Old 08-11-2007   #1 (permalink)
aftermath4788
zx-11/250r
aftermath4788's Avatar
Default rust in gas tank
i got a problem with rust in my gas tank. i have a 1991 zx 11 and it is annoying to me. it gets in my carb bowls and makes my bike sputter and run like crap. i drain the bowls, the gas is orange with rust and clean the carbs like 3 times a month. when i do that it runs perfect. then a few days later rust builds up in the carbs and here we go again. i hate cleaning my carbs every other week to keep it running right to i need to get rid of the rust without replaceing the gas tank. i dont want to use acid because i dont want to eat a hole in the tank. my friends at the dealership said to put some kind of coating in the tank to cover the rust. he said it will put this coating that is sorta like the coating on the handles of pliers. this rubber mess. what are you guys opinion on it? should i do that or is there another way and if not how hard is it to put that coating in it?
aftermath4788 is offline   Reply With Quote
Old 08-11-2007   #2 (permalink)
tractor
take the tank off and empty the gas, put about 1 gallon of rocks in the tank with water, roll the tank gently with lite shaking. The rocks will clean the spots of rust off the tank. Keep inspecting the inside of the tanks and you will see it clean up. Wash the tank out really good, dry out your tank with a blower before re-installing it. Replace with new gas and happy riding. In the future drain the tank if you are going to let it sit for a long time like in the winter.
tractor is offline   Reply With Quote
Old 08-11-2007   #3 (permalink)
Ruger
Poser ProudŽ
Ruger's Avatar
The stuff is called "sloshing compound", and you can get it at most automotive stores or I'm sure you can order it off the internet. It is a multipart goo that you mix, pour into the tank, then rotate the tank around every so often to make sure it gets to all the bad spots. It is kind of a pain to do, but the stuff I got worked very well. It puts a heavy coating of stuff on the inside surface of the tank that will probably outlast the tank itself. I did a tank over 10 years ago and it is still in great shape. The stuff I got was not cheap, around $50 as I remember, but I was restoring a '81 KZ 1000 and I couldn't get a tank for anywhere near that amount. Oh yes just one thing, once you slosh the tank you can't use several popular fuel additives (like B12) because they have acetone in them and will dissolve the coating.
Good luck.
2006 VN900 Classic
The best car safety device is a rear-view mirror with a cop in it. - Dudley Moore
Ruger is offline   Reply With Quote
Old 08-11-2007   #4 (permalink)
Nessism
Third Gear And Gaining
There are two common brands of tank cleaning/lining materials: Kreem and Por-15. Of the two, Por-15 has a better reputation from what I've heard. The repair kits includes a de-rusting solution (phosphoric acid) and a liner. Depending on how much rust you have in the tank you can just go with the phosphoric acid wash if it's not too bad.
Search Result Page OEM Parts from Z1 Enterprises, Inc.
Heavy Duty Cycle Tank Repair Kit
Nessism is offline   Reply With Quote
Old 08-11-2007   #5 (permalink)
zedx11
yellow doesn't corner wel
zedx11's Avatar
Send a message via Yahoo to zedx11
http://www.kawasakimotorcycle.org/fo...-gas-tank.html
Darrell
Ignorance is a disease my friend. You should rid yourself of it.
zedx11 is offline   Reply With Quote
Old 08-12-2007   #6 (permalink)
aftermath4788
zx-11/250r
thank you for the response i will give it a try
Gas leak from the gas cap left brownish stuff on the tank sqldosa Kawasaki Cruisers 6 06-19-2007 10:30 PM
Gas tank whine Crosstown The Mechanics Corner 11 11-26-2006 11:12 PM
Bad tank of gas minnzoo3 Kawasaki Cruisers 13 09-01-2005 06:37 AM
gas tank cleaner intrepid7 Vintage Motorcyle Info 6 08-08-2005 06:41 PM
Rust in the gas tank 79batmobile Kawasaki Streetbikes/Sportbikes 4 08-03-2005 08:49 AM
