Well, on top...on top of the handlebar? The clutch fluid is the one on the left, and the brake fluid is the one on the right handlebar...if you are refering to something else, then I recomend you do a google search for the manual on your bike...year and model have to be correct most likely, then just look int he manuel, it'll tell you everything you need to know.or go to the library and chedk out a manual on how to take your bike apart and put it back together from scratch and that will have your answer
