Old 09-20-2004   #1 (permalink)
RichardMcCoy1
Send a message via Yahoo to RichardMcCoy1
Default ZX 9 Will not START!! PLEASE HELP!!
My 1997 ZX 900R was working fine. I parked it for the night. Then tried to start it the next morning and nothing. No noise nothing. Everything else works except for the horn too. When you first turn the key to the on position the instrament panel lights up. As soon as I hit the start button the headlight comes on but nothing else no noise at all.
I've checked the Batter Duh! That is new and reads fine. I've checked the engine kill switch and starter button and those are fine. I also checked the sidestand kill switch and it is in working order. When you bump start it, it fires right up and runs normal until you turn it off then you get nothing. I am fairly intellegent when it comes to bikes but I have never seen or heard of this typ of problem. Oh and the fuses are good too. The whole headlight coming on only after you attemt to start completly baffles me too. I don't think it is a wiring problem either. If someone out there knows anything else please let me know before I go and spend top dollar for something rediculus. Thanks.
RichardMcCoy1 is offline   Reply With Quote
Old 09-20-2004   #2 (permalink)
Curt
Default Re: ZX 9 Will not START!! PLEASE HELP!!
Are you saying that you tap the starter and then it fires up? Old Ford starters used to be famous for that. Just change the starter and you'll be fine.
But if you're talking about push-starting the bike, that's a different story. It still could be the starter or the solenoid. The first thing I'd check is to see if you have voltage at the starter. The big wire should have power all the time. The smaller one should only get power when you hit the start button. Are you getting those two voltages properly? Check it and report back.
Then we can trace it down from there. You've already eliminated most of the common problems, so I'm leaning toward starter failure anyway.
Curt
red 2001 Kawasai Ninja 250R
http://www.curtmorales.com/Ninja (note capitalization)
Curt is offline   Reply With Quote
Old 09-20-2004   #3 (permalink)
RichardMcCoy1
Default The Start Button
No No I did not bump the starter. What I meant was I can jump start the bike and it fires right up. But once I turn it off and try to start it the normal way with key and start button on the handle bar nothing happens no clicking from the starter or anything. The only thing that happens is the headlight comes on along with all the other lights. Also note that the horn does not work either. It was working fine yesterday. Now if the starter was bad that would not effect the horn though. I've used the horn before with out the bike being started. That is what has my concern. No clicking form junction box, starter or anything. But everything else electrical is working fine except for the horn now. And the fact that the bike will not even attempt at turning over.
Old 09-20-2004   #4 (permalink)
Curt
Default Re: The Start Button
Also note that the horn does not work either. . . . Now if the starter was bad that would not effect the horn though.
Oh, yeah. Okay, so I'm not the sharpest crayon in the box.
It sounds like the horn and starter may be on the same circuit with a blown fuse. You said you already checked your fuses, but here's what I would recommend anyway:
1. get a manual to see if the horn is on the same circuit as the ignition. If they are, I'd sure be looking very suspiciously at that fuse.
2. The horn isn't the problem, but it's a great clue. So let's find the horn fuse and pull it. Then check to see that the fuse is good and check that there is power where the fuse plugs in.
3. Check voltages on the ignition switch. You should always have power on one wire (on my bike it's a white wire) at the ignition switch. When you turn the switch to on, you should have power coming out of two more wires. On my bike it's a brown one going to the horn, and a yellow one going to the handlebar kill switch.
4. While we're at it, you said that you checked the kill switch. Did you check it for continuity or voltage or both? And while we're still at it, we could do the same for the neutral, clutch, and kickstand switches. You know, it doesn't do any good for the switch to be functioning if there is no power to the switch.
5. When you turn the key to on, you said the instrument panel lights up. Does the oil light turn on? On my bike that is powered by that same brown wire.
There's a lot more we can check. How about if we start with these and see where we go from there?
Curt
Old 09-20-2004   #5 (permalink)
Curt
Wait! Wait! Wait!
You can push start the bike? Oh, that's a huge clue. Let me think about that one for a little bit.
Curt
Old 09-20-2004   #6 (permalink)
RichardMcCoy1
Default My ZX 9
yes thats correct I can jump (push) start it and it runs fine. and the oil light comes on aswell as everything else. Well except for the purr of the engine as it is turning over LOL! Just had to make a funny. Can't let this get the best of me. Besides this is the only thing I have to look forward too everyday is a nice ride in the eavining.
Thanks for all the help. Hopefully we will figure this puppy out.
Old 09-20-2004   #7 (permalink)
Green Knight
Banned
Green Knight's Avatar
Send a message via MSN to Green Knight Send a message via Yahoo to Green Knight
I keep thinking a bad starter. I don't think it would be electrical cause I just dont' think it would stay running. I think about it and I always get back to the starter. Something is up there.
Green Knight is offline   Reply With Quote
Old 09-20-2004   #8 (permalink)
Curt
Okay, so after you push start it everything is normal; i.e. except the horn, right?
So that means that the problem should not be the key switch, nor the side stand switch, nor the neutral switch, nor the clutch switch, nor the kill switch. It might be the starter switch, even though you checked it.
Do you have an alarm on this bike? Sometimes those interefere with the start circuit and the horn.
I would like to know if there is power on the thumb-button start switch. I think that is a logical place to look first. If there is power there, then we can move closer to the starter. The next place is to check if there is power on the little wire on the starter (only when you push the start button). If it's there, then we're looking at a bad starter again. If there is no power on the starter switch, then we can look backwards towards the key switch.
Curt
Old 09-20-2004   #9 (permalink)
Curt
I would also like to know how the horn failure is related to the problem. I feel like I'm looking at all the right clues, but I can't figure it out. Does the horn itself work? You could test it by running a hot wire to it, just to make sure it is working properly.
Curt
Old 09-20-2004   #10 (permalink)
RichardMcCoy1
Default My ZX 9
Yes the horn works just ran a got wire to it and it works. And as far as the start button (switch) it has to be getting power because when I push it the head light comes on.
And no when the bike is running the horn does not work either. When I jumped it I pushed the starter button just to see real quick if it would make any noise and nothing. No horn no Noise from the starter. And this is while it is running.
I think maybe it might be the actual key Ignition itself. You think maybe? But then again when it does push start the horn and starter button still do nothing.
Thanks for all your help on this.
Old 09-20-2004   #11 (permalink)
Curt
Default Re: My ZX 9
That's right, you said that at the beginning. I told you I wasn't the sharpest crayon in the box.
I still can't quite figure out the horn clue, so I'll ignore that for the moment.
Let's look into that headlight a little more. On mine, when I turn on the key, the lights come on, except the headlight. That is to save the battery power for the starter. When I press start, the starter turns and the headlight stays off. When I release start, the headlight comes on. Does your headlight turn on "as soon as you hit the start button" or only when you release the start button? If it happens when you release it, then it sounds like that system is working perfectly.
Anyway, as you said, the starter switch is probably good. It should be a SPST switch, so if it can trigger the headlight, it shoud be fine. So let's follow the logic to the starter. The switch is working, and it has power. From there the power has to get to the starter. So let's check:
1. Put the bike in neutral, on the center stand, with the side stand up.
2. Check the "out" wire on the starter button. This is the wire that is only hot if you press the button. Make sure it is hot when you press the button.
3. Check the other end of that wire at the starter. It may go through some other switches and junctions along the way, and the color may change. But at the starter there should be a small wire that is only hot when you press the start button. This is the one that powers the starter relay. If you get power there, and only when you hit the start button, then your entire electrical system is working properly and you have a bad starter. If you're not getting power there, but you have it at the starter button, then the problem is somewhere in between. Until you figure out the problem you could hotwire the bike to get you going for a while.
My starter has these contacts (other than the big starter wire and ground)
1. white wire going from the positive starter cable to the alternator and fuse box
2. yellow wire/red stripe powers the relay when the starter button is pressed
3. black wire/yellow stripe goes to ground.
So if you were working on my bike, I would want to see power on the yellow/red wire, but only while the start button is pressed. If that's the case, it's time to change the starter.
Curt
Old 09-20-2004   #12 (permalink)
Stuart
Can't find time to ride
Send a message via MSN to Stuart
just so you know jump starting and push starting a bike are two different things, which did you do?
1982 Yamaha Virago (XV750)
Custom Rebuilt & Restored
AMA # 220196
Stuart is offline   Reply With Quote
Old 09-20-2004   #13 (permalink)
QKENUF4U
AZ's Official Mechanic
QKENUF4U's Avatar
man curt i know your trying to help but your chasing your tail. ive never seen this fabled wire from the starter your keep talking about. there is a BATTERY CABLE from the STARTER SOLENOID to the starter.
but anyways, RICHARD, since your light comes on after pushing the starter button then its fine all the way down to where power enters the junction box, you have relays in the junction box that need to be closed to power the starter solenoid/system. look in your manual and figure out the "POWER IN" wire and check it for battery voltage, then find the "POWER OUT" wire and check that for battery voltage. if that checks fine then you need to find your starter solenoid and check for voltage there.
easy test once there is put a screwdriver across the battery cable posts on the solenoid and see if the bike starts/turns over.
if you FIND NO VOLTAGE AT THE "POWER OUT WIRE" on the junction box then the box is bad, if you DO HAVE POWER OUT of the junction box and the soleniod doesnt work then the solenoid is bad.
QKENUF4U is offline   Reply With Quote
Old 09-21-2004   #14 (permalink)
Curt
I think he meant he push starting; i.e. he pushed it then popped the clutch to start it. I don't think it would start if he tried jumping it with battery cables from the car.
Sounds like good advice to me.
I still think that the horn not working is a really important clue.
Curt
Old 09-21-2004   #15 (permalink)
QKENUF4U
QKENUF4U's Avatar
Originally Posted by Curt
I still think that the horn not working is a really important clue.Curt
if i had a electrical schematic in front of me i could tell ya if the horns important. i could be that its not powering up the part of the elec. system that the horn is on. he needs to look in his manual and work his way from there.
Old 09-21-2004   #16 (permalink)
RichardMcCoy1
Default Thanks for the help
Well the bike is now in the shop. I narrowed it down to the Junction Box. After many painstaking hours. It is the starter relay inside the juncktion box go figure.
thanks Curt I will let you know for sure when they get it fixed.
Old 09-21-2004   #17 (permalink)
QKENUF4U
QKENUF4U's Avatar
Default Re: Thanks for the help
UHHHHH HELLLLLLOOOOOOOOO im the one that told you about the junction box/relays. wheres my THANKS !!!!????
Old 09-21-2004   #18 (permalink)
Curt
Here ya go . . . Thanks. You nailed it. I'm sure he meant you instead of me.
Curt
Old 09-21-2004   #19 (permalink)
QKENUF4U
QKENUF4U's Avatar
thanks curt, was just given him ****. you where doing a good job of explaining things but kinda working the wrong way. but then i went to school to learn this stuff so i better know what im talking about huh ?
Old 09-21-2004   #20 (permalink)
yoassizmine
Foil Inspector
i was wondering where does you guys learn all this stuff?
because im a nooob and would like to gain some knowledge of the bike's mechanical issues.
thanks
yoassizmine is offline   Reply With Quote
zx7r wont start tino Kawasaki Streetbikes/Sportbikes 10 08-18-2008 01:18 AM
'04 205 - Won't start, no power noodlenoggan Kawasaki Streetbikes/Sportbikes 5 07-22-2005 10:46 PM
Won,t Start LARRY BARWICK The Mechanics Corner 5 05-24-2005 06:09 PM
kawasaki zzr250 wont start - please help pitbull51 The Mechanics Corner 6 08-02-2004 12:39 AM
95' zx6r cold start takes very long sin5150 The Mechanics Corner 3 04-22-2004 12:12 AM
