Old 05-10-2007   #1 (permalink)
a-ron
Let the good times roll..
a-ron's Avatar
Send a message via AIM to a-ron Send a message via MSN to a-ron Send a message via Yahoo to a-ron
Default Tank mount GPS, good idea?
Hey all, I'm just wondering if anyone else does this or not.
I like to get on the road and ride sometimes, and I cannot count how many times I've either had to stop and ask for directions, or take a map with me and pull over each time to check and recheck the directions I was given.
FINALLY, I bought a Garmin GPS. Fell in love with it. Bought the cheap C330, basic introductory GPS because I'm not looking for anything too fancy, just something that can point me in the right direction (literally, lol).
Well this unit was originally intended for my car, I am wondering if it's uses can be expanded upon.
Got home last night with it, and looked into the garage to see the bike. Of course I had to go and play with the suction cup mount. Tried mounting it on the inside of the windscreen, didn't work. To much of a concave effect going on in there. Then I set it down on the tank, thinking, and tried to pick it up and experienced resistance. **LIGHT BULB GETS REALLY BRIGHT OVER MY HEAD**
Pulled up the little lever to mount it, stuck it to the tank, pushed the lever, and BOOM mounted. I tried to pull (with a little force at first) it off a few times, then tried to rip it off with quite a bit of force, and it seemed pretty well put.
Sorry I draw stuff out, I like to explain everything in detail first
Now to my actual question, has anyone ever done this before? Or should I nix the idea?
Main things I'm worried about are bumps in the road, and wind.
Would the windscreen block the unit from most of the wind coming directly at the bike from higher speeds?
a-ron is offline   Reply With Quote
Old 05-10-2007   #2 (permalink)
kingofwings
Posting Slacker
kingofwings's Avatar
I have a Garmin mounted on my handlebar and love it. I do have a lanyard on it just it case the mount failed.
R.I.P. Deron
kingofwings is offline   Reply With Quote
Old 05-10-2007   #3 (permalink)
Pistobah
Workin too much
Pistobah's Avatar
I like the idea man. If you tried to rip it off and it still stuck, you'll probably be fine, but i'd take Frank's idea of the lanyard and use that as a safety net in case it does break lose. One of these days i'll have to break down and get a gps thingy.
Chris
'05 ZX-6R
'05 SV650S
1954 BMW R51/3
Pistobah is offline   Reply With Quote
Old 05-10-2007   #4 (permalink)
eddogg12
Finally Got Into First Gear
I believe that they do make a handlebar mount, for some of the smaller units like the Etrex Series, etc... The Problem with that is, they are alittle harder to see, and at night you would constantly need to have the backlight on.
Although, With a smaller unit generally you need something with mapping capabilities, and need additional software (ie. mapsource) to download more detailed maps other than the base map set.
eddogg12 is offline   Reply With Quote
Old 05-10-2007   #5 (permalink)
jaseman
Insane in the membrane
jaseman's Avatar
I've been thinking about a GPS unit for a while. My only problems with mounting it on the tank are A) I ride with a tank bag, and B) I'd rather have it mounted on the bars or dash, so it's more head's up. But my old ZX-10 has alot more dash than your bike.
03 MeanStreak
'90 ZX10
'04 Honda 599
Ride it like you stole it!
jaseman is offline   Reply With Quote
Stranded Gas in the 2005 1600 Nomad Tank + Misc. dhg Kawasaki Cruisers 8 08-27-2005 06:14 PM
Need a good GPS for the bike NYcruiser Kawasaki Cruisers 12 08-04-2005 11:23 PM
Mount Baker Ride - Pics Spok Rides, Events and Rallies! 11 06-20-2005 11:16 AM
My second bike, so far so good... NovaPhoenix Main Lobby 9 04-20-2005 05:13 PM
filling tank, gas milage, dummy light question VetDr Kawasaki Cruisers 4 09-06-2004 04:46 PM
