Old 07-08-2008   #1 (permalink)
ssteal
Default Will this exhaust fit on a 2008 ninja 500r
I was wondering if these exhaust slip ons will fit on my 2008 500r. here the link to them.. eBay Motors: HMF exhaust for NINJA EX500 (item 150266303335 end time Jul-09-08 10:34:00 PDT)
ssteal is offline   Reply With Quote
Old 07-08-2008   #2 (permalink)
gr8ride
Top Gear Full Throttle
gr8ride's Avatar
Try this: double check the part numbers for the stock exhausts, if they are the same for both years they will work.
Kawasaki Motorcycle Parts, Kawasaki Dirt Bike Parts, Kawasaki ATV Parts and Kawasaki Jet Ski Parts
I looked up the parts here and they matched for 1994 and 2008 so they will fit, but I will not be liable if they don't.
07 Ninja 250R Silver- mucho mods....
06 CBR F4i Blue- Stock
Next: Ninja 636 or ZX6r Green!
gr8ride is offline   Reply With Quote
Old 07-08-2008   #3 (permalink)
Daren
Turtle Wax Taster
Daren's Avatar
The last time the 500r changed was in 1994, so those should be fine. Anything that fits a 1994-present should fit with no problems.
Daren is offline   Reply With Quote
Old 07-08-2008   #4 (permalink)
eidian
Black is faster, right?
eidian's Avatar
gr8ride/Daren: Shame on the both of you! Yes, you're both correct in the information that you gave--but you left out the most important point that ssteal hasn't even thought of: how crappy the bike will run once he's installed the pipes. Both of you to the corner...now!
Keep the stock pipes because that's what the engine is designed for. If you throw on any aftermarket pipes on the 500R, you're going to mess up the fuel mixture and your bike will never run the same way again. $100, huh? Get some grips, smaller turn signals for the front, new pegs if you're inclined, a cargo net, tank protector and then get a value meal with the money that's left over.
'07 black Z1000: Power Bronze/Projekt D/EYI Designs/Leo Vince/Puig/Galfer/T1Concepts
eidian is offline   Reply With Quote
Old 07-08-2008   #5 (permalink)
Daren
Turtle Wax Taster
Daren's Avatar
is all I have to say to you eidian... haha
Old 07-09-2008   #6 (permalink)
gr8ride
gr8ride's Avatar
Can I come out of the corner now? , Is it that extreme of a change when you swap cans? I thought it just helped the engine breath better.... but other than that exhaust doesn't really affect how the bike runs. For maximum performance you need to rejet... and other than that exhaust really doesn't do much for the entire system except get exhaust out faster and complete a closed combustion system for required back pressure???
I am willing to be wrong on this, just inform me how so I can get out of the corner!
Old 07-09-2008   #7 (permalink)
ssteal
hmm what about cutting the baffles out of the stock exhaust will that hurt anything. seen someone on youtube that did it, sounded better then the moped sound that comes out now.. heres a link to what he did.. YouTube - Debaffling an EX 500 Ninja
Old 07-09-2008   #8 (permalink)
eidian
eidian's Avatar
The lack of backflow from the exhaust swap will lean out the fuel mixture resulting in decreased acceleration and possible "dead spots" in the power curve (too much air, not enough fuel). Re-jetting along with a new air filter in order to allow more air in on the intake side to try to even out the decreased backflow will be nominal at best. Re-jetting usually just moves the dead spot on the power curve. I have yet to see a post where a 500R owner was completely happy with an aftermarket exhaust; the closest I've read are from Sarachu owners. Apparently adjusting the fuel mixture screws will eliminate the popping and the performance isn't affected by too much.
Live with the moped sound...it's a 500cc parallel twin and that's the only sound that you're going to get out of it no matter what you do to the exhaust. Get an exhaust when you upgrade to an in-line 4...that's what I did.
Okay, it's recess time!
Old 07-09-2008   #9 (permalink)
gr8ride
gr8ride's Avatar
well I am trading engine work for a two brothers exhaust, that's going on my 250, I know they don't increase hp but the do give me more ground clearance and reduce weight, so do I rejet and put in pod filters?
Old 07-09-2008   #10 (permalink)
ssteal
But will it hurt anything taking out the baffels
Old 07-09-2008   #11 (permalink)
eidian
eidian's Avatar
The best advice that I can give you is to ask in a 250R forum. I'm sure that that someone will be able to help you out with specifics. The weight reduction will be significant I'm sure (I reduced the weight on my Z1 by 30lbs by switching slip-ons) but remember, the re-jetting and air filter/pod switch will be an attempt to keep stock max hp. For me, I can't justify an exhaust change that requires a bandaid afterwards just to get it back to stock.
Old 07-09-2008   #12 (permalink)
eidian
eidian's Avatar
When I ordered the Leo Vince slip-ons for my Z1, I asked if I had to run the baffles (they are removable); the answer was that I could run without the baffles but I would definitely feel a power decrease unless I ran a PCIII also. So I got the pipes and installed them without baffles and here's the story (post #1 are my observations without baffles including loss of torque--post #30 is what happened when I put the baffles back in)...
http://www.kawasakimotorcycle.org/fo...74-baffle.html
KAWASAKI NINJA 500r vs SUZUKI GS500f beginnerman Kawasaki Streetbikes/Sportbikes 32 02-18-2008 08:35 AM
Help me with a custom paint job on Ninja 500r Psychoness999 Kawasaki Streetbikes/Sportbikes 9 09-06-2006 04:17 AM
Ninja 500R features review torres Kawasaki Streetbikes/Sportbikes 0 08-15-2006 08:56 AM
Buying a 2004 Ninja 500R Mrblue104 Kawasaki Streetbikes/Sportbikes 14 04-15-2005 02:25 AM
Ninja 500r: 2 questions about MCN Review cspan37421 Main Lobby 12 09-25-2004 11:32 PM
