Old 12-17-2004   #1 (permalink)
ZX6RRNewbie
Sit speling cheker
ZX6RRNewbie's Avatar
Talking 2005 ZX-6R Street & Track Test!! DAY 1
Taken from www.motorcycle.com:
"Almeria Spain, 12/15/2004 ~ 2005 marks the 20th anniversary of the GPZ 600R Ninja and the birth of the 600 Supersport class. Since that fateful day twenty years ago, the 600 class has been defined by constant improvement and a controversial trend towards narrow focused racetrack oriented sportbikes. In 2003, Kawasaki fired one of the loudest shots in the 600 class, when it introduced the extremely aggressive ZX-6RR and 636cc ZX-6R. That ZX-6R made 108Hp at the tire, shading its competition by over 4Hp and scaring its riders with a razor sharp focus that translates into a nervous front end and a punishing ride on anything but the smoothest pavement. Still, its sizable horsepower advantage allowed it considerable sales success.
Not content with dominating the horsepower wars, Kawasaki has decided to refine the 6R's street manners, in an effort to challenge the more comfortable Yamaha R6 for top Supersport "Streetbike" honors. Because Kawasaki claims that the ZX-6R is aimed at street and track day riders, while the ZX-6RR is a limited production motorcycle aimed squarely at roadracers, the all-new 2005 ZX-6R receives special revisions aimed at improving its comfort and overall suitability as a streetbike. Most notably, these revisions include a more linear powerband, flatter and more comfortable rider's seat, a slight relaxing of the old 6R's nervous steering geometry and an under tail exhaust.
In addition, Kawasaki switched from Kayaba to Showa suspension components, softening the old 6R's (overly harsh) dampening in the process. They also relaxed the riding position, changed the wheels to a lighter and stronger 6-spoke design like the ones on the ZX-10R, changed the brake rotors to a "petal" design (also like the ZX-10R), upgraded the master cylinder to a radial-pump unit, completely redesigned the frame, bodywork, intake and about twenty other things and generally refined the old bike into a nicer package. Kawasaki claims that these changes add around +3Lbs to the bike. Oh yeah, lest you think the ZX-6R is growing "soft" on us, consider this amazing fact: Kawasaki also redesigned the engine and they now claim that the 2005 ZX-6R has gained Nine horsepower. Since the previous generation ZX-6R made an honest 108Hp at the tire, the 2005 bike should be putting something in the neighborhood of 117Hp to the ground! Folks, I don't care if the thing has ape hangers and foreward controls, if it weighs less than 420Lbs wet and generates 117Hp, nobody is going to call it "soft".
Now that horsepower cat is out of the bag, let's discuss how Kawasaki achieved this stunning output from a mere 636cc of displacement. The obvious changes are the typical hot rodder tricks of higher compression and better breathing. To be specific, the 6R's intake throats have developed an oval cross
A quartet of new "shower" type injectors sit immediately upstream from the new oval-shaped intake throats.
section, allowing the total volume of airflow to increase, without increasing the actual diameter of the throttle bodies. This prevented any frame widening to accommodate a wider throttle body rack. Immediately upstream of that rack sits a quartet of new "shower" type injectors, which come on-line above 5,500RPM to supplement the flow from the standard injectors. Once the mixture is properly enrichened, it enters a new cylinder head, which has been enhanced with a smoother surface treatment. Those smoother intake passages lead to a set of +1mm larger intake valves and once inside the combustion chamber, the mixture is compressed 12.9:1 (up from 12.8:1) by a new set of deeply crowned pistons with low-friction skirts, before igniting and being expelled through a set of +1mm larger exhaust valves. After exiting the engine, the gasses travel to a catalytic converter and then out through a new flapper-valve equipped under-seat muffler. That computer-controlled valve is closed until around 5,500RPM (depending on throttle opening, etc.), increasing backpressure and boosting low-mid RPM torque. Above 5,500RPM, the valve opens an additional passage through the muffler, to allow the deeper breathing necessary for good high-rpm performance. In a reversal of SOP, Kawasaki moved the cylinders into a more upright position, reducing their foreward-cant from 25° to 20°. Other engine revisions include the addition of a slipper clutch like the one on the ZX-6RR, and a deeper oil sump with a revised pump, to reduce crankshaft windage and cut parasitic drag.
Day 1 - The Street
All that power is well and good on the racetrack, but on public roads, it's the powertrain's refinements and the integration of the whole package that impresses most. Though it is a cold morning, there is no need to pull any "cold start" levers, because the '05 bikes now feature an auto fast-idle circuit in their ECU. This means the ZX-6R fires-up with a minimum of fuss and quickly adjusts its idle speed to suit the engine's temperature. The Spanish countryside received a pounding from Mother Nature in the days preceding our visit, so the roads are mostly filthy and wet. As I accelerate away from the racetrack and out into the foothills, the new 6R quickly has me relaxed, because the throttle is delivering exactly the level torque that I request, so traction management is a breeze and the wet roads quickly fade to the back of my mind. Between the flapper valve and the addition of those shower injectors, Kawasaki has managed to flatten the torque curve, creating a nice and linear power delivery, that pulls very hard through the midrange and then screams into the stratosphere. The changes are quite noticeable, though not what you would call "dramatic", thanks to the linear manner in which the torque is metered out. After a few corners, it is immediately apparent that the shift quality and drive lash have been improved upon over last year's model and the new slipper clutch works like a charm. I would rate the shift quality as outstanding, very smooth and with a minimum of lash, slop or pedal travel. Of course it's no VFR, but this is one highly refined supersport.
The day's street ride, has us following a pre-determined route to various photo points and I enjoy the scenic views, as I cruise along between 50-260Kmh, depending on surface conditions and weather or not there is another vehicle within three miles of me. Spain is different indeed. After a few photos, I need to make-up some time on the rest of the group, so I find myself hustling through a nice set of twisty pass roads, where the conditions vary from soaking wet to sunny and dry, depending on what side of the mountain you are on. The stakes are high enough to make me a bit nervous, but the bike is happy to oblige whatever my ego or cowardice decide to dish-out. In these conditions, there are three things in particular that I appreciate about the '05 bike. 1.) The new Radial-Pump Master Cylinder offers very good feel and allows me to meter braking forces with the same accuracy that the fuel injection delivers acceleration. 2.) Kawasaki relaxed the steering geometry from 24.5° to 25° and extended the trail from 95mm to 104mm, so that the bike has less of a tendency to headshake over rough pavement, than last year's bike. 3.) When they switched from Kayaba to Showa suspension components, they specified softer damping for the forks and shock, so the ride is smoother and less prone to chatter.
Now that I've been in the saddle for a while, I'm starting to appreciate the flatter seat, and more relaxed riding position. Although the pegs are in the usual (high) place, I find that overall comfort is excellent for a supersport bike. To be fair, I didn't spend any time droning down a freeway or trolling through traffic, so a thorough evaluation of the bike's comfort level will have to wait for a stateside test. However, I do think it's safe to say that the new ZX-6R is at least as comfortable as any other supersport that I've ridden.
600 Class "Streetbike" Score: A
After our street ride, we met back at the Circuito de Almeria, for a short (wet) track session. Since we didn't have any full-wet race tires, conditions dictated that we keep the speeds moderate. Once again, the supple suspension, liner power delivery and predictable brakes kept the drama to a minimum. Though we didn't really do much hot lapping, I rode enough to gain an appreciation of the 6R's ability to be placed accurately on the chosen line and its predictable nature when ridden with a bit of wheelspin (wheee!). At the end of the day, we returned to the Hotel and cleaned up for an oddly fish-centric dinner, punctuated with the rude comments and off-color jokes that can only be told by a bunch of drunk & jetlagged motojournalists. I think I remember belching a tequila flavored prayer into my pillow before I lost conciousness.... It went something like this: "Please lord, let the track be clean and dry tomorrow, cause I think velocity is an excellent hangover cure."
'03 ZX-6RR
http://www.stancourseymemorial.org
ZX6RRNewbie is offline   Reply With Quote
Old 12-17-2004   #2 (permalink)
ZX6RRNewbie
Sit speling cheker
Talking
Day 2 - The Track
As luck would have it, we arrived back at Almeria with the distant mountain's snow-capped peaks clearly visible beneath sunny skies.
This was shaping up to be a great day. For the morning's sessions, we would be riding on the stock Bridgestone BT-014 OEM street tires, followed by a post-lunch switch to Bridgestone DOT race tires. I liked the 014s on the street, due to their good wet grip and neutral steering. They continued to impress on the racetrack, with impressive dry grip and good consistency. However, it was the race compound tires that really got me excited about the ZX-6R's new engine. You see, the street tires caused me to be a bit restrained with the loud handle and once we switched to race rubber, I was more inclined to probe the new bike's limits.
Those limits are lofty indeed. The new engine's power is very much like a GSX-R 750 and with the ZX-6R's light weight and nimble handling, the acceleration off of corners is highly entertaining. When hard on the gas on race tires, the bike wants to wheelie through the rapid right-left transition between turns one and two. Those wheelies are caused not just by abundance of power, but also by the fact that I'm able to dial-in exactly the amount of power that the tire can handle through those transitions. It seems that when an engine is this manageable, you find yourself using more of what it has to offer.
Unfortunately, though the brakes offer excellent power and feel, the new radial master cylinder is mounted so that it comes into contact with the fork leg and prevents the brake lever from being rotated-down far enough to reach a natural/comfortable hand position. According to an un-named Kawasaki tech, this problem made it to production because most of the Japanese development riders are fairly short, so their wrists approach the grips & levers at a flatter angle. However, like most American riders, my wrists approach from above and rotating my hand up to reach the brake lever is both uncomfortable and time consuming. My only other nit-pick is with hard (racing) up-shifts near redline on the straights. These shifts are often met with the slightest of wiggles from the bars (see videos) and I get the distinct impression that you wouldn't want to try them one-handed. Don't get me wrong, the bike is much less likely to shake its head than the '03-'04 ZX-6Rs were, but it still lets you know that there isn't a steering damper working under that fairing. There you have it, you've just read my only complaints with the 2005 Kawasaki ZX-6R.
Get the picture? This thing rocks! The powerful brakes and excellent slipper clutch allow smooth corner entries, with deep trail braking and drama-free downshifts, lap-after-lap. Mid corner stability is better than the previous ZX-6R, but not quite as rock-solid as a CBR 600RR. However, mid-corner line changes and clumsy shifting of my considerable body weight didn't phase the 6R. Another thing that impresses me, is that the ZX-6R's suspension and tire feedback is nice and clear. This comes in handy not only for changing surface conditions on the street, but also for aspiring racers who are trying to select tires and sort suspension settings. Even though the Kawasaki's feedback is a useful diagnostic tool, aside from rotating the levers as far-down as they would allow, the only things I needed to change throughout the entire day were gas and tires.
600 Class "Trackbike" Score: A+
Conclusion:
What we have here is a weapon. It's light, nimble and silly fast, while being refined, consistent and fairly comfortable. If you ride a lot of twisties and/or terrorize track days, this bike needs to be at or near the very top of your shopping list. I have no idea how they do this year-after-year, but the Japanese have redefined what it means to have open-class power in a middleweight package. It used to be just marketing hype, it's now reality."
'03 ZX-6RR
Old 12-17-2004   #3 (permalink)
michaelvZX6RR
Turtle Wax Taster
michaelvZX6RR's Avatar
I want one!
Oh wait, I already have one! Or, pretty **** close anyway...
(Several of the '05 6R changes came from the '04 6RR, especially in the engine.)
'04 Ninja ZX6RR (track bike)
'04 ZZR 1200 (touring bike)
michaelvZX6RR is offline   Reply With Quote
Old 12-17-2004   #4 (permalink)
ZX6RRNewbie
Sit speling cheker
I'm green with envy!!!!!!
I want one too!!
'03 ZX-6RR
Old 05-04-2005   #5 (permalink)
davidlust
Send a message via MSN to davidlust Send a message via Yahoo to davidlust
I just got one, oh my god, what an amazing ride. cheating a little on the breakin period just cause i got the itch, and cant wait to let it open up and suck in the entire atmosphere!!!!!
davidlust is offline   Reply With Quote
