Old 09-07-2008   #1 (permalink)
sac600r
Finally Got Into First Gear
Default anyone seen/used these bulbs before?
I was checking for a some brighter rear tail light/brake light LED bulb and came across these on ebay. Anyone have any experience with these?
Or possibly recommend some good ones?
eBay Motors: 12V 54-LED Auto Motorcycle Tail/Break Light 1157 BAY15D (item 130250684823 end time Sep-07-08 22:00:00 PDT)
sac600r is offline   Reply With Quote
Old 09-07-2008   #2 (permalink)
JasonFMHS
JasonFMHS's Avatar
Send a message via AIM to JasonFMHS
Nope, if you get them, let us know how they work out.
01' ZX-6r
JasonFMHS is offline   Reply With Quote
Old 09-07-2008   #3 (permalink)
97tjtom
youre probably gonna have a real hard time getting them through the socket in the back of the lense.
i have the red led bulbs that have only one row of leds around the side. in my experience they arent as good as filaments during the daytime but at night they are crazy bright.
97tjtom is offline   Reply With Quote
Old 09-07-2008   #4 (permalink)
MFolks
Needs A Real Job
MFolks's Avatar
If your bike has a brake light sensor it might indicate in error the filiment in the bulb has failed.Other than the fitment and the visibility in the daytime I see no problem.
Old 09-07-2008   #5 (permalink)
Alizard
The Cruising Gunsmith
They are not bright enough to be a brake light in direct sunlight. The only one that is bright enough is the 3W luxeons I am running now.
3 Watt Luxeon 1156/1157 Bulb SPECIFICATIONS
These are the only ones that are brighter than the stock bulbs.
Alizard is offline   Reply With Quote
Old 09-07-2008   #6 (permalink)
freightshaker
Luv my big boy toys
freightshaker's Avatar
Radiantz has some of the best & brightest LED bulbs out there.
Review
Do what now?
freightshaker is offline   Reply With Quote
Old 09-08-2008   #7 (permalink)
sac600r
Thats a interesting bulb, is that a single LED in the middle of it?
Old 09-09-2008   #8 (permalink)
Alizard
Yes, but it's very powerful and able to be run at very high intensity because it's mounted on the aluminum heatsink piece that screws into the socket. Those things are BLINDING bright, I absolutely caution not to have the battery connected while you install them. If it lights up on you, there will be spots in your eyes for a good while.
The ones using multiple single LEDs have a heat dissipation problem when they try to get bright enough because they don't have an effective heatsink.
I have the 3W Luxeons in my brake lights and my work buddies were behind me and asked what kind of lights were in it because they were startled by the brightness.
LED Replacement Bulbs??? Vulcan900 Kawasaki Cruisers 12 08-14-2008 12:51 AM
Signal bulbs skipsaxe Kawasaki Cruisers 5 05-12-2008 02:33 PM
Xenon Lights dusty30 Kawasaki Cruisers 40 02-01-2008 04:08 PM
Simple, plug-n-play brighter bulbs??? DS06Nomad Kawasaki Cruisers 5 12-24-2007 10:32 PM
900 headlight bulb replacement yourkillinme Kawasaki Cruisers 18 08-01-2007 10:34 PM
