Old 02-09-2008   #1 (permalink)
quiXilver
Wannabe
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via MSN to quiXilver Send a message via Yahoo to quiXilver
Default Z1000 Low RPM Sputter?
My friend just bought an '03 Z1000 and when you blip the throttle from idle, it sputters and hesitates untill it gets past 2k rpm. Same thing happens if you are in a low gear going around a corner at low rpm and you try to give it throttle it just bucks and hesistates really bad untill you get past a certain rpm. Once it gets past that it goes like hell and runs perfect.
Anyone have an idea on what could be causing this? The bike has only 4,500 miles on it and it great condition otherwise. Thanks for the help!
quiXilver is offline   Reply With Quote
Old 02-09-2008   #2 (permalink)
eidian
Black is faster, right?
eidian's Avatar
Any mods to the bike...like an aftermarket exhaust? An '03 with only 4,500 miles? Great find!...but how long has it been sitting?
'07 black Z1000: Power Bronze/Projekt D/EYI Designs/Leo Vince/Puig/Galfer/T1Concepts
eidian is offline   Reply With Quote
Old 02-09-2008   #3 (permalink)
quiXilver
Wannabe
It was also only $5,100 cash out the door. Completely stock. It's most likely been sitting for a while...
Old 02-09-2008   #4 (permalink)
CKRider
gonna get a 10
CKRider's Avatar
Send a message via AIM to CKRider
I would turn my attention to the spark plugs for starters...
00 Ninja 250R -Kawi-Green!!
TheEvolutionofDance
myspace
facebook
CKRider is offline   Reply With Quote
Old 02-11-2008   #5 (permalink)
quiXilver
Wannabe
Yea, I think that's what he's going to do. Too bad I've heard it's like a 2 hr job. Take off the thermostat or drop the motor lol.
Old 02-12-2008   #6 (permalink)
MR.S7
Way Too Much Free Time
MR.S7's Avatar
Send a message via ICQ to MR.S7 Send a message via Yahoo to MR.S7
i might go for injection checking and/or cdi.
most probably injection..
a good ultrasound cleaning of inyector will fix it.
MR.S7 is offline   Reply With Quote
Old 02-12-2008   #7 (permalink)
daemon
devil in god's country
daemon's Avatar
i've yet to even attempt to do my own.
but i will agree that the bike may have been sitting for awhile and the problem will most likely be in the plugs or F.I.
if your friend has not started the mod process...keep him away from the guys on riderforums.
the bike will never look the same again.
I KNOW
my_vids
litany_of_fear
daemon is offline   Reply With Quote
Old 02-12-2008   #8 (permalink)
quiXilver
Wannabe
I KNOW
I'll let him know, thanks.
What's CDI btw?
Old 02-12-2008   #9 (permalink)
eidian
eidian's Avatar
What's CDI btw?
CDI: Capacitor Discharge Ignition. You can become an "expert" like the rest of us!
Capacitor discharge ignition - Wikipedia, the free encyclopedia
The has so few miles that I would be suprised if it was the CDI, they tend to be pretty much bullet-proof. Clogged fuel injector maybe?
Old 02-12-2008   #10 (permalink)
quiXilver
Wannabe
Ok, I'll let him know.
We put FI Cleaner through it...to no avail. Any other way to check and see if the injector is clogged?
Is there anyway to adjust the air/fuel ratio or intake? You can smell gas real bad when it's idling. Like it's running really rich...
Old 02-13-2008   #11 (permalink)
GREENISBEST
Honest it wern't me !!
GREENISBEST's Avatar
First off you can get numbers 2 & 3 spark plugs out by loosening the stat housing and unplugging the associated connectors around it saves dropping the coolant, It's a jiggle but can be done.
I've found a surprising amount of low mileage Z1000's that have the Throttle bodies go out of Synchronization causing them to stumble at low revs.
I would check to make sure you have no air leaks which would cause a lean mixture that the ECU would compensate for by adding extra fuel.
Also check (Or get checked) the Throttle position sensor output voltage as this will cause your symptoms if it's out of range..
Poor Fuel can also cause problems, On occasion you can pick up some Water at the Pumps which is for the most part non combustable
END OF MESSAGE !
GREENISBEST is offline   Reply With Quote
Old 02-14-2008   #12 (permalink)
quiXilver
Wannabe
Hey guys, we managed to get the spark plugs out by unbolting the tank, maneuvering it around accordingly, and using the little bend tool that came with the bike. It's runs 110% better now, it's all fixed! Thanks for the suggestions!
Fastest you have riden, and on what (make, model, year)? 07Z1K Kawasaki Streetbikes/Sportbikes 829 2 Days Ago 03:06 PM
low RPM hesitation ZZR1200 psdejong The Mechanics Corner 4 11-23-2007 07:13 AM
2000 Vulcan 800 Classic > low voltage when high RPM. JohnG1975 Kawasaki Cruisers 6 11-13-2007 06:21 PM
low rpm prob? Trubattleax Kawasaki Streetbikes/Sportbikes 6 05-01-2007 05:13 AM
low rpm miss kid The Mechanics Corner 3 07-05-2006 03:48 PM
