Old 06-22-2008   #1 (permalink)
ylwf3ve
Default 02 ZX6R hard to start
Just got my bike out of the shop. Got full 30K tune up and few repairs. I''ve found out that it has full Akroapovic(?) exhaust system and "jetted" for that pipe. What does the "jetted" mean?
Also, due to the exhaust/pipe being jetted, I have hard time starting it. The guy started it right away, but whenever I tried to start it it just turns and turns but no start. He said leave the choke closed since it''s closed unless it''s cold out. Any ideas on why it doesn''t want to start?
will the bike being that lean cause it hard to start? if so, I guess it''s not jetted.. just changed the spark plug to NGK ones hoping it will do the trick but it''s still the same.. backfired and then started.. turned it off and tried to start it and still nothing.. any thoughts?
ylwf3ve is offline   Reply With Quote
Old 06-22-2008   #2 (permalink)
evmo
Way Too Much Free Time
evmo's Avatar
Use the choke anyway, it should solve your problem. Once the motor is going gradually let the choke out. try to keep it under 3000rpms while its warming up.
'06 ZZR600
'84 FJ600 (SOLD)
evmo is offline   Reply With Quote
Old 06-22-2008   #3 (permalink)
jbsmd
nu2kawi
jbsmd's Avatar
Jetting usually refers to carburetor jets being changed. Does your bike have a hand choke? My FI bike does not, but my carb'd bike does.
07, Z1000
01, XVS1100LC Yam cust.
jbsmd is offline   Reply With Quote
Old 06-22-2008   #4 (permalink)
ylwf3ve
it does have a hand choke.. i'll try using the choke from now on.. if it's not jetted should i get it jetted?
Old 06-22-2008   #5 (permalink)
hawkpbt44
chokeing the bike should help
your carbs have fuel jets in them, so the guy installed
different jets and that is what jetted means.
the key question would be does this dude know what in
the hell he was doing when he (re jetted the bike)!
hawkpbt44 is offline   Reply With Quote
Zx6r Won't Start.... paintshine The Mechanics Corner 4 07-31-2007 10:08 PM
Vandalized ZX6R Won't Start lstoker The Mechanics Corner 13 07-08-2006 03:16 AM
Hard to start when cold... mpoertner The Mechanics Corner 3 03-03-2005 11:54 AM
1996 zx6R wont start rolonso Kawasaki Streetbikes/Sportbikes 0 11-15-2004 04:58 PM
'91 Ninja zx6r will not start, just backfires kaneda007 The Mechanics Corner 6 02-05-2004 07:45 PM
