Old 08-01-2005   #61 (permalink)
devestator_x
Default Body Panels for 88 zx600c?
Im purchasing an '88 Ninja 600 from a friend and have a few questions concerning interchanging parts from other year bikes. My bike is gonna need some body work (some cracks, some mounting holes need reinforcing) thats not too hard for me, what I do need though is new panels on both sides where the petcock for the fuel is (best I could describe as I dont know if theres a name for this piece). He said they were covered in vinyl matching the seat, but he bought the bike without them there from someone else. From all the searching I've doen thus far, noone seems to make any replacement panels for this year. Occasionally I can stumble across some body parts for 89, 90, and 91 but not 88, also theres a ton of body panels and things available for an 88 500. Are any of these of any use to me or are there large differences in body shape/style between models and years? Id also like to find some flush mount turn signals to match the rear ones he put on (clear preferably) Any replies are greatly appreciated. Thanks in advance.
devestator_x is offline   Reply With Quote
Old 08-01-2005   #62 (permalink)
devestator_x
After searching some pics on www.bikepics.com I think I've determined the panels I need didnt change at all from 88 to 97. Now I just need to find some being sold somewhere...
Old 08-02-2005   #63 (permalink)
DarkTari
Default Clutch Cable Issue...............
New to the forum. Got a 99 9R late last year. Did a search but didn't see anything.
A lil history on problem:
Cable started to stretch, got hard to get into gear & neutral. Adjusted at lever, things seemed okay for a while then problem returned. Then I adjusted at the clutch case. Worked fine for a while then the problem persisted so new cable was ordered (#54011) Installed new cable (old one had frayed) but had to adjust the new one to max at both lever & case ends to get it to dissengage. Now it won't change gears and there's no more adjustment left. Seems like the cable is too long, when fully depressed, I can manually move it another 1" which tells it's not fully dissengaging. Company assures me this is the right cable. Also the return spring for the release lever is broken so I ordered one from my local shop (inturn they order it from Kawasaki, 1 week wait). Now this spring beside returning the clutch release shaft also prevents it from coming out of the case, correct ?
Why does this cable seem too long?
My 1st thought was that the clutch release shaft had turned some how cause I was assured the cable was correct. Kawasaki website confirmed.
I'm at a point that I'm about to fabricate an extention at the case to get it to work. Any ideas?
Thanx!
DarkTari is offline   Reply With Quote
Old 08-10-2005   #64 (permalink)
boostfed
Send a message via AIM to boostfed
Whats up everyone? I just started playin with an 88 Ninja 600R. Its not my first bike, but it is my first street bike. When I got it it had been sitting for a number of years, since 99 maybe, so I cleaned the carbs, changed the oil, changed the plugs and wires, and flushed the coolant. Its missing the boots between the carbs and the airbox so, I just pulled the airbox out and im going to put individual filters on. Anyways, my problem is when I start the bike, its very hard to start and I have to push start it a lot of the time. After I finally get it started the bike will not run above 7K. When it gets to 7 it just dies. If I give it wide open throttle it will not run, it bogs down and stalls. Low end power is basicly non existant. My question is, would this be due to open carbs or by chance is something else wrong? Am I going to need to rejet? I pulled the plugs out and they're not fouled and I also pulled the carbs back off and recleaned them. I need some suggestions.
88 Ninja 600- the 40$ project.
boostfed is offline   Reply With Quote
Old 08-16-2005   #65 (permalink)
slest
Default 1996 zx6r front fork settings
Hi,
a while back I adjusted (tried to tune) the settings for my front forks. Problem is I have lost the piece of paper where I kept the original settings, so I can't return to original and start playing again. Anyone know the original set up?
Even better, has anyone got any setting suggestions ?
to pre-empt... I am 195 lbs ride on road, medium sporty style.
any and all feedback appreciated.
Thanks
SL
slest is offline   Reply With Quote
Old 08-16-2005   #66 (permalink)
Green Knight
Banned
Green Knight's Avatar
Send a message via MSN to Green Knight Send a message via Yahoo to Green Knight
Go to www.sportrider.com and check out the "tech" and "suspention" spots. I think they might have the recommended settings for different bikes there. The "recommended" might work better for ya than the stock ones anyway.
Green Knight is offline   Reply With Quote
Old 08-16-2005   #67 (permalink)
Chromequeen
Banned
Chromequeen's Avatar
Send a message via Yahoo to Chromequeen
Curious what ppl have paid for their 05 zx6r? Got one dealership jewed down to an OTD price of $8276.50 with tax, title and plate included. I'm thinking that's a great deal so far........ Anyone care to share???
Chromequeen is offline   Reply With Quote
Old 08-17-2005   #68 (permalink)
Chromequeen
Banned
Anyone, Anyone? Help me out here guys, making sure I can't get any better price..... Yeah, I enjoy the haggling and dealing!
Old 08-17-2005   #69 (permalink)
southjersey636
Way Too Much Free Time
southjersey636's Avatar
Send a message via AIM to southjersey636
does the 88 600r still have gas in it from back in 99? if so I would pull the tank and drain it, then refill her with some good 93 and then give her a shot at running. After you refill the bike just let her run for awhile outside.
anything from 88-97 im sure will fit. The side panels you can buy oem if you want on bikebandit.com but im sure on ebay you can find them soon or later.
2004 Kawasaki ZX6R 636
1995 Kawasaki 600R (old bike)
1991 Plymouth Laser
southjersey636 is offline   Reply With Quote
Old 08-20-2005   #70 (permalink)
ninja636billy
ninja636billy's Avatar
Send a message via AIM to ninja636billy
lucky...
i got mine for like $8,000 w/o tax/tags and everything else. =P Orig they wanted $8,500, but i knew a guy. ^_^
ninja636billy is offline   Reply With Quote
Old 08-24-2005   #71 (permalink)
Pistobah
Workin too much
Pistobah's Avatar
Default '05 zx-6r
Originally Posted by ninja636billy
lucky...
I wanted green and they had to ship it from another dealership, so i paid around $9,000 after destination charges. I think you are probably getting a good deal.
Pistobah is offline   Reply With Quote
Old 08-24-2005   #72 (permalink)
Pistobah
Workin too much
Pistobah's Avatar
Anyone know what style of headlight bulb the '05 ZX-6R takes. I want to get a brighter bulb for night riding. Thanks.
Chris
'08 GSX-R750
'05 ZX-6R
'05 SV650S
1954 BMW R51/3
Old 08-24-2005   #73 (permalink)
jimmyh
A guy who used to ride
jimmyh's Avatar
H7 for both beams. Do you know of a bulb with a light purplish tint to it? One that is not going to burn out after 100miles?
And I paid $7900 out the door after $1000 trade in with 4-yr ext warranty.
Hey anyone know if 04 and 05 zx6r windshields are interchangeable? I am looking for a blue tinted double bubble for my 05.
Ninja Rider from the past...
jimmyh is offline   Reply With Quote
Old 08-24-2005   #74 (permalink)
orangemug
Can't find time to ride
have u tryd zero gravity for the tinted windshield?
o and i put in the PIAA bulb in my bike and wow can u tell a diff.
has a real nice light blue tint like h.i.d's and projects so bright it looks about daylight....lol
2005 zx-6r
"the only replacement for displacement is technology"
orangemug is offline   Reply With Quote
Old 08-26-2005   #75 (permalink)
jimmyh
jimmyh's Avatar
I ordered a puig double bubble. Found them for 05 at www.58cycle.com. They have a great selection of stuff for 03-04 and 05 ninjas if anyone is interested. And they accept paypal if you are like me and sell stuff on ebay.
All I need now is to find a rear hugger.
Old 08-27-2005   #76 (permalink)
ImportCrew
I paid $7700 for the 05 zx6-r (w/o tax, title, license) then I got 10% off on any accessory I bought that day, along with a 4yr extended warranty.
Later on, I seen an add in a cycle focus magazine that was selling for $7400 before tax, title, and license.
ImportCrew is offline   Reply With Quote
Old 08-29-2005   #77 (permalink)
Pistobah
Workin too much
Pistobah's Avatar
Default Synthetic
I'm having my oil changed this weekend and it will have a little over 6k miles on it. What are the advantages of synthetic oils? Would it be okay to change to synthetic at this point? Do most people recommend Mobil 1? Thanks
Chris
'08 GSX-R750
'05 ZX-6R
'05 SV650S
1954 BMW R51/3
Old 08-31-2005   #78 (permalink)
Pistobah
Workin too much
Pistobah's Avatar
Default Gear Selector Indicator
I was wondering if anyone has had luck with the Datatool DiGi - digital gear indicator. Also, is there a place online to buy one? Thanks.
Chris
'08 GSX-R750
'05 ZX-6R
'05 SV650S
1954 BMW R51/3
Old 09-10-2005   #79 (permalink)
JZZR
wuz up people new here and just had a ? do yall know if the make a exhaust system for a 05 zzr600 because i cant find one or is there a diffrent model that is the same so i can get 1
JZZR is offline   Reply With Quote
Old 09-12-2005   #80 (permalink)
Thmastr
rain is here
Thmastr's Avatar
Default question
HI im looking into getting a zzr.....
what is the earliest year they are offerd in the us?
i really liked the 1998 body style, but i have seen zzr600s the same body style since the very early 1990s, however when I search i get the same body for some zx6s help me out here as you can see by my question im very confused.
Thmastr is offline   Reply With Quote
