Old 09-20-2007   #1 (permalink)
baileyjn
Third Gear And Gaining
Default Wheel Removal
I have both front wheel and rear wheel stands to get both wheels of my bike off the ground. I was planning on taking both wheels off at the same time to get my pirellis put on quicker after work tomorrow. I mentioned that to my dad on the phone and he thought it was a bad idea because it is unstable. Does anyone have any recommendations? Anyone have any bad stories? What do most of you do?
Jon Bailey
2007 Black CBR 600RR
Sliders
Double Bubble
Pirelli DCIIIs
Strobing Flushmounts
baileyjn is offline   Reply With Quote
Old 09-20-2007   #2 (permalink)
bennice
RIP Deron
bennice's Avatar
I did exactly what you are planning to do. Rear stand first, front stand last, and the reverse when it's all done. While my wheels were off I also took off my fairings and gas tank and dropped in a new cam chain tensioner, cleaned my air filter, cleaned the chain, and anything else I could think of that was needed. I didn't have any stability problems that I noticed - most importantly my bike stayed put.
I've heard it's best if you have a triple tree stand in front, but I've never used one so I don't know for sure. I think that as long as you have decent stands, you've done your part to lift the bike correctly, and nobody does anything stupid to your bike while it's sitting on the stands, you should be okay.
I've got Pit bull for the rear and T-rex for the front. Truth be told, I'd rather have Pit Bull in front, but the T-rex worked fine.
bennice is offline   Reply With Quote
Old 09-20-2007   #3 (permalink)
TVoyagerXII
Wild and wooly
TVoyagerXII's Avatar
Send a message via Yahoo to TVoyagerXII
I have a small hydraulic bike lift from Harbor Freight, but I did each wheel one at a time. I felt like the lift was stable enough, but I couldn't stand the thought of the bike maybe falling over.
It only took a me about 3 hours and on my Boulevard I had to drop the exhaust pipes. I broke them down put in new tubes (that was the real hard part) and I think it would have been faster if it had not been my first time and those stupid 90 degree valve stems.
CrenshawCountyRiders Page
TVoyagerXII is offline   Reply With Quote
Old 09-20-2007   #4 (permalink)
xeon
Wants better weather!
xeon's Avatar
What kind of stands do you have? I've put mine up on both stands several times and they are fine. I have T-Rex stands, which are on par with Pitt Bull which are pretty good stands unlike say Handystands. I find the front stand made by Handystands to not be very confidence inspiring. If you have good stands toss it up, pull the wheels and get on with it... that is my opinion.
Black '06 Ninja 250R
Red-n-Silver '99 YZF600R
xeon is offline   Reply With Quote
Old 09-21-2007   #5 (permalink)
WeBeToyz
Make Mine Pure BHP
WeBeToyz's Avatar
Send a message via AIM to WeBeToyz Send a message via MSN to WeBeToyz Send a message via Yahoo to WeBeToyz
I use Pit Bull stands front & rear. As mentioned, lift rear & then front and reversal when setting down.
My front stand is the Forklift model, but I have gotten the converter for it so it lifts the bike by the steering stem. While the stand was stable w/o the converter, I found I liked the extra stability when lifting via steering stem especially if the bike was going to up for a couple of days. The converter is convenient when pulling forks, etc.
Bryan
'94 ZX-7
'06 Dragon Run
WeBeToyz is offline   Reply With Quote
Old 09-21-2007   #6 (permalink)
luvda6R
luvda6R's Avatar
I had a bad incident with my stands, which was pretty much due to my inattention. I was doing the same thing as you, had never done it before so had my bike up on stands for about 3 days while I got the new tires put on, and did a lot of head scratching, etc. I have the Handy Stand universal setup.
Handy Industries Online Store
Well, long story short, I finally had my tires on and was about 15 minutes from taking the bike off the stands. With all the wrenching and knocking around I did on the bike, it had tipped forward slightly on the rear stand over the few days, and finally completely rolled forward off the stand. Luckily the front stand kept it upright until I could get a friend to help get it on the ground. If I didn't have it on the front stand also, it probably would have tipped over. Also would have sucked if the tires were not on yet.
So, maybe it wasn't a "long story short", but I'd say I would have been worse off if I only had it on the rear stand at that time. Also, just keep an eye out for that "rolling forward or backward" as you work.
'05 ZX-6R
Two Bros CF V.A.L.E.
Zero Gravity Double Bubble
luvda6R is offline   Reply With Quote
Old 09-21-2007   #7 (permalink)
bennice
RIP Deron
bennice's Avatar
One thing that I do like a lot about the T-rex stand I have is the rubber feet on the bottom when the bike is lifted. It helps prevent the bike from rolling forward on the stand's wheels. I know with my Pit Bull, I can push the bike back and forth a bit if only using the rear stand.
The only negative I've come across with the T-Rex really isn't that big a deal. It's that when assembled they aren't shaped as precisely as the Pit bull stands (which are one piece), so one side may not be perfectly symmetrical with the other. But mine is close enough that it made no difference at all.
Old 09-22-2007   #8 (permalink)
xeon
xeon's Avatar
Noted that myself, you have to loosen the bolts up a bit and realign it then re tighten. I've had to realign mine once after some pretty regular use. I noted one of the rear wheels was off the ground, indicative of it not being square. It wasn't really an issue, but I tend to be a perfectionist.
Old 09-22-2007   #9 (permalink)
baileyjn
I ended up putting it up on both stands and taking both wheels off. It was not a problem. OMFG Pirellis!
Jon Bailey
Sliders
Double Bubble
Pirelli DCIIIs
rear wheel removal (flat) genegoss The Mechanics Corner 3 05-14-2007 07:36 PM
Rear wheel removal genegoss Projects and "How To" Write Ups 2 05-13-2007 11:36 PM
ZX11 Front Wheel Removal gooch Kawasaki Streetbikes/Sportbikes 7 10-11-2006 05:32 PM
Front wheel removal (800a) mumbles Kawasaki Cruisers 10 09-13-2005 04:14 AM
KZ650 rear wheel removal Britcheflee Main Lobby 1 09-08-2004 02:47 PM
