starting problem, VN750 wilythek Kawasaki Cruisers 12 10-20-2004 04:24 PM
