Old 07-05-2008   #1 (permalink)
Nickoli55
Asphalt Junkie
Nickoli55's Avatar
Default 05 636 Brake problem
Greetings all! Not so good of a day for me as I backed my van into my bike in preparation to hook up our trailor to take the kids to a local bike track. The bike was hinged on the kickstated, front tire and the rear bumper of my van. I was able to pull the van up without the bike falling all the way over but the kick stand is shot. I have a new one on order. Now for the issue. After getting the bike up and half-way straightening the kickstand I noticed the front brakes weren't right. They were not grabbing at the same spot each time I engaged them. Also, I noticed they were not grabbing at all when I would test drive the bike down a local street.
Is this indicative of the brakes needing to be bled out? If so, is there a step step procedure one could provide to correct this? Any help is greatly appreciated. I wanted to try this first before taking it to the shop.
Nickoli55 is offline   Reply With Quote
Old 07-05-2008   #2 (permalink)
ervins
MOM Sept 2006
ervins's Avatar
Send a message via Yahoo to ervins
You sure nothing is bent? Forks? Rotors? I could not see how the brakes would not bite unless they are tweaked...Was there any brake fluid dripping or anything?
ervins is offline   Reply With Quote
Old 07-05-2008   #3 (permalink)
Nickoli55
Asphalt Junkie
Nickoli55's Avatar
No no fluids were dripping. I have a feeling the rotor is hosed. I'm going to take it to my local shop where I will undoubtedly get bent over but atleast I'll get it fixed right. Thanks for the help.
brake caliper putting back together problem goldwing55706 Vintage Motorcyle Info 14 01-03-2008 08:26 AM
lil problem with my 636 and coolant... Army_of_Ninja The Mechanics Corner 4 07-04-2007 11:09 AM
06 636 taillight problem rwalton1129 Kawasaki Streetbikes/Sportbikes 9 05-20-2007 04:33 PM
Bike-a-holics quick and easy brake bleeding guide Spok Projects and "How To" Write Ups 6 03-02-2007 09:43 PM
bleeding... kscubb Kawasaki Cruisers 5 02-27-2007 02:37 PM
