Hi I have made several posts in hopes of getting my 85 600r ninja to start when it is cold,It takes better than 2hrs to get it to fire up even with starting fluid,and having a battery charger on all the time I try so I dont kill the battery while In trying.I have change coils cdi box plugs wires carbs adjusted fuel level changed carbs even put stock carbs and air box back on still refuses to start cold. I have noticed that even after I have tried starting it for some time I have pulled plugs and found them to be dry HOW is this posible I have cleand carbs and know pilot jets are clean and carbs are spotless ????????????????? why is no fuel getting into the pulled into the engine valves are set and engine has great compression across the all 4 cyl. This problem is getting old and I have run out of things to try
#4 (permalink) |
I checked it with a guage no1 178psi no2 175psi no 3 178psi no4 177psi
I have a good blue spark that junps a 14in gap gauge and have had both cdi boxes checked at the dealer both coog as well as coils and wires I know it should start but it dosent when it dose start it runs like a kitten and will star all day long but if you let it sit overnite wham ////// |
| electrical starting problem, please help | jivelivinhippy | Kawasaki Streetbikes/Sportbikes | 19 | 12-10-2006 10:01 PM |
| Newbie starting & idling problem | DarkKawa | Vintage Motorcyle Info | 5 | 09-08-2006 12:19 PM |
| Kawasaki 360 4x4 idle problem when cold | yvcharro | Kawasaki ATV and Mule | 5 | 04-15-2006 06:15 AM |
| KVF 360 cold weather starting | mike360 | Kawasaki ATV and Mule | 4 | 10-18-2005 11:02 AM |
| Problem strating bike in cold weather after lapse of time | Melv | Main Lobby | 5 | 01-01-2004 01:18 PM |
