Old 03-30-2007   #1 (permalink)
dabige
Default 1994 B ZX-9 Factory Pro Jet settings?? Help
Hi all,
I have a 1994 B ZX-9 and purchased a factory pro 1.7 Kit for it... Installed it and set it to the recomended settings and have problems between 2-3.5 K... during roll-on acceleration and tip-in throttle ... but WOT from a dead stop... everything is fine...
Before I take everything apart and dial the settings in... I wanted to share my settings and maybe get others to share theirs so that I can minimize the number of times I have to take the carbs apart.
Header Pipe: Stock
Muffler: Yoshimura slip on
Advancer: Factory pro +4 degrees
Needle position: 3.5 (from the top) on all 4 needles
Fuel screws are 2.75 turns out
Main Jets: 195/205 stagger (2 cylinders at 195 2 at 205)
Thanks in advance!
dabige is offline   Reply With Quote
Jet Kit Info diablo13346 Kawasaki Streetbikes/Sportbikes 7 07-25-2006 01:13 PM
Jet Settings Nutmeg Kawasaki ATV and Mule 0 06-19-2006 03:52 PM
need pilot jet... ratfink The Mechanics Corner 1 05-03-2006 12:12 AM
Correct jet size and settings DeathTrap The Mechanics Corner 1 02-02-2005 08:53 PM
2001 ZX9R- factory suspention settings hooliganx1 The Mechanics Corner 3 02-04-2004 03:57 PM
