'97 Ninja EX500 Rider
I am about to change my front fork seals because they are leaking, and I can't find anywhere that tells me what kind of front fork oil i need
I would like to know what kind of front fork oil my '97 EX500 uses and about how much i need to put in it.... Thx and also any suggestions will be appreciated...THX |
12 yrs old at heart!
I don't know about amount, but the service guys at your local should should be able to tell you, or a good service manual. As for type, they do make fork oil and probably a 10 weight will work. that's what I put in my vulcan. again, probably the service guys would be best to recommend.
Maybe someone on here has better specifics for you.
Ol' Panhead Member of Bonnie's Hot MotoGuzzi Club http://www.bikepics.com/members/ncdave |
#5 (permalink) |
zx-11/250r
That bike probably has motor oil in it from factory, mine did as well and I put new seals in it and put fork oil in it instead and it didnt make that much of a difference but the ride was a bit smoother than before. You could get away with using either or as long as it is the proper weight
| Vulcan 900 Oil Change with pics | 900classic | Projects and "How To" Write Ups | 13 | 4 Weeks Ago 08:19 PM |
| Fork Oil | MSGAmling | FAQ'S | 1 | 12-04-2007 06:57 PM |
| What Holds the Valve Stem Oil Seal? | bountyhunter | The Mechanics Corner | 4 | 09-17-2007 01:26 PM |
| Removing Engine Cover: Kick Shaft Oil Seal | double stroke | Kawasaki Motocross and Offroad | 4 | 02-25-2006 12:33 AM |
| How to change oil on 99 ninja 500R | mixery2k | The Mechanics Corner | 8 | 01-22-2004 06:49 PM |
