Made It To Second Gear
Is it possible for tires to get rust on them....?
long story short...i got another bike same exact one finally but maybe because of the weather (maryland east coast) i get a rusty looking patch on my tire (that part that makes contact with the ground) ..its garage kept but it is parked next to the wall of my garage.. with that being said maybe water from the cold air at night seeps to the floor and my bike sits in water for 12hrs over night maybe idk???? im not sure has anyone had this issue? if so is it harmful? and what can i do about it? |
just hot water and copper brush and it doesnt really come off like that.....
i thought about it but i had to ride it to work and back home soo i didnt want soapy wet tires while riding when i have time and im not going to ride maybe i'll try but i was looking more so for preventive maintenence to this issue? |
#4 (permalink) |
It's probably from iron leaching through the concrete.
As the carbon black in tires ages, it does tend to turn brownish, but a bike that is ridden regularly will rarely display this, and it would be a pretty even coating all around the sidewalls.
- Rich 2006 1600 Classic Member CORVA, BRC Patriot Guard Rider |
#7 (permalink) |
gonna get a 10
So... put the bike on front/rear stands..and then put some tire warmers on. End result is the bike is off the concrete while you are not riding. When you DO go to ride..they will only be in contact with that concrete for the amount of time it takes you to get it out of the garage...surely not enough time for any more discoloration to take place.
#8 (permalink) | |
i was gonna park the wheels on cardboard buttt i cant believe this never happen to anyone lol? |
#9 (permalink) |
Try cardboard and see if it still happens.
Maybe you're the only one that looks at the bottom of his tires before riding? ![]() Actually not a bad idea if you're looking for nails and rocks.
#10 (permalink) |
gonna get a 10
OK so if stands take up too much room, and you only have room for the bike... then I suggest a very inexpensive alternative. Get a couple 2x4's and cut them to length you need, and position the bike on them. That will still give you elevation from the concrete. I would mention one of those bike ramp deals..but that is a space-taker...so would not be any better than the stands IMO. Just out of curiousity...is the Acura sufferring the same dillemma ? If so then I suggest a permanent fix..and will take NO space what-so-ever...seal the garage concrete floor with that coating stuff called "UcoatIt"...here's a link:
UCoat It Do-it Yourself Floor Coatings for a Durable, Protective Finish ..this is what I would do were it my garage. |
#11 (permalink) | |
i thought everyone does that? Actually CK I havent looked at the car's tires (duh why didnt i think of that and im normally good at diagnosing things hmph) yeah i was gonna re-caulk the bottom lining of the concrete i took a second look at the ground and right along the edges its slightly darker than the rest of the floor possible water/condensation Last edited by Ironman Alloyz : 10-12-2008 at 10:24 PM. |
#12 (permalink) |
Basic TCLOKS, including tire pressure, but I only actually look for nails and cuts after I've knowingly ridden over debris or find inflation lower than expected.
#13 (permalink) |
Navy Vet S.A.R. crew
Maybe the steel belts in those radial tires rusting up.
Seriously though, have you looked in that area of the floor to see if any rebar or reinforcement wire is at the surface and producing the rust when it gets wet? |
#14 (permalink) |
BUBF
Ok, this may be a bit far out, but if the water is from a domestic water supply there is a possibility of a level of manganese in the water that will produce a brown stain. It usually stains concrete and porous porcelain brown and there is a product available from the H2O providing utility to remove it. Also there are commercial/ hardware store products that do the same thing. If the concrete is not turning brown, that is likely not the problem.
Clean the tire, park the bike on a durable plastic mat. Check the tires on the "car". It's an interesting question, Rich could be right, it might be iron leaching. I lived in suburban Maryland for 18 months (Prince George's county) and never saw anything like that. It rained like heck in July and August and soaked EVERYTHING most days about 5 pm, but no brown stuff on the tires. Might you be picking something up on the way home? |
#16 (permalink) |
ever just go with bacteria or some ****? cause it's not the tires, and if the car isnt doing it.. not the concrete.. so maybe a alge? Dunno but no ones brain storming to the ****ers who double the population every 1/2 hour.. spores stay in the dirt for a long *** time.. give them moisture and walla.
#17 (permalink) | |
also this morning i checked my tires after washing them off yesterday and no brown today. its probably cause i parked it different today..i didnt park my front tires so close to the wall this time but there's no browning on the concrete nor on the car's tires so maybe stargate's idea seems more logical but can that happen on a new bike? |
#18 (permalink) | |
I don't even think our tires are steel belted... I think they're poly/glass, and some have an aramid belt under the tread cap. Steel belted radials would be too heavy for a bike.
#19 (permalink) | |
but it hasnt done it lately but once again i took the parkiing variable out of the equation by just parking differently so most likely it has to do with water and the tires sitting in it for a couple hours sooo........ yeahhh ummm how bout dem skinz? |
#20 (permalink) |
Yes I was very much kidding about the radial part. I was also very serious about the rebar or wire at the surface as a possibility. I've seen that done before. There just wasn't any bikes parked over it.
