Old 10-28-2008   #21 (permalink)
97tjtom
seafoam fouled my plugs.
i pulled all 4, cleaned them, and put them back in. problem solved.
but at least now im an expert at doing valve jobs
97tjtom is offline   Reply With Quote
Old 10-28-2008   #22 (permalink)
zedx11
Banned
Originally Posted by 97tjtom View Post
it was running fine before i did the valve job, only reason i adjusted them was because it was at 12k and it was tapping. after the adjustment she ran beautifully except for a slight hesitation from idle but she had full power. last thing done before it started running bad was the seafoam. runs like its running out of gas. but i have plenty in the tank and she runs fine under 1/4 throttle.
did you check the timing chain adjuster?
zedx11 is offline   Reply With Quote
Ran battery dead, now electrical problems. chrishoward1 Kawasaki Cruisers 13 03-28-2009 04:46 AM
84-88 GPZ 900 center stand Fredvs79 Vintage Motorcyle Info 2 07-25-2008 10:40 AM
Man shot dead for bad singing in Philippine karaoke bar Bad Company Off Topic 4 06-03-2007 01:36 AM
timing a klf300 at top dead center,,,?? beepco Main Lobby 0 10-07-2006 08:27 PM
'87 454 - What hose goes on top tee between carbs? bill buttermore Kawasaki Streetbikes/Sportbikes 2 09-08-2006 09:44 AM
