Old 06-07-2007   #1 (permalink)
JimMcQuaid
Jim McQuaid
Default Need 1981 KZ 440 LTD underseat air filter parts
I need the two pieces that sit under the seat, over the battery of my 1981 440 LTD. The part numbers are 11011 (Case, Element) and 11012 (Cap, Air Filter).
My dealer here in Ottawa Ontario Canada says they are not available new Sad . So, can someone point me to where these parts might be available new or even used? I was able to get the foam filter itself (11013).
Thanks.
Peace
Cheers, Jim
613-791-5900
email jimpmcquaid@yahoo.ca
JimMcQuaid is offline   Reply With Quote
Old 06-10-2007   #2 (permalink)
Shamrocker98
Shamrocker98's Avatar
Thanks.
Peace
Cheers, Jim
613-791-5900
We faced the same issue...the last owner removed the stock airbox and replaced it with two high performance air filters (one for each carb). The only problem was that the carb was shaking loose all the time, since it was not attached to the frame any longer. When faced with the option of searching for an old, rare, expensive air box....our mechanic made a small custom bracket to attach the carb to the frame. Worked like a charm. I know it doesn't help your search, but it is a workable option if you need one
Josh P.
1981 KZ440 LTD
Shamrocker98 is offline   Reply With Quote
Air Filter Cleaning Norseman10 Vintage Motorcyle Info 6 05-04-2007 09:27 AM
Air Filter Cover blew off while riding Neo Vulcan Kawasaki Cruisers 8 02-17-2007 06:52 PM
MS: TOO MUCH oil!! Damage? K&N air filter replacement? AdamBomb Kawasaki Cruisers 23 07-02-2006 01:32 AM
81 Kz440 Ltd air filter gizmo200118 Vintage Motorcyle Info 15 06-03-2006 12:13 PM
Replacing Stock Air filter with K&N joecruiser Kawasaki Cruisers 4 12-28-2005 11:48 AM
