Old 06-09-2009   #621 (permalink)
j1shotz88
i have a 07 zzr600 and the clutch lever has no tension...can anybody help me figure this problem out? it doesnt look to be a broken cable or loose cable bc the cable when pulled it moves the lever by the engine, there is just no tension when i go to pull it... the lever also goes back to its original spot...help!!!!
j1shotz88 is offline   Reply With Quote
Old 06-09-2009   #622 (permalink)
THEDEVINE
i have a 04 zx636 and the valve train(i think) sounds like someone dumped marbles in it... tapping or knocking no sure what but its loud... just bought the bike in feb with 16k on it and got a receipt from a reputable local shop that said they put a manual cam tensioner on along with a 15k service... new ngk plugs, air filter, etc... ive done two oil changes and had to burp the oil filter both times to get the oil pres light out... my question is about the knocking/tapping/marbles... is this normal for a 636... or should i worry?
THEDEVINE is offline   Reply With Quote
Old 06-09-2009   #623 (permalink)
THEDEVINE
sounds like the adjustment knob by the lever needs adjusting? or maybe youve tryed that... nm i see you have tred that sorry i dont have a lot of experience with motorcycles... just trying to help...
Old 06-10-2009   #624 (permalink)
kqodprez
Such a kawi newbie!
Hey guys. I just picked up an 84 zx900 and I had a few questions. I'm handy with tools and I mess with cars all the time but this is my first hands on bike. How do you check/change the coolant? Oil? Filter location? And is there anything else I need to worry about before I put her on the highway? These things were supposedly checked by my uncle's mechanic however I want to double check them anyway since I will be commuting about 60 miles a day with her. Thanks in advance!!!!
84 zx900
92 eagle talon tsi <---track toy
95 eagle talon tsi <---daily driver
kqodprez is offline   Reply With Quote
Old 06-11-2009   #625 (permalink)
kqodprez
Such a kawi newbie!
Never mind...I found all the information that I need! This site rocks!!!!
84 zx900
Old 06-13-2009   #626 (permalink)
bennice
Last of the non-banned
bennice's Avatar
Cam chain tensioner. Tighten it, and make sure it's locked in place when you're done.
2007 ZX-10R
2007 EX-650R
2003 ZX-6RR
bennice is offline   Reply With Quote
Old 06-21-2009   #627 (permalink)
masonpark
Default Tire Options for a 2004 ZX-6R
Something tells me that this question has come up quite a few times based on what I have found today. - But if someone has access to the service manual, or just knows, - what are the other options that are available for tires (front and rear) on a 2004 ZX-6R?
- Right now, I have the Bridgestone Battlax BT012R 180/55 R17 on the rear. - I need to replace this tire - but can't find it anywhere without paying through the nose.
Trying to get a download copy of the manual to find out as I did have one and it listings for two other tires sets that are recommended for the bike. - I think they were Michelins and Pirelli's.
Thanks.
masonpark is offline   Reply With Quote
Old 06-22-2009   #628 (permalink)
Always4Kawis
Sit speling cheker
Always4Kawis's Avatar
Send a message via AIM to Always4Kawis Send a message via Yahoo to Always4Kawis
I don't know that you can go wrong with about any tire make for your bike in the 180/55; Michelin, Pirelli, Dunlop, Bridgestone, and others all make excellent replacement tires.
Also, the popularity of these tires generally dictates aggressive pricing on them. I think you shouldn't be paying over $150 max for any of them; possibly as low as $130. I don't know what area you are in, but check your local bike shops (if there are any); do you have a CycleGear close? There are dozens of online merchants if none of the above are avaiable to you.
Another possibility is buying used; check the classifieds in your local sportbike forums if that's an option for you.
Kawasaki to me baby!
Always4Kawis is offline   Reply With Quote
Old 06-22-2009   #629 (permalink)
Loving2wheels
Send a message via Yahoo to Loving2wheels
Question interchangeable parts...please any info will help****
i have a 99 ZX6R and i found an awesome deal on a set of chrome rims, 6 inch chrome swingarm, and chrome pegs(i want to go chrome/black)... but they are for a 2004-2005 ZX10, i thought that since there aren't engine parts that they might fit....
can someone help me out here because i cant find any information online if the ZX10 parts will fit so i can pick them up b4 someone esle does... thanks in advance
Loving2wheels is offline   Reply With Quote
Old 06-22-2009   #630 (permalink)
masonpark
Default 2004 ZX-6R Tires
Thanks for the reply. - I agree that you probably couldn't go wrong with any of the brands, - but even within the 180/55 sizes there are so many options. - Was hoping if I someone had access to the Manufacturer's suggestions, - I could narrow my search. In the this case, - it's a (BT012R) 180/55ZR-17 (M/C) Bridgestone Battlax on the rear - and it' composite match on the front. - If someone has the owner's manual for this bike, - I think the info may be in there.
Without being able to locate the exact rear (without paying $300+) dollars, - I had originally downloaded a manual (which I can't find now) that listed two other matches and tire sets and tire manufacturers for this specific bike.
So, it probably doesn't matter too much, - I just can't get out of my head that the specific answer is out there.
Thanks.
Old 07-06-2009   #631 (permalink)
itsertime
Default 2004 zzr
hi,
I am thinking of purchasing a 2004 zzr-600 i rode a 1992 ninja 600 for the summer of 2003 than had an accident, the dealership wants 3500 but he said he would raise the handle bars and a few other things it was female ridden. some advice would be appreciated thanks, Erica
itsertime is offline   Reply With Quote
Old 07-10-2009   #632 (permalink)
sxgt
Green Machine
sxgt's Avatar
How does the 636 stack up against the 2009 ZX6R ?
2008 Kawasaki Ninja 250R
you tube handle is: kirbienstien
sxgt is offline   Reply With Quote
Old 07-11-2009   #633 (permalink)
Always4Kawis
Sit speling cheker
IMHO:
636=much better street bike,
6R = much better race bike.
I know this is over-simplification, but it's pretty much what the 'argument' boils down to. FWIW, if you consider a 636, I'd try to confine it to either the '05 or '06 models; I think these were the best. Mainly due to the suspension upgrades.
Starting in '07, Kawasaki made the 6R a more track-focused bike, and that trend has continued. Now, I cannot dispute that the newer engine has more power, and, on paper, "beats" the 636 motor. But, in real-world application, the extra torque provided by the extra displacement works much better in typical street riding.
I'm sure there are other benefits of the newer models as well, such as more areodynamic bodywork, frame, chassis, and brake refinements/upgrades, but none that translate to a better "all-arounder".
Old 07-12-2009   #634 (permalink)
messer00
2009 ZX-6R
messer00's Avatar
GREAT STUFF ABOUT THE 09' - Sport Rider Magazine, Middleweight Comparison Test
"Usually the track portion of the comparison is a closer subjectively, but the new ZX-6R blew everyone out of the water this time."
"The powerplant is not only the strongest on the dyno (even over the 675cc Triumph), but its quick-revving character translates to fierce acceleration all the way from the beefy midrange to its screaming top-end."
"The ZX-6R is so exhilerating that it doesn't seem in the same class with the others."
MORE - Motor Cyclist Magazine, Class of 09' (Kawasaki ZX-6R, Ducati 1198, Honda CBR-600, Suzuki GSX-R1000, Yamaha R1)
"Excepting Ducati's 1198, there's not a racier bike in this bunch, and even that's a close call."
"This ZX-6R pulls so hard off the corners that we had to check the tailsection decal to be sure Kawi hadn't slipped us another 636cc cheater."
"And the rev-hungry inline-four delivers glorious high-rpm power that has you grinning in your helmet at every corner exit."
messer00 is offline   Reply With Quote
Old 07-28-2009   #635 (permalink)
89ninja_ryder
i have a 1989 ninja zx 600 and when it got wet it started making a bubbling sound from the exhaust and it goes away when its dry. also the next day it started making a clicking sounds in the idle when i started it up the next day. what do you think those are?
Originally Posted by NinjaGirl View Post
This Sticky is for specific questions, concerns and feedback pertaining to the:
Ninja ZX-6RR
Ninja ZX-6R
ZZR-600
750S
ZX9R (?)
89ninja_ryder is offline   Reply With Quote
Old 07-28-2009   #636 (permalink)
xxVETRICKxx
xxVETRICKxx's Avatar
Ninja ZX-6RR
Ninja ZX-6R
ZZR-600
750S
ZX9R (?)
hi my bike just turned off while i was rideing it then wouldnt start i turned off the key then it started i have a 99 ZX6r any one can help me
xxVETRICKxx is offline   Reply With Quote
Old 08-29-2009   #637 (permalink)
Alex Orlov
Hi ! I got a 99 zx6r motor ! anybody wont's to by it? I`m located in freehold NJ, the motor has 15000 on it. if interested email at eagle2105@hotmail.com
Alex Orlov is offline   Reply With Quote
Old 09-02-2009   #638 (permalink)
97ZX6E
Quick question, I have a '97 ZX6E and she rides great, but when I get home to drive the bike into the garage, I have to drive up the driveway which is at about a 45 degree incline. I stop the bike to open the garage and as I start up the hill in 1st she cuts out and won't start again. This has happened twice in the past 3 days. Any helpful info would be greatly appreciated.
97ZX6E is offline   Reply With Quote
Old 09-20-2009   #639 (permalink)
jenzx6r
Just a girl and her 636
jenzx6r's Avatar
Love it I think when I checked I was getting about 48 per gallon if that sounds right...now this was my 2004, I have only had my 2006 for a day and I questioned my first calculatoin of 40 MPH but then again, I was truly enjoying our maiden voyage through some good sweepers and turns so 40 might be accurate on a day like today. I usually fill up at 140 tho, I am too much of a wuss to go past it or to ignore the light.
2006 Ninja ZX636 current
2004 Ninja ZX636
2000 Ninja ZX6R
2003 GSXR 600
jenzx6r is offline   Reply With Quote
Old 09-20-2009   #640 (permalink)
jenzx6r
jenzx6r's Avatar
IMHO:
I can't agree more. I LOVE the 636 and yes the 2006 is a tremendous improvement from the 2004. I am sad that 2006 was the last year, what a shame. The 636 is the best street bike out there ...but just my humble opinion... It did however fabulously n the track as well and that was my 2004. I repeatedly lapped all but one other rider by the end of the day, even a GSXR 1000 over and over again (much to his dismay and his buddies delight) and after my day long ride on my 2006 today I can only imagine what more she can do on the track. I don't know much about the mechanics or why she is an amazing bike but I can ride and I can agree that this is just hands down one of the best bikes ever built.
2004 Ninja ZX636
2000 Ninja ZX6R
2003 GSXR 600
