Old 06-01-2007   #1 (permalink)
heepofajeep
Default Headlight blowing fuses
I am sure this is a really dumb question, but I am hoping you guys can help me with some quick troubleshooting...
My newly acquired 2002 zx7r is blowing the fuse in the headlight. It blows instantly on high beam, and intermittently on low beam...
So my [very lame] question is, does the fact that one is intermittent and the other definite mean anything as far as diagnosis goes?
Thanks!!!
heepofajeep is offline   Reply With Quote
Old 06-01-2007   #2 (permalink)
zedx11
yellow doesn't corner wel
zedx11's Avatar
Send a message via Yahoo to zedx11
check the wiring harness, make sure there are no shorts.
Darrell
Ignorance is a disease my friend. You should rid yourself of it.
zedx11 is online now   Reply With Quote
Old 06-01-2007   #3 (permalink)
eidian
Black is faster, right?
eidian's Avatar
+1 and then follow the wiring up to the light--it's shorting somewhere. The intermittency (is that a word?) means that the short is probably from something that is loose that randomly grounds out. My guess is that you'll probably find some frayed wiring that is exposed.
'07 black Z1000: Power Bronze/Projekt D/EYI Designs/Leo Vince/Puig/Galfer/T1Concepts
eidian is offline   Reply With Quote
Old 06-01-2007   #4 (permalink)
bountyhunter
Way Too Much Free Time
Check the bakelite connector that goes on the back of the headlight. They usually have three wires (HI, LOW, GND). If there is a current path to the ground line, it will blow fuses.
ALSO: make sure the correct fuse is installed (probably a 10A) and make sure it's the right headlight for the bike. If it is some funky, super bright off-road light it may be pulling too much current for the fuse.
bountyhunter is offline   Reply With Quote
Old 06-01-2007   #5 (permalink)
xeon
Wants better weather!
xeon's Avatar
Second checking the headlamp type... something that runs at 100+ watts doubles the current essentially from stock. That would be my guess from the observation of it blowing the fuse on high every single time as opposed to some of the time on the low beam.
Black '06 Ninja 250R
Red-n-Silver '99 YZF600R
xeon is online now   Reply With Quote
84 KZ 550 blowing fuses Joscelin The Mechanics Corner 4 10-13-2006 11:24 AM
84 KZ 550 blowing fuses Joscelin Kawasaki Cruisers 1 10-10-2006 02:50 PM
1500 Classic blowing fuses smokey_243 The Mechanics Corner 2 08-25-2006 09:08 AM
Problem with Ignition Blowing fuses lonestar Kawasaki Cruisers 0 07-21-2005 10:03 AM
Blowing fuses 1981 Kawasaki kz1100 fuzzy2874 Vintage Motorcyle Info 2 11-08-2004 10:04 PM
