Hello
i am normally on thumpertalk fourms but i do own a 2006 ex250 and i wanted to join the kawawaki fourms and see what you guys and ladies have been doing to your bikes. Has anyone ever done a spark plug mod to any street bike? you know if you take the spark plug wire off the plug and looked into it you see a slotted screwdriver bolt in it. well if you take that out you get a resistor and a spring. if you replace that resistor with a peice of 4mm stainless steel bolt it will deliever a hotter spark. which increases throttle response and gives a tiny bit more power. any one done this? i have done it to my dirt bikes and seen great things from it. i just thought it would make the little 250 a but more worthy. also is there a common opening up of the 250s? like remove a snorkel in the airbox and put a slip on exhaust or remove the baffle? any cheap upgrades? |
| Spark Plug Wiring, 85 GPZ900 Need Help quick Please | megahyperion | Kawasaki Streetbikes/Sportbikes | 4 | 04-23-2008 10:14 AM |
| 1998 Bayou Carbon build up on spark plug | Nick8564 | Kawasaki ATV and Mule | 10 | 03-19-2007 11:17 PM |
| spark plug question | vencenexus112 | The Mechanics Corner | 2 | 09-15-2005 11:12 AM |
| Helicoil question...... | Chromequeen | The Mechanics Corner | 23 | 08-10-2005 12:37 AM |
| Vulcan 2000 Spark Plug Installation | dacvulcan | The Mechanics Corner | 1 | 03-13-2005 06:07 PM |
