Old 04-16-2005   #1 (permalink)
Kawi Goon
Kawi Goon's Avatar
Default Bar Ends
I just bought a set of those cheesy carbon fiber bar ends, but I can't get the original ends off the bike. The screw is so tight that it just starts to strip when I turn it. How the heck am I supposed to get them off? Its a ZZR 600 and the ends are attached with a phillips head screw.
Kawi Goon is offline   Reply With Quote
Old 04-16-2005   #2 (permalink)
Green Knight
Banned
Green Knight's Avatar
Send a message via MSN to Green Knight Send a message via Yahoo to Green Knight
Make sure the driver you're using goes all the way into the screws.
Green Knight is offline   Reply With Quote
Old 04-16-2005   #3 (permalink)
virtualkuz
Third Gear And Gaining
most people don't realize it, but the philips head screw actually has several standard sizes. Screwdrivers are made to fit exactly, which makes the job much easier. However, the way the screws are you usally can use either a too big or too small driver and get the job done, you might just mess up the screw head. Those bar ends are lilkey locktited on, so you are going to need the right size bit, and I would use a ratchet to get the torque you need to break the locktite.
2005 Z750S
virtualkuz is offline   Reply With Quote
Old 04-16-2005   #4 (permalink)
r409z
Sit speling cheker
r409z's Avatar
Send a message via AIM to r409z Send a message via Yahoo to r409z
when i switched mine i had to have someone hold the bike and i think a vein popped out of my forehead i had to pull so hard to break that thing loose
2006 Black ZX-6R
Old Bike -- Hot Lime Green 2004 500R
r409z is offline   Reply With Quote
Old 04-16-2005   #5 (permalink)
Kawi Goon
Kawi Goon's Avatar
Stupid stupid stupid bar ends!!!! I didn't even want them, why did I buy them? I think you're right virtualkuz, they must have Loctite on them. I got so frustrated I almost kicked my bike, then I thought better of it and kicked my car instead.
Old 04-16-2005   #6 (permalink)
2WheelFun
the "fun old" guy
2WheelFun's Avatar
If your careful...maybe you could use an impact driver and with enough taps get the screws to break loose? Just a thought.
***KING KAHUNA***
***2007 V2K LT***
******PICS******
2007 Brute Force 650i
******PICS******
*I love the smell of SeaFoam in the morning*
2WheelFun is offline   Reply With Quote
Old 04-17-2005   #7 (permalink)
Kawi Goon
Kawi Goon's Avatar
Thanks Whistle Clean, you are a genius. I borrowed an impact driver today and I was finally able to bust them loose. Both screws had red Loctite on them, what a pain.
Old 04-17-2005   #8 (permalink)
2WheelFun
the "fun old" guy
2WheelFun's Avatar
Your welcome!
Glad it worked! While loctite is good and necessary...at times it can cause some serious heartburn!
***KING KAHUNA***
***2007 V2K LT***
******PICS******
******PICS******
Old 04-17-2005   #9 (permalink)
SouthJersey600R
Uncle Bob's Love Child
SouthJersey600R's Avatar
did you get the carbon fiber ends off ebay? if so how are they quality wise, and do they actually help dampen vibration like the LP (Lockhart Phillips) ones are supposed to.
SouthJersey600R is offline   Reply With Quote
