Old 06-09-2007   #1 (permalink)
WarX
Made It To Second Gear
Send a message via AIM to WarX
Default ZX600c Headlight question
Hey, quick question for you guys, has anyone noticed that when starting the bike the highbeam bulb/highbeam itself flickers? I wired my HIDs up so that it ONLY turns on with highbeams on so that the ballast only sees a constant voltage instead of a varying one that could kill it. But i was surprised when i started the bike a few days ago and the HIDs turned on immediately and flickered off and kept turning on/off with revving or while the bike is being turned over...
Basically my question is... is there any way to stop the bike from powering the high beam circuit before the motorcycle is on/before the highbeam switch is flicked?
WarX is offline   Reply With Quote
Old 06-09-2007   #2 (permalink)
86Ninja
EX650rider
Yeah get a new headlight modulator, yours is either bad, or you wired it up wrong.
86Ninja is offline   Reply With Quote
Old 06-09-2007   #3 (permalink)
WarX
nah, didn't wire it up wrong, i do car electronics usually :p everything is correct.... 'kay, gonna check the headlight mod.
Old 06-10-2007   #4 (permalink)
WarX
wait a minute, does the the motorcycle come WITH a headlight modulator factory? i just googled it and it looks like an aftermarket part... maybe you might have misunderstood what i was talking about... anyone else with any information possibly?
Old 06-10-2007   #5 (permalink)
xeon
Wants better weather!
xeon's Avatar
I would have to have a better understanding of your wiring and components. Is this one of those kits from E-bay where you slap a HID in your stock reflector? You should have the HID wired directly to your battery. Although HIDs run at 35W, the ballast has quite a current draw to get started which can be problematic on stock wiring. I wouldn't wire it to turn on or off with the high beam since HIDs don't like to be flicked on and off. In any regards, it sounds like a ballast problem with the little bit of info given...
Black '06 Ninja 250R
Red-n-Silver '99 YZF600R
xeon is online now   Reply With Quote
Old 06-10-2007   #6 (permalink)
xeon
xeon's Avatar
Old 06-10-2007   #7 (permalink)
86Ninja
EX650rider
Its not really called a modulator, its called a reserve lighting device, any here's the schematic
Old 06-10-2007   #8 (permalink)
WarX
Xeon, what would you wire it to do? don't you want to wire it to turn on and off?
The point of the ballast is to charge electrically then send the signal to the xenon inside the bulb to excite it to light up... I wired the HID input to the high beam input so that it does not get a varying voltage during startups/revving as it is right now. The high beam itself has a separate switch to turn it on and off versus starting the bike and getting the HIDs immediately turned on.
I retrofitted projectors into the factory housings, i didn't use the standard reflectors for the HIDs. Also, if i had it wired directly to the battery... is it to stay on 24/7? since you can't exactly just pop the wires onto the battery and off of it... you can, but that's just not intelligent. You are supposed to have a sort of means of turning on and off the HIDs, they're made to turn on and off.
86Ninja, thanks, i think that's what i was looking for. i'll check it tomorrow and try to trouble shoot it. Thanks again
Old 06-11-2007   #9 (permalink)
xeon
xeon's Avatar
To properly wire a HID you should wire directly to the battery. I fully understand how HIDs work and the initial current draw to start the HID is substantial.
In terms of the HID always being on, you wire your custom harness with a relay that turns it on and off via integration with the stock lamp connector. What you do not want to do with HIDs is flick them on and off, they may not always relight and it will shorten the lamps life considerably. It is for that reason that HIDs use a shutter that moves for hi/lo beams... the lamps remain lit and the same while on. Below is but one harness example illustrating a dual bi-xenon:
You are on the right track with using a full retrofit with projectors, but I suspect your wiring harness is questionable. My advice since you are wiring savvy, poke around hidplanet.com forum and figure out a harness.
Old 06-11-2007   #10 (permalink)
WarX
already done that =P and as for the relay, that's done already, it's just that instead of having it turn on automatically with the bike i'd rather have it run w/ just the highbeams on since it's single beam. When they're on, they'll stay on with the bike, they won't be flicked on and off. That's the problem with them right now is that they ARE being flickered on and off because there is some short or something wrong in the line where the low beam is somehow powering the highbeam which flicks the relay over to allow power into the ballast, and the ballast sees a varying current... but i've got the correct wiring done
Ninja 600 (ZX600-c) Headlight Question 600r The Mechanics Corner 1 03-18-2007 07:39 PM
Headlight wiring Question darkwolf29a Vintage Motorcyle Info 9 02-20-2007 10:13 AM
Headlight bulb question for ZX-7R 2002ZX7R Kawasaki Streetbikes/Sportbikes 2 04-17-2006 02:41 PM
2003 636 headlight question vboulytchev Kawasaki Streetbikes/Sportbikes 1 06-10-2005 10:42 PM
1990 zx600c question. Identity Crisis Kawasaki Streetbikes/Sportbikes 11 11-15-2004 10:47 PM
