Old 03-05-2007   #1 (permalink)
Villaven
Turtle Wax Taster
Default New rear tire with old stock front?
Ok folks, what's the consensus? My rear tire is starting to show its age and it's time to consider replacing it. Is it so wrong to put a new tire on the back that is not exactly the same as the one in the front? On my old 500R I put a new Avon tire in the back with the stock front and it seemed fine. Not a high performance bike I know, but I am not heading to the track anytime soon either. Now with my '04 636 I am in need once again. I really can't afford to buy both tires right now, I wonder if I can get away with replacing the rear with a nice new tire and then matching up the front when I can. What do we think?? Oh yeah the front is stock Bridgestone BT012
Villaven is offline   Reply With Quote
Old 03-05-2007   #2 (permalink)
Thmastr
rain is here
Thmastr's Avatar
I would advise against it (I have no personal experience in this) but I woul only replace the back if I replaced it with the same tire as the front.
2 different manufacturers= 2 different compounds.. and u dont want to have a softer back than a front.
Proud owner of an 06 Ninja 250.
Yes I am 6'4 and yes I weight 160 lbs
Thmastr is offline   Reply With Quote
Old 03-05-2007   #3 (permalink)
suegip
enjoying the ride
suegip's Avatar
Ideally you would replace both tires at the same time, but one new tire at a time is better than running a bad tire. I have replaced tires one at a time many times with no ill effects, so I would say go for it.
suegip is offline   Reply With Quote
Old 03-05-2007   #4 (permalink)
southjersey636
Way Too Much Free Time
southjersey636's Avatar
Send a message via AIM to southjersey636
Not a problem. Have done this numerous times and just remember unless your doing insane knee dragging you wont notice the difference. I been in your situation plenty of times.
2004 Kawasaki ZX6R 636
1995 Kawasaki 600R (old bike)
1991 Plymouth Laser
southjersey636 is offline   Reply With Quote
Old 03-05-2007   #5 (permalink)
Villaven
Turtle Wax Taster
Thanks guys. I figured as much. It's just nice to hear it from others ya know?
Old 03-06-2007   #6 (permalink)
zedx11
Banned
usually wear out 2 rears to one front and rarely get the same tire because of whats on sale at the time. never had any problems.
zedx11 is offline   Reply With Quote
Old 03-06-2007   #7 (permalink)
UNDERTOW
Cruising In Fourth Gear
UNDERTOW's Avatar
Default just remember tire break in
i would just replace one at a time but try to keep with the same tire
2006 ex500 = old bike
2007 zzr600 = new bike
UNDERTOW is offline   Reply With Quote
Old 03-06-2007   #8 (permalink)
fretbuzz
Non Omnis Moriar
fretbuzz's Avatar
I replaced my rear at 14,000 miles and I just now need a new front at
20,000+, so it would be a serious financial wast if I would have replaced the front just because I replaced the rear.
Unless you are a hard-core racer I don't see where it would matter.
Disclaimer: I am no expert.
fretbuzz is offline   Reply With Quote
Old 03-06-2007   #9 (permalink)
4W4K3
Foil Inspector
Send a message via AIM to 4W4K3
If you have the funds, I'd go ahead and buy both new front and rear. But then keep the old front tire as a "spare". If for some reason you have a problem with the new front, you have a back-up tire to hold you over.
If you can't afford both, just replace the bad one and don't worry about it. Like others have said you probably won't notice a big difference unless you are taking it to the track and really counting on sticky tires.
MSF, Bike, License
Can I eat your brain? - http://kevan.org/brain.cgi?4W4K3
4W4K3 is offline   Reply With Quote
VN900 Front tire colbycurtis Kawasaki Cruisers 3 01-11-2007 07:38 AM
KX65 white smoke and locked up rear tire opihiman911 Kawasaki Motocross and Offroad 4 09-04-2006 07:15 PM
1993 ZX-6E - Tire Change (Rear) WSentertainment Kawasaki Streetbikes/Sportbikes 2 05-28-2006 05:49 PM
front tire scupping out samuel The Mechanics Corner 8 01-07-2006 11:28 AM
Replacing your stock front turn signals - Mean Streak SleekStreak Kawasaki Cruisers 10 08-18-2005 09:57 PM
