#2 (permalink) | |
Uncle Bob's Love Child
What do you mean by "high octane"? If you're talking about general pump gas, find a gas-station. If you're looking for like 110 leaded or race-gas, go hit up a small airport or race track. I get my 110 leaded from the local airport. |
Ludicrous Speed...GO!
Ther eis a product called "Octane Booster" that you can add to your gas. I'm not sure how well it works though.
Visit Crue's Control 2004 Vulcan 2000 HK 3" Big Straights, TFI, Thunder Teardrop custom |
#5 (permalink) |
Holy ****? Octane booster?? Where have you guys been? Do you know what "octane" is?
That ****'s all snake-water. Don't put anything in your tank that's not fuel, or anything in the case that's not oil, or anything in the cooling system that's not distilled water/designated antifreeze. Ever. Seriously...octane booster? Yeah...and my girlfriend isn't pregnant because I splash her cooter with pepsi after every "use"... |
#6 (permalink) |
Further more...
Octane is a hydrocarbon chain (like propane (and propane accessories ), pentane, butane etc) that ignites at a higher temp than many other hydrocarbons. This means you can compress it (which heats it) more before it explodes. The octane rating is the percentage of octane that the gas is made of (the rest being pentane, hexane etc). This is useful if your engine has a high compression ratio, which provides more power (think of a spring- the more you compress it, the harder it pushes when you let it go). However, having more octane than neccessary gains nothing because it is not being compressed more (and won't produce any more power). Running higher octane will most likely not change much and just be a waste of money, but I guess it could even cause problems with unburned fuel in more extreme cases (don't use the 110octane race stuff ). So break out your manual and start reading. Unless you've altered the compression ratio, it will tell you what you should be using...use that, nothing else. |
#7 (permalink) |
Finally Got Into First Gear
Sorry man, your post above varies from absolute rubbish (the first paragraph), to quite correct (the rest).
There is NO "octane" (the hydrocarbon) added into modern fuel, much less being a percentage of... What is 104 octane then? That hydrocarbon simply gave it's name to the scale (of which there are many different scales and definitions). Below is a text dump from http://www.totalmotorcycle.com/downl...MuchOctane.htm which spells it out nicely. You are right however that the marketing people want you to think that more octane means more power - in the absence of other changes, it does not. More octane may allow you to run higher boost, more compression etc that make more power... EDIT: I have not used them myself - my bike is stock and my car does not detonate even when running nitrous, but I understand that those octane boosters work very well when you are attempting to control detonation in a modified engine. If you are adding it to get "more power", then rather just drink the post-coital Pepsi - you'll feel on top of the world... QUOTE: How Much Octane? - National Dragster When thinking of octane numbers, most automotive enthusiasts subscribe to "More's Law," which is: "If some's good, more's better." This is frequently the case high-octane race fuel for street legal drag racing cars. So, what is octane, why is it needed, and how can it help a street machine make an occasional great pass? The engines in many street-legal cars have been modified to improve performance. These modifications, which include after market headers, carb/intake manifold, camshaft, rockers, fuel-injection system, higher compression, and modified cylinder heads with big valves, can lead to increased horsepower as a result of getting a greater amount of the proper air/fuel mixture into the engine. When more of the proper air/fuel mixture is in the combustion chamber, the cylinder pressure is greater than it would be in an unmodified engine. This increased cylinder pressure needs more octane. If the octane number of the gasoline is not high enough, it can result in detonation and destruction of the engine. Even some unmodified engines may benefit from higher octane gasoline. As under-hood temperatures increase, the engine needs a higher octane gasoline. In a dry climate like much of the Southwest, the lower humidity also contributes to increased demand for octane. On a low-humidity, 100-degree day with the air conditioner on, an engine's octane appetite can increase by three to four numbers. The benefit to using a 100-octane gasoline in high-performance street engines goes beyond the octane number. The distillation curve of the gasoline defines the temperature at which various amounts of gasoline are evaporated. Gasoline must be in a vapor form to burn, so the more readily it vaporizes (within limits), the better it will work in your engine. This can be a performance benefit in some engines because of the ability of the gasoline to evaporate more readily, contributing to more complete burning, which in turn leads to greater efficiency and power. DEFINING OCTANE NUMBER What is octane? How can it help my engine? Two laboratory octane numbers determine the overall octane quality of a gasoline. Both numbers are determined in single-cylinder, variable-compression-ratio engines. The first is the research octane number (RON), where operating conditions are mild. This is the number that gas stations in the 1960s put on their advertising signs out in front, numbers that ranged from a little over 100 to as high as 104. If an engine is detonating (pinging) at part throttle, it usually needs more RON. The second laboratory octane number is also determined in a single-cylinder, variable-compression-ratio engine and is called motor octane number (MON). The MON test is conducted under more severe operating conditions (higher rpm and higher inlet temperature) than the RON test, and as a result, the number is lower. If an engine is detonating at wide-open throttle, a higher MON will usually satisfy it. The number shown on the black and yellow sticker on the service station gas pump is the average of the RON and MON, or antiknock index (AKI). If the sticker shows an AKI of 92, RON is typically between 96 and 97, and MON is typically between 87 and 88. The RON and MON can vary slightly but still must average a minimum of 92 to have a pump posting of 92. Higher octane unleaded fuels will have a greater difference between RON and MON. For instance, 76 Unleaded Racing Gasoline has a RON of 106 to 107 and a MON of 94 to 95, which gives an AKI of 100 to 102. Higher octane does not necessarily mean more power. If a racer's engine is detonating on 92 octane gasoline, using a higher-octane quality fuel is definitely a plus. If your engine is detonation-free on 92 octane gasoline, the benefit of using a higher octane product is limited to the distillation characteristics discussed earlier. OCTANE REQUIREMENT The octane requirement of an engine in a vehicle can be measured on a chassis dynamometer with a standard series of reference fuels. Racers are not expected to conduct these tests but must be able to recognize when they need a higher-octane number gasoline. Keep in mind that higher octane does not mean more power unless your engine is experiencing detonation. If racers are not sure if detonation exists, try a higher octane gasoline and see if their speeds and e.t.s. improve. If they do improve, probably the engine was experiencing detonation. CONTRIBUTING FACTORS Many factors significantly increase an engine's octane requirement. 'I'hey include a higher compression ratio, a bigger cylinder bore, leaner mixtures, higher coolant and intake-air temperatures, dry air (low humidity), higher barometric pressures, altitude closer to sea level, and more spark advance. Also, cast-iron heads need more octane than aluminum heads. WHAT IS DETONATION? The octane number of a gasoline is a measure of its resistance to detonation. Detonation occurs when the octane number is too low for the engine and its operating conditions. When the spark plug fires, the flame moves through the air/fuel mixture, burning it very rapidly. Detonation occurs if a portion of the unburned air/fuel mixture gets raised to a temperature and pressure it cannot tolerate and ignites before the flame front gets to it. Detonation causes the maximum pressure in the combustion chamber to be reached before the piston reaches top dead center and pushes down the piston before it has reaches the top of its travel. Much of the gasoline's energy is wasted in trying to move the piston up while the high-pressure gasses are trying to push it down. The extreme temperature and pressure developed can cause broken rings, rod-bearing damage, piston overheating, and erosion of the aluminum. Pistons sometimes end up with holes in their tops from the high temperatures and high pressures. KNOCK-SENSOR-EQUIPPED VEHICLES In the late 1970s, the automakers began using knock sensors on engines. When the knock sensor senses detonation, it sends a signal to the main computer, which retards the spark timing until detonation ceases. By the early- to mid-1990s, knock-sensor systems were becoming much more sophisticated and could be found on about 50 percent of all new cars and trucks. The number increases slightly each year. The best thing about a knock-sensor system is its ability to reduce or eliminate engine damage due to detonation. It can, however, cause spark-timing retard, which reduces horsepower and fuel economy. Still, the trade-off can save lots of money and is a good compromise. Detonation normally occurs in one or sometimes two cylinders unless a serious fuel-starvation problem exists. Most engine-management systems reduce the spark timing in all cylinders, although some reduce the timing in only the cylinder that is detonating. Using a gasoline high enough in octane to satisfy the engine under all types of conditions will ensure maximum performance from all cylinders. EXHAUST-VALVE-SEAT CONSIDERATIONS In the 1960s, all gasoline contained tetraethyl lead, which was an easy way to increase the octane number. The lead oxide from the burned tetraethyl lead left a coating on the exhaust valve seat that provided protection from wear. If racers are using an older engine that does not have hardened exhaust valve seats, they should use an after market lead substitute. If they are getting ready to do a valve job on that 1960s car, they should have hardened seats installed so they don't have to mess with additives. LEADED RACING GASOLINE Using leaded racing gasoline on the street is illegal. The user and the seller can both be fined up to $10,000 each. UNQUOTE
Time flies like an arrow. Fruit flies like a banana. Last edited by Brett : 02-09-2005 at 08:30 AM. |
