Old 03-05-2008   #1 (permalink)
Nickoli55
Asphalt Junkie
Nickoli55's Avatar
Default Removing front wheel on 05 636
I need to get my front tire replaced and I was quoted a price of 52.00 if they remove the wheel and 26.00 if bring the wheel in only. I've searched the forums and found a couple hits on removing the wheel but I'm still not sure what the proper procedure is.
When I remove the brake calipers do I just remove the 2 hex bolts located on the top caliper and let them hang down? Also, I believe axel is threaded so which side do I loosen the hex bolts and then the axel? Any help is greatly appreciated.
Nickoli55 is offline   Reply With Quote
Old 03-05-2008   #2 (permalink)
JTpaintball70
has a surgically implanted keyboard
JTpaintball70's Avatar
Send a message via AIM to JTpaintball70 Send a message via MSN to JTpaintball70 Send a message via Yahoo to JTpaintball70
You actually shouldn't need to remove the calipers.
I know when I did it on an 03/04 636 front end all I had to do was take a 17mm hex and unscrew the axle and then undo the pinch bolts on the bottom
Nathan
My Photobucket
2007 ZX-6R
2007 Ninja 650R aka Shion - STOLEN 2-4-08
2001 Jeep TJ
NM EMT-Basic
JTpaintball70 is offline   Reply With Quote
Old 03-05-2008   #3 (permalink)
sebastian1000
Needs A Real Job
It should be pretty easy....just undo the main axle nut and then the pinch-bolt...after that you MIGHT have to undo one of the calipers to get the rim out easier...but that is only another two bolts so no biggie.
sebastian1000 is offline   Reply With Quote
Old 03-05-2008   #4 (permalink)
xeon
Wants better weather!
xeon's Avatar
I've never taken a front wheel off of that bike, but you can certainly do it. Do you have bike stands? On some bikes you do have to take one or both of the calipers off to enable you to clear the rim. In general it is two bolts that mount to the fork. Taking the caliper off is as simple as taking those two bolts out and getting it out the way. I like to wrap them in a rag because they can bang into your rim if you aren't careful.
Data you should have are the torque values for the front axle, caliper mounting bolts and pinch bolt/s. Do you have the factory service manual? They tend to be worth their weight in gold especially if you plan to wrench on your bike much.
Black '06 Ninja 250R
Red-n-Silver '99 YZF600R
xeon is offline   Reply With Quote
Old 03-05-2008   #5 (permalink)
Nickoli55
Asphalt Junkie
Nickoli55's Avatar
Yes I do have stands both front and back so I'm all set there. Now you're scaring me with torque value questions as I don't have the appropriate tools to measure that. Hmmm what to do...
Old 03-05-2008   #6 (permalink)
Nickoli55
Asphalt Junkie
Nickoli55's Avatar
I was able to find the service manual for my bike. However what should I use to loosen and remove the axle itself? Can you buy that tool somewhere or is there a workaround utilizing another tool? TIA
Old 03-05-2008   #7 (permalink)
alec
Lets RIDE!
alec's Avatar
You need a hex tool. I bought mine at the dealership...$35 what a rip off...go to like autozone or whatever and get it. Torque wrench can be found anywhere for $20-$100. I bought mine at Canadian tire for $20, nice ones are $100.
Should be torqued to 94ft-lbs.
2006 zx6r Special Edition
2007 Triumph Daytona 675
alec is offline   Reply With Quote
Old 03-05-2008   #8 (permalink)
Nickoli55
Asphalt Junkie
Nickoli55's Avatar
Thanks man for the info. So would I need 2 hex tools as I would need to hold the opposite side or do the fork screws hold the nut tight?
Old 03-05-2008   #9 (permalink)
Nickoli55
Asphalt Junkie
Nickoli55's Avatar
Also, what size hex tool is needed. You'd think the service manual would have this info.
Old 03-05-2008   #10 (permalink)
xeon
xeon's Avatar
When you say hex, I'm not sure what you are speaking about specifically... could be the pinch bolt or the axle. You can get a set of allen head sockets for ~$10 @ Wal-Mart. If you're going to be working on your bike, they will come in handy. You can use a spark plug socket on the axle nut or they do sell special sockets for front axles. You flip the spark plug socket around and pull out the rubber guts. Basically you use the socket backwards.
Not sure about the size, but I seem to have been part of a similar discussion here over the last year. Maybe you can dig it up?
Old 03-05-2008   #11 (permalink)
alec
Lets RIDE!
alec's Avatar
You'll need the 24mm. Just 1 will do. The other side use a pliers to hold the axle from spinning.
Old 03-07-2008   #12 (permalink)
Nickoli55
Asphalt Junkie
Nickoli55's Avatar
Thanks man, I have the part on order and hopefully will be here in the next couple days as it's cutting into my riding time Thanks again for the info and the help!
Old 03-07-2008   #13 (permalink)
WeBeToyz
Make Mine Pure BHP
WeBeToyz's Avatar
Send a message via AIM to WeBeToyz Send a message via MSN to WeBeToyz Send a message via Yahoo to WeBeToyz
Lot of auto chain stores have tool loaner programs - so you could basically rent a torque wrench if need be.
Bryan
'94 ZX-7
'06 Dragon Run
WeBeToyz is offline   Reply With Quote
Old 03-07-2008   #14 (permalink)
Nickoli55
Asphalt Junkie
Nickoli55's Avatar
Yes, the guy at Autozone told me that which is nice as I don't have it. Thanks for the info man.
Front brakes, how much resistance should the wheel have? rd3500 The Mechanics Corner 4 10-23-2007 01:02 PM
02 636 Wheel? bad4door Kawasaki Streetbikes/Sportbikes 2 07-13-2007 10:50 PM
Front wheel Tightness vegita182 Kawasaki Streetbikes/Sportbikes 2 09-12-2006 07:55 PM
Looking for a 800a front wheel chopperdan6212 Accessory Swap Meet 0 12-25-2005 07:37 PM
Removing Front Whell, Need help Justin187 Kawasaki Streetbikes/Sportbikes 1 12-22-2005 03:18 PM
