Old 10-14-2008   #1 (permalink)
Mekial82kzp
Mekial82kzp's Avatar
Default spring/sprung exhaust questions
I built myself a exhaust system which uses a collector made for springs to hold the pipes to the collector... I can't seem to find any info sources on this type of system... I would like to know as much as posible about this type of system. should I use high-temp silicone where the pipes slip on to the collector? is it possible make it so they wount slip? I know thats what the spring system is made for but it's just a question. Thank you.
Mekial82kzp is offline   Reply With Quote
Old 10-14-2008   #2 (permalink)
QKENUF4U
AZ's Official Mechanic
QKENUF4U's Avatar
that type of system isnt the most common type. my buds gsxr has that system and i think my zrx does also.
you wouldnt use any sealant, they will seal perfectly fine since they heat up and swell to seal.
QKENUF4U is offline   Reply With Quote
Old 10-14-2008   #3 (permalink)
vikbarbarian
vikbarbarian's Avatar
somebody suggested me for GP Slash Cut Megaphone slip on's. and they sound AWESOME!!! is this true? anybody else has tried them, plzz share
vikbarbarian is offline   Reply With Quote
Old 10-14-2008   #4 (permalink)
Mekial82kzp
I haven't examined the header to collector connection really, but it looks like the collector to tailpipe connection is where it allows gasses to excape... at idle there is alot of gas out of the tip, when I rev it very little gas comes out... and how the tailpipe slips over the collector would indicate to me that the gasses would be directed to my stator... I still need to make a heat shield to protect it... don't know how much temperature the stator can handle...
kz1000j exhaust and carb questions... Mekial82kzp Vintage Motorcyle Info 17 09-14-2008 02:16 PM
90' ZX600D exhaust questions Hacksaw Kawasaki Streetbikes/Sportbikes 7 12-05-2006 11:03 AM
Vulcan 2000 Exhaust LOWFLYER Kawasaki Cruisers 21 08-02-2006 08:07 PM
Finally, The exhaust is on uf-engineer Kawasaki Cruisers 23 07-07-2006 05:43 PM
exhaust for a 500r... questions d0hnj0e Kawasaki Streetbikes/Sportbikes 2 06-28-2005 11:08 PM
