Old 03-12-2008   #1 (permalink)
ndoerr
Default 1982 Kawasaki 1100
i have a 1982 kawasaki 1100 spectre, and was wondering what years interchange for engine and electrical parts, i have a stator and windings going out and possibly the voltage regulator. an easy way to check if the stator and windings are good is to start and run the bike, then disconnect the battery and see if it stays running, right?? any help would be appreciated
ndoerr is offline   Reply With Quote
Old 03-12-2008   #2 (permalink)
MR.S7
Way Too Much Free Time
MR.S7's Avatar
Send a message via ICQ to MR.S7 Send a message via Yahoo to MR.S7
No, you shouldnt do that Ever, might damage your CDI.
The best unique way is to check the battery charge , must be 12v +- when off, and when bike is running must increase 13.5, 14 v, if its not increasing your regulator is wrong, if it nincrease too much your rectidier is wrong.
check also the spark is working ok in each cilinder.
best luck
MR.S7 is offline   Reply With Quote
Kawasaki can make you sick. Uncle Bob Off Topic 24 01-15-2009 03:00 PM
Kawasaki 250cc Rants&Raves Specialist ZX-2R Main Lobby 41 10-12-2007 06:06 PM
1982 Kaw 1100 Problems ndoerr Vintage Motorcyle Info 6 08-04-2007 03:06 AM
***1600/1500 Classic/Nomad/Meanstreak/Maurader - Photo Contest*** Spok Kawasaki Cruisers 170 12-12-2006 06:12 PM
1982 Kawasaki KZ750N Spectre BassProRuss The Mechanics Corner 2 09-09-2006 08:50 AM
