#361 (permalink) | |
You can copy down the VIN and call a local Kawi shop. They should be able to tell you what model it is by the VIN.
2002 ZX9R 2003 YZ450F All I've got to say is "Yee Ha"!!! |
#362 (permalink) |
Whew! I made my trip to Colorado Springs from Arizona. For those non-Southwest U.S. folks, that's about a 1750 mile round trip. Made it in 3 days. I can tell you several things:
Cheers!
#363 (permalink) |
i am so freakin jealous of you
No one is more professional than I, I am a Non Comissioned Officer a leader of Soldiers. www.msf-usa.org |
#364 (permalink) | |
Man, I used to ride around town, which is pretty big, but some friends and I have been taking weekend day-rides, so this was pretty cool. I've really been enjoying these rides, and that last one was so cool I'm really looking forward to a new destination!
#365 (permalink) |
Ready to play!!!
just bought it and out of habit, from filling my jeep, i put 87 octane and realized that the manual says it requires at least 90 octane. will it be ok, or should i add some octane booster to it??? any help would be great. thanks.
joesoldiermedic |
#367 (permalink) | |
MOM Sept 2006
Black 2006 ZX-10R
http://cache.www.gametracker.com/ser...0/b_560x95.png |
#368 (permalink) | |
You should be okay. It'll run rough, depending on the compression a ZX6 puts out. The higher the compression, the higher the octane needed. It won't ruin it by any means, but it won't put out the same power while that 87 is in it. So, drop the boost in or don't, it can't hurt.
#370 (permalink) | |
Needs A Real Job
Interesting... in my 636 (I live in Italy) the manual says to use minimum 95 octane fuel...
06 636 - the last of it's kind |
#371 (permalink) |
I have an 00 zx6r that I'm building up for a track bike. I bought the bike badly wrecked and it looks like I will need a frame. Does anyone know if other frames besides 00-02 zx6r will work and if so what are they? I think the 05-06 zzr is the same but not sure. How about the 00 zx9r?
Thx, Mark |
#372 (permalink) |
I just bought a 636 for my son but unfortunately I don't have the owners manual so some questions:
1) Does the key have a transponder? I want to have a spare key made. 2) How do I adjust the shift light? 3) How do I tell if the exhaust header are standard or aftermarket? and... 4) Is there a place where I can download an owners manual? |
#373 (permalink) | |
Needs A Real Job
Yes the key does have a transponder, but if the guy you bought it from didn't give you the mother key (it's red) you're in trouble... to make spares you have to replace the entire key/transponder block which I hear sets you back several hundred dollars... To adjust the shift light, keep the mode and reset buttons pressed for 3 seconds. First you have to choose the light brightness with the mode button (not so bright/very bright/off) then press reset and select the number of revs at which it will come on. Keep pressing mode, the revs will increase and then decrease once you get to 15,5K. Once you have chosen the revs keep mode pressed for 2/3 seconds and you're set. BTW, it's bulls.hit that you can see it with your peripheral vision, it's pretty useless! Don't know about the rest...
#376 (permalink) | |
#377 (permalink) | |
MOM Sept 2006
What year? 2003-2004 No to 1 and 2 (never seen it)...Does the bike have a PC? If not then not likely a full system. If the bike has a slip on exhaust the pipe that comes from the header to the can could have come with the exhaust. Then again mine is a highmount. The header itself is not replaced in a slip on.
Black 2006 ZX-10R
#379 (permalink) | |
MOM Sept 2006
Black 2006 ZX-10R
#380 (permalink) | |
If he is not carefull he is going to land up with my 1000K6 and I'm taking the 636 |
