LinkBack | Thread Tools |
Made It To Second Gear
Hey guys I need some major help....
Yesterday i was warming my bike up ( 2006 ninja 636) and about 30 seconds into warming it up it stalled out in neutral. I tried to fire it back up and it will not fire but it will make the noise like it wants to. about 2 hours before hand i rode my bike in the rain for about 3 minutes but that is it. I checked the airfilter for water damage and i checked under the take and made sure the tps and other harnesses and htey were. any ideas??? i really appreciate the help! and btw ive never ever had a problem with my biek starting ever so im baffeled at the situation |
#5 (permalink) |
Vintage bike addict
My 82 750 has got something in the low speed jets and was acting the same way. Happened on my way to work. Try starting it with the throttle open a bit. If it'll start you may want to give your carbs a once over cleaning.
82 KZ750LTD, 84 Virago 700, 85 Vulcan 700.78 KZ750 twin,82 KZ650, 77 KZ650, 75 CB200T,Vince |
#7 (permalink) |
Vintage bike addict
Have you checked to see if you have good spark? I'm not at all familiar with the fuel injected bikes. Is it an electronic fuel injection system? If so have you checked your fuses? Lucky me a little carb cleaning and I'm back in business. If it's not spark or fuse problems you may have clogged injectors. Check the easy stuff first. If you have a book and the tools to check the injectors I'd check there after verifying you've good spark and the injectors and fuel pump have power and function.
#10 (permalink) |
Vintage bike addict
I hope you're lucky and find it's just a fuse. Have you checked the plugs have spark and are not fouled yet? That was the first suggestion and it is the logical first check to make.
#11 (permalink) | |
Honest it wern't me !!
![]() ![]() Join Date: Nov 2006
So when you turn the Ignition on and hit the start button the motor does not turn over, Pressing the start button does nothing....Yes ? Do you here the Fuel (Gas) Pump working when you switch the ignition on ? (Whinning Noise) If the Motor does turn over when you hit the start button is the FI light flashing as it's turning over ?
END OF MESSAGE ! |
| Ways to drop your motorcycle | Freakinout | Main Lobby | 174 | 10-14-2009 02:58 AM |
| I can fix my own bike | GreenJello | What I learned today | 9 | 11-15-2006 01:59 PM |
| FS: 1996 ZX9r plus additional ZX9 parts bike | Inten_Z | Streetbikes Buy/Sell/Trade | 0 | 11-25-2005 12:36 AM |
| Need help with crazy bike problem. | marsolais | Kawasaki Streetbikes/Sportbikes | 25 | 10-15-2005 09:02 AM |
