Old 08-05-2006   #1 (permalink)
pester
pester the molester
Exclamation reserve?
well i was riding the whole afternoon no problems bike worked great but
of course i had to be an idiot and forgot to put gas then i remember hey use the reserve
so bike started again but, was choking the whole time. i had to ride in the center line for about 1/2 mile until i got to a gas station,
question, why the frigging reserve didnt work properly?
engine was runnin but everytime i let of the clutch on first it was like chocking not enough gas
of course i filled with about 3.6 gallons switched to on and bingo ride again
wonder why reserve gave me troubles
pls ppl gimme some info so i can work on it tomorrow
thanks "PESTER THE MOLESTER"
God told john. come forth and u will get eternal life, instead john came fifth... and won a toaster
pester is offline   Reply With Quote
Old 08-05-2006   #2 (permalink)
diablo13346
life just got ALOT FASTER
diablo13346's Avatar
Send a message via AIM to diablo13346
uhm could be old gass diffrent octane gas in it and bike didnt like the sudden change o and where is your reserve gas tank? i gotta 95 zx6 and idk where it would be under tha tail ?meybe
diablo13346 is offline   Reply With Quote
Old 08-05-2006   #3 (permalink)
Mesa_Slim
olderigetfasteriwas
Mesa_Slim's Avatar
Were you on reserve or prime? Easy mistake to make.
If you are anitpasto does that make you provolone?
Mesa_Slim is offline   Reply With Quote
Old 08-05-2006   #4 (permalink)
nevin
Cruising In Fourth Gear
nevin's Avatar
you should run on reserve every now and then to get rid of the old gas at the bottom of the tank...i run on reserve all the time
2006 500r...green ofcourse
nevin is offline   Reply With Quote
Old 08-05-2006   #5 (permalink)
likearock4x4
Thanks to all Veterans!!!
likearock4x4's Avatar
Location: PGR Member #7955 O'Fallon, Illinois (Near St. Louis)
Just make sure you remember to put it back to the main tank, otherwise, you'll be out of gas and without a paddle.
RIP Deron Harden. :-( You are truely missed.
likearock4x4 is offline   Reply With Quote
Old 08-05-2006   #6 (permalink)
pester
pester the molester
ok mine is a 250 ninja and the petcoke have only off on and reserve, and yes. same octane could be old gas that might be true
and reseve is in the same tank
weird dont u all think? btw thnaks guys for replies is much appreciated
Old 08-05-2006   #7 (permalink)
pester
pester the molester
ok i will burn that gas thats a good idea and yeah, heck i wont forget to switch back lmao
this time felt like crap ha
Old 08-05-2006   #8 (permalink)
likearock4x4
Hopefully it's not some rust or something like that that got into the fuel line or carb or something and caused problems. Did it straighten out when you put gas in it?
Old 08-06-2006   #9 (permalink)
cudaosix
Guitar nerd
cudaosix's Avatar
Send a message via Yahoo to cudaosix
Your petcock has two fuel intakes pointing up into the tank (tubes). One is shorter then the other, the shorter one of course being your reserve which will allow you to use gas thats below the longer intakes level. I've seen both intakes with small filters on the tips and without. What could have happened is something is partially blocking the reserve intake in the tank or the petcock. you would have to remove and check your petcock. Thats what makes sense to me. Below is a link that explains how your reserve works so you get a better idea of what I'm talking about.
http://www.obairlann.net/~reaper/mot...serve-faq.html
Over 40 MegaFonzies and rising
1980 KZ1000
cudaosix is offline   Reply With Quote
Old 08-06-2006   #10 (permalink)
nevin
nevin's Avatar
I always knew the basics of how it worked...but for some crazy reason I always pictured in my head the tubes came from the top of the tank so that reserve was longer...guess that doesnt really make much sence due to where the engine is located lol. Thanks for the link, very nice site.
Old 08-06-2006   #11 (permalink)
zedx11
yellow doesn't corner wel
zedx11's Avatar
Send a message via Yahoo to zedx11
on an older bike that would be the reason, if it was newer it may be blockage in the fuel tap.
Darrell
Ignorance is a disease my friend. You should rid yourself of it.
zedx11 is offline   Reply With Quote
Old 08-06-2006   #12 (permalink)
QKENUF4U
AZ's Official Mechanic
QKENUF4U's Avatar
all gas is in the same tank, there is no OLD gas/NEW gas.
from the sounds of it like cuda said you have a blockage of the res. tube (or the little filter is crushed) pull the petcok and make sure the tubes are clean/clear. the little filters will come off but BE SUPER CAREFUL YOU DONT CRUCH/RIP THEM, you can clean them out from the INSIDE OUT.
QKENUF4U is offline   Reply With Quote
A reserve reminder for newbies... rbentnail What I learned today 18 01-21-2006 02:45 PM
Issues with fuel flow in ON vs. Reserve jmatthew The Mechanics Corner 3 12-29-2005 12:22 PM
EX500 Reserve Questions... BlackEX500A5 The Mechanics Corner 4 04-02-2005 10:28 AM
EX500 Fuel Reserve Question Narcisse91 Kawasaki Streetbikes/Sportbikes 13 09-17-2004 07:40 AM
Reserve Tank etbachli Kawasaki Streetbikes/Sportbikes 5 05-12-2004 11:13 AM
