96 GPZ no third gear or above
+ Reply to Thread
Results 1 to 9 of 9
Thread: 96 GPZ no third gear or above
  1. #1
    Join Date
    Feb 2004
    Posts
    5
    Default 96 GPZ no third gear or above
    I have a 96 gpz with 18k miles, I have only owned the bike for 4 days, I just did a ton of service on it. The first ride went fine, but now it won't shift pass second. It goes from 1 to n to 2 fine, then it will kind of get between gears if you try and go to third, there is no excessive noise at all please help me....
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Refrigerator Magnet Test Engineer BTK Expert
    Join Date
    Jan 2004
    Location
    St. Paul, Minnesnowta
    Posts
    456
    You know we're going to ask this, so here goes ...
    What service did you do -- especially anything related to the transmission or shift lever? Did you change the front sprocket? Did you go any deeper? And are you sure the higher gears worked before the service?
    Curt
    red 2001 Kawasai Ninja 250R
    http://www.curtmorales.com/Ninja (note capitalization)
  4. #3
    Join Date
    Feb 2004
    Posts
    5
    Default thanks for the reply
    I changed both sprockets and the chain, new tires wheel bearings and all new fluids. Specificly the oil I used 10-40 synthetic blend motorcycle oil. I didn't ride the bike before that work, I only rode it after. And all gears where working. well up thru 5th was working, I didn't try 6th. The very next day nothing was change an it won't go past 2nd....
  5. #4
    Cruising In Fourth Gear BTK Intermediate
    Join Date
    Jan 2004
    Location
    Michigan
    Posts
    209
    People have had problems with clutch slippage when they use full synthetic oil. Could be the problem?
  6. #5
    Join Date
    Feb 2004
    Posts
    5
    Thanks for the reply, the cluch is not slipping its actually not going into gear, as if the bike only had 2 speeds. It takes no noise and is perfectly ridable untill you try and shift it into 3rd. I read something about a set of bearings that use centrifugal force to keep the bike from going in to gear when its going to slow. does anyone know about this. Tonight I was thinking of taking it closer to redline, and trying to put it in gear......
    Thanks again for the reply, BTW this is only my second street bike so I am no a very experienced rider, at least not on the street.
  7. #6
    Join Date
    Feb 2004
    Posts
    5
    Default better description of the symptoms
    I can now get it to go past 2. it seems to go into 3rd, and then as I let out the cluch it stays in third untill I apply power then it slips back into 2nd.. I can get it to go into 4 5 and 6 and it seems normal. When trying to go into 3 sometimes it grinds when letting out the cluch like its in between gears. It does somewhat better at higher speeds. Please help, I really love this bike and I want to keep it...
    thanks
  8. #7
    Join Date
    Jan 2004
    Location
    Michigan
    Posts
    209
    sounds like shifting forks to me
  9. #8
    Join Date
    Feb 2004
    Posts
    5
    Default forks
    how hard is that to fix, anyone know where to get a manual for this thing?
  10. #9
    Join Date
    Jan 2004
    Location
    Michigan
    Posts
    209
    You can get either a Haynes or Chymers (sp). Try ebay first, I got a hardcover Haynes for $25 including shipping. If not ebay, I think a local dealer would carry one.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Sythetic Gear Oil ?
    By Plato in forum The Mechanics Corner
    Last Post: 03-06-2006, 08:21 PM
  2. 94 vulcan 750 no second gear
    By larrycavan in forum The Mechanics Corner
    Last Post: 02-05-2006, 08:21 AM
  3. stuck in gear and shifting problems
    By harpgregory in forum Main Lobby
    Last Post: 01-24-2006, 07:56 PM
  4. 2001 ZX-6R J2 gear lever/clutch problem?
    By MJ in forum The Mechanics Corner
    Last Post: 11-19-2004, 12:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
