Old 02-17-2009   #1 (permalink)
logspec12
Military Man
logspec12's Avatar
Default 2007 z1000 Temperature
Anybody know what the usual temperature should be when idling after riding for about an hour? Mine went up to 208 degrees. What's the max temp I should worry about?
logspec12 is offline   Reply With Quote
Old 02-17-2009   #2 (permalink)
daemon
devil in god's country
daemon's Avatar
my 04 will range around there when it has sat at idle for a bit,but IMO it is normal.
the problem will arise when you don't hear the fan kick on somewhere near that temp.
NO WORRIES.
my_vids
litany_of_fear
daemon is offline   Reply With Quote
Old 02-17-2009   #3 (permalink)
eidian
Black is faster, right?
eidian's Avatar
I've had mine go up as high as 220*F at idle when the ambient temps were close to or above 100*F. My bike hovers between 190* to 210*F most of the time when the ambient temps are between 70* to 90*F.
Taken from my '07 Owner's Manual:
*If the coolant temperature rises to 115*C (239*F) and below 120*C (248*F), the numerical value of the current coolant temperature starts flashing. This warns the operator the collant temperature is high
*If the coolant temperature rises to above 120*C (248*F), "HI" is displayed and starts flashing. This warns the operator tht the coolant temperature is too high; stop the engine and check the coolant level in the reserve tank after the engine cools down.
You're not even close to having to worry.
'07 black Z1000: Power Bronze/Projekt D/EYI Designs/Leo Vince/Puig/Galfer/T1Concepts
eidian is offline   Reply With Quote
Old 02-18-2009   #4 (permalink)
CheeseHeadNinja
Winter sucks!
CheeseHeadNinja's Avatar
Idling? That's about right. It's hard to keep an engine cool with no airflow. But 208 isn't bad. When it gets above 230, then you can start worrying.
CheeseHeadNinja is offline   Reply With Quote
