Old 11-19-2007   #21 (permalink)
Alizard
The Cruising Gunsmith
Originally Posted by southjersey636 View Post
I had my gasket off 3 times to check my valves and it didnt start leaking till the 3rd time I installed it again. Just stick with OEM and if you do have to do any valve checks or adjustments you can most likely reuse it without any problems.
Yeah, I used to get about three R+R's out of a factory gasket. If it's just leaking a bit you can apply some RTV to seal it up and get one more go out of it.
I just can't get up for spending $80 for a gasket I can make for $3. I found a place selling aftermarket ones for $15, but they are one off use as well.
Alizard is offline   Reply With Quote
valve cover aftermath4788 The Mechanics Corner 1 11-12-2007 01:54 AM
valve cover leak cyclenut Kawasaki Cruisers 1 08-29-2006 10:51 PM
Valve cover removal part II zedx0011 The Mechanics Corner 4 06-01-2006 06:10 PM
Can I use Silicone Joint instead of original Gasket in the Clutch Cover?? runingwild The Mechanics Corner 6 03-24-2005 09:40 PM
