LinkBack | Thread Tools |
I'm not the most technically knowledgable person with bikes so please bear with me.
I have an old (89) ex500, that will no longer start. About 2 weeks ago I tried to start it and I just got the clicking noise, so I recharged the battery and after a few minutes was able to get it to start, I ran it for about 10 mins then parked it. I went out of town and yesterday (2 weeks later) tried to start it again, only this time I didn't even get the clicking noise, just a static noise comming from the direction of the junction box. So I recharged the battery over night (trickle charge) and installed it today. Now I'm not getting any noise at all. The lights, turn signals, horns ect work, but nothing when I try to start it. I've check the fuses in the junction box and the starter relay and they are fine. I just don't know what to do next, please help me I am really stuck. Thank you. |
I have updated information and I really hope someone can help me. I had the battery tested, it is fine. Talking with a kawasaki dealer, he said to try and short the two bolts on the starter relay. I did that and it starts up just fine, so I'm thinking that my starter relay (solenoid) went bad. So I replaced it, after installing the new part, same exact problem. I hit the start button and absolutly nothing, yet I short the two bolts (positive battery to starter) and it starts up - no problem. I don't want to throw more money at this than I need to, please does anyone know how I could troubleshoot this problem to find out if it is the Junction box, the starter button, the ingnition switch or something else. Thank you for your help I really appreciate it.
#4 (permalink) |
Finally Got Into First Gear
I'm no mechanic by any means, but my 90 zx-10 had a very similar problem when I first bought it. Mine turned out to be a broken clutch switch, but it could have been any number of things (i.e. starter button contacts, clutch switch, kickstand switch, ignition switch, etc.). I know the starter button contacts tend to get oxidized, which mine were until I cleaned them. The way I narrowed my problem down was to take a plain automotive test light with the alligator clip grounded, and probed the lines associated to the items listed above to make sure they were working properly (i.e. had approximately 12V to light the test light, or not depending on how they were supposed to be). I ended up buying a shop manual to help find what devices on the bike might keep the starter from engaging. I realize I probably am not much help, and the best advice I can offer is to listen to experienced people like QKENUF4U. He has given me good advice on things. Good luck on getting it running again.
#6 (permalink) |
Cruising In Fourth Gear
Yup. Get a voltmeter and a service manual, then start testing. I had a similar problem on my old Katana and it was the clutch interlock switch. Kickstand saftey switch and nuetral safety switch can do it too.
1994 ZX6E -Mike |
#7 (permalink) |
I wanted to bump this thread to life again, as I have the same/similiar problem. I only get a buzzing out of my junction box when I try to start my EX500. Here's the things I've tried -
- Checked the clutch switch and its fine - The neutral light comes on and seems fine. - The kill switch checks out. - Dismantled the junction box. Relays on board appear fine. They click nicely with a nine volt battery across the coil. Coil resistance is 316ohms, which the relay manufactuer says is right. - The starter relay is 4ohms across its coil and clicks with 12volts. - I hooked the relay up so that the 3 pin connector on it only had the white wire connected. So in essence the coil connections weren't hooked up. When I hit the starter button, the junction box clicked like I expected. - When I hook the starter relay up again, the junction box relay buzzes. I have the OEM manual and the starter circuit is pretty simply. I can't figure out what else could be the problem. Please someone help my sanity!!!! |
#8 (permalink) |
Way Too Much Free Time
Hi pal, i dont know if im late to this post.. but.. is nothing to worry about.. its sound like Defenetly a Battery problem, stpo charging it .. the battery is useless now.. juts have to buy a new one..
and thats the end of it. ps: check the rectifier is charging correctly the battery also. |
#9 (permalink) |
dam*n i wish i could understand every word u guys say so i can help..
What do u call relay? and The junction box? is the Ignition?? or the fuses?.. If u explain me the Exact sypmtoms of the bike when and what occur i might be able to help u.. |
#10 (permalink) |
Thanks for the reply. Its not the battery though. I just finished hooking the bike up to my car battery and it still doesn't work.
The junction box is the name Kawasaki gave the fuse box under the seat. Mine has 4 10Amp fuses in it. The junction box has two relays inside and some diodes. Any other ideas? |
#11 (permalink) | |
I was talking about the battery to the guy who posted this thread... about your problem i said i wosh i culd undesrtan your exact symptoms if u tell me the exact symptoms i might help .. |
#12 (permalink) |
yellow doesn't corner wel
where did you get values to check the relays in the junction box? I can't even anyone that can tell me anything about them. I ended up just jumpering the junction box to make one start.
Darrell Ignorance is a disease my friend. You should rid yourself of it. |
#13 (permalink) | |
and the orignal post was made in March of 2005
Darrell Ignorance is a disease my friend. You should rid yourself of it. Last edited by zedx11 : 12-10-2006 at 08:30 PM. |
#14 (permalink) | |
i might u remember that i dont speak English very well.. so i only need the Precise symptoms.. of What happens, and When.. becasu certain words.. i dont understan thata s all. |
#15 (permalink) | ||
#16 (permalink) |
im not sure, but try this.. try to turno onn ur bike connecting directli the starter (i dont know how u called) its the one ROund in the ruber basket with the positive and negative on it.. make a direct connection there.. to see if the problem is from fuse box or before..
#17 (permalink) |
I found the values on the relays by dismantling the Junction Box. They are made by NEC and are the MR301 series, which is an automotive relay. If you download the specs on that series of relay, it has a chart which shows the coil resistance.
The diodes I checked with my multimeter, set to diode. Not all meters have a diode checker, so most manuals say to use the Ohm meter function and you should have an open when you connect the leads one way. When you swap the leads and measure the value should be near zero. HTH. |
#18 (permalink) | |
If I connect the + positive battery to the yellow/green wire on the starter relay, the motor will start. The yellow/green wire goes to the coil inside the relay. The black/yellow is the coil ground, back to the - negative on the battery. I haven't tried to connect the starter lugs directly, but they must be good, otherwise the other steps wouldn't work. |
#19 (permalink) | |
tHATS WHAT IM SAYIng try turning on directly so u can know where the problem is.. |
#20 (permalink) | |
![]() this is what I finally did to make mine start every time. ![]()
