Old 04-08-2007   #1 (permalink)
biker4life
Born to be wild :)
Default Is tuning the answer ?
Hi, I've just finished giving my 96 ZX9R-B a lengthy service and am looking for some advice. This may seem a stupid question but i'm worried and need a second opinion so i'll explain the situation so far. I've added a new K&N high flow air filter, K&N high flow oil filter, Fully synthetic oil, NGK iridium spark plugs, coolant change and last but not least a full Beet Nassert exhaust system with titanium pipes. I knew it would need a tuning afterwards but at the moment it can barely hit 4000 rpm through all the gears and lets off more of a Harley rumble than the crazy sound of a screaming Ninja, i've only taken it for a short ride just to test it out but it's a lot worse than i expected, can a tuning cure this problem or could it something more serious ? It idle's almost perfectly at 1100 rpm and only has a short delay in throttle response when in neutral and will smoothly fly up the rpm. I'm no mechanic but i've been busier than a one armed decorator and have carried out all work keeping strictly to the service manual. Any help would be greatly appreciated, Thanks
biker4life is offline   Reply With Quote
Old 04-08-2007   #2 (permalink)
Tbone800b
Skullhead Donkey Puncher
Tbone800b's Avatar
Something isn't hitting right. Good Luck. Someone should be able to lend some advice shortly.
2005 Vulcan 800 Classic
V&H Cruizers
Hi-Five Air Cleaner
Tbone800b is offline   Reply With Quote
Old 04-08-2007   #3 (permalink)
Colo_636
Colo_Ninja 636
Sounds like it may be running rich, not sure though need a little more info. Mine did the same thing though. The carb was finished. through on a new one and she ran great. I had pretty close to the same type of problem. I could run it up in neutral fine but as soon as I put a load on it, it would run like crap like it wasnt getting any fuel or to much. I replaced the carb and she was fine.
2006 Kawasaki Ninja 636
Colo_636 is offline   Reply With Quote
Old 04-08-2007   #4 (permalink)
bennice
RIP Deron
bennice's Avatar
I'm no mechanic, but am pretty sure that you've got to have it jetted and tuned after the K&N air filter and pipe.
Please contribute to the SFC Ezell Memorial Bike Project/Fund. More info here.
bennice is offline   Reply With Quote
Old 04-08-2007   #5 (permalink)
Colo_636
Colo_Ninja 636
+1 probably running rich.
Old 04-08-2007   #6 (permalink)
biker4life
Born to be wild :)
Thanks for all the reply's, yer that the problem i'm having aswell colo so i'll keep that in mind. how much does it cost to get a reputable Kawasaki specialist to tune a bike ? cheers again everyone
2005 ZZR600 (ZX600J4) Suspension Tuning rlovrin1 The Mechanics Corner 6 07-06-2006 12:35 PM
PC III Tuning: am I thinking too much? Wicked96SS Kawasaki Cruisers 1 06-17-2006 09:38 AM
Mean Streak Dyno Tuning Question uf-engineer Kawasaki Cruisers 24 12-09-2005 09:45 AM
two-stroke tuning questions Dr. Feelgood The Mechanics Corner 3 04-24-2005 11:32 AM
Carb tuning tips StinkBug Kawasaki Streetbikes/Sportbikes 1 01-30-2005 11:47 AM
