how to???
+ Reply to Thread
Results 1 to 6 of 6
Thread: how to???
  1. #1
    Join Date
    Mar 2007
    Location
    dover, de
    Posts
    17
    Default how to???
    i just bought some lowering links for my zx7r and i was wondering if anyone knows how to install them on my bike or maybe send me in the right direction.
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Honest it wern't me !! ULTIMATE Forum Supporter GREENISBEST's Avatar
    Join Date
    Nov 2006
    Location
    Northants UK
    Posts
    2,432
    Are they fixed or adjustable links ??
    Normally you will need to suspend the back of the bike to relieve the weight from the suspension so you can remove the links and replace with the modified ones.
    Depending on how much they lower the bike you may need to cut down the side stand otherwise the bike will sit to upright making her prone to falling over..
    BEWARE Make sure you are confident that the bike is supported well enough otherwise you can knock the link securing bolts out and end up with the bike collapsing onto the rear wheel/fender and or bouncing onto the floor
    A couple of extra pair of hands either side of the bike for safety is preferable, Thats two people, four hands
    END OF KEV's MESSAGE !
  4. #3
    Join Date
    Mar 2007
    Location
    dover, de
    Posts
    17
    they are the adjustable links.....1.5 or 3 inches. how do i lower the front?
  5. #4
    Join Date
    Nov 2006
    Location
    Northants UK
    Posts
    2,432
    Quote Originally Posted by EMFL View Post
    Usually the lower kit instructions will give you an idea as to how much to lower the front end............
    But if you have none then a rule of thumb is to drop the forks through the yolks 10mm...
    Again you will need to support the front this time and loosen the yolk pinch bolts top and bottom..
    As the back end, assistants are a bonus in case the front drops suddenly and requires you to replace the front fender
  6. #5
    Join Date
    Mar 2007
    Location
    dover, de
    Posts
    17
    ok cool but one more thing, how should i modify the side stand???
    thanx for all the help
  7. #6
    Member BTK Expert
    Join Date
    Oct 2005
    Posts
    22,566
    you could find someone with a welder to cut and weld it or find an adjustable one.
+ Reply to Thread
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
