Old 05-20-2009   #2161 (permalink)
Djblomquist356
Default 250 transmission engaging issue
I've got a 93 ninja 250 that I acquired about a year ago, and have been trying to get it running. It was last registered back in 95, and was running then. I got the bike to turn on and idle, etc. Here's the problem I'm running into:
I've got the bike on the center stand, crank it over and shift into 1st, now the problem comes about. So on occasion when I let out the clutch the rear wheel will begin to turn and suddenly stop rotating. From then on the wheel doesn't want to spin, even if I shut the bike off and turn it back on and shift into gear again. Even if I pull on the throttle with the clutch out it doesn't spin.
Any ideas?
I have already tried tightening the clutch cable (which I replaced) and nothing changes.
Any ideas or thoughts are appreciated, thanks.
Djblomquist356 is offline   Reply With Quote
Old 05-20-2009   #2162 (permalink)
hitchface
Hmm...tough to say when you are on your center stand. Maybe your idle jets are partially blocked?
hitchface is offline   Reply With Quote
Old 05-20-2009   #2163 (permalink)
Carl722
Can't find time to ride
Carl722's Avatar
Send a message via AIM to Carl722 Send a message via Yahoo to Carl722
You could have some gear case issues. Is your rear wheel out of alignment where the chain is pulling at an angle causing some binding?
2007 Ninja 500R
Carl722 is offline   Reply With Quote
Old 05-23-2009   #2164 (permalink)
maggie47
maggie47's Avatar
Originally Posted by keyda81 View Post
It's always the little things that can cause a big pain in the you know what. So far I haven't had any problems with mine, but I'm sure I'll be checking it now!
*Note to self: keep a small bungee w/ the bike*
Ninja 250r
maggie47 is offline   Reply With Quote
Old 05-23-2009   #2165 (permalink)
Djblomquist356
I had originally thought that might be the issue. So I took the carbs off and went through them thoroughly cleaning everything. Didn't seem to help, but I was able to get the throttle to respond better, but no wheel spin.
Old 05-23-2009   #2166 (permalink)
Djblomquist356
I haven't thought about that. I will have to check and see. I'll update when I try aligning the chain. thanks
Old 05-24-2009   #2167 (permalink)
Dave55
Is the Ninja 500 R too small for me at 6'2" ?
I need a commuter bike to slice through freeway clogs and
I'm starting to favor a blue Ninja 500 R for the slim and nimble qualities.
At first I wanted a 600 or 650 size and checked the specs on the Versys and ER-6N.
Dave55 is offline   Reply With Quote
Old 05-24-2009   #2168 (permalink)
Jaycin
Hey everyone. I have a 2008 Kawasaki Ninja 250ex. The problem with my bike is that every time I start up my bike and gun the throttle a little bit the bike will shut off. We've had the Ninja for over a year now but I only began riding it last month. Any suggestions as to why this is happening?
Jaycin is offline   Reply With Quote
Old 05-25-2009   #2169 (permalink)
ChrisW
Two things: First off you need to let the bike warm up a little bit. 2nd you need to learn how to use the choke. That's the black lever on next to the high beam switch.
ChrisW is offline   Reply With Quote
Old 05-25-2009   #2170 (permalink)
Jaycin
Thank you for replying to my post. I do let the bike warm up and I do use the choke. Even after riding for a while when I leave the bike off for 10 minutes I have to rev up the bike before it will ride off. If not, it will stall when I gun the throttle.
OH and are you the ChrisW from the dot net?
Old 05-28-2009   #2171 (permalink)
keyda81
2005 Ninja 250 "Sapphire"
keyda81's Avatar
Don't gun the throttle. You could be flooding it.
You only live once, get out there, enjoy it, and have no regrets!
keyda81 is offline   Reply With Quote
Old 05-31-2009   #2172 (permalink)
sxgt
Green Machine
sxgt's Avatar
by laws of basic physicals.. a 330lbs motorcycle is going to be easier to turn then a 458lbs motorcycle?
i know tires are a factor for grip but it seems like a ninja 250 is going to be more nibble then a zx10 even if the zx10 is a billion times most powerful. yes? yes?
2008 Kawasaki Ninja 250R
you tube handle is: kirbienstien
sxgt is offline   Reply With Quote
Old 06-04-2009   #2173 (permalink)
GAS2HI
Rubber Side Down
GAS2HI's Avatar
Send a message via Yahoo to GAS2HI
Default tire time
I have around 7.5k on the back tire and it time to change. What's a good one that has a good tread life?
06 ninja 500. 130/70 -17
Upgrades-
RAM Mount for TOM TOM GPS
Manta Tank Bag
ThrottleMeister Cruise Control
GAS2HI is offline   Reply With Quote
Old 06-08-2009   #2174 (permalink)
jlcnuke
Too busy, I blame Donkey
jlcnuke's Avatar
You're floats could be sticking. Get the carbs cleaned, or at a minimum run some seafoam through. When my 500 started not liking to throttle and stall at speeds a quick carb clean did the trick.
jlcnuke is offline   Reply With Quote
Old 06-09-2009   #2175 (permalink)
bretsk2500
'07 ZZR600
bretsk2500's Avatar
Send a message via Yahoo to bretsk2500
It has a lot more to do with gyroscopic effects of the tires and engine rotating mass than the actual weight of the bike. A liter bike has MUCH larger rotating masses which will literally fight a change in direction. When you move up from a 250, the larger bike WILL tire you out for a while because it takes more effort to ride.
'07 ZZR600 Fire Red
11.957@117
Jardine RT1
Factory Pro +4 rotor
Renthal +2
bretsk2500 is offline   Reply With Quote
Old 06-22-2009   #2176 (permalink)
warrior_jimbo
'09 Ninja 500R
warrior_jimbo's Avatar
Default '09 EX-500 Ninja exhaust
I just installed some D & D slip-ons on my Ninja. I opted for the slip-ons so I could keep the center stand & lower faring.
I gotta tell you, the sound is unbelievable! And I swear I have better throttle response. Jetting & high flow air cleaner are coming next.
ISSUE: I have some leakage around the joints. Other than cranking down on the brackets, any suggestions? Is there a seal I can use?
Thanks in advance.
warrior_jimbo is offline   Reply With Quote
Old 06-22-2009   #2177 (permalink)
sxgt
Green Machine
sxgt's Avatar
so a 250 handles better....
Old 06-22-2009   #2178 (permalink)
bretsk2500
'07 ZZR600
bretsk2500's Avatar
no, it turns quicker, there is a difference.
'07 ZZR600 Fire Red
11.957@117
Jardine RT1
Renthal +2
Old 06-22-2009   #2179 (permalink)
sxgt
Green Machine
sxgt's Avatar
help me to learn.
Old 06-23-2009   #2180 (permalink)
Carl722
Carl722's Avatar
It is easier to drop a lighter bike into a turn. Handling like all around the heavier bikes are much better on stability especially on the highway from wind and passing semi's.
2007 Ninja 500R
