TooTall
About 1500 miles ago I replaced my clutch plates due to slipping. Got everything put back together and all seemed fine. Today, while I was riding it, I started noticing a pretty bad whining noise during deceleration. It doesn’t make that noise as long I’m on the throttle but when I let go, it makes that noise. It also stops when pressing the clutch lever. Any Ideas what it might be and what is the fix.
#4 (permalink) |
TooTall
I did the clutch work. I have the service manual and it was pretty easy. the bike has around 14k miles. When I bought the bike, it had only 300 miles on it. I bought oil and a filter today as well as final gear oil. I will be changing the oils today to make sure theres no metal in the oil. If you have any ideas on what it may be, let me know please.
#5 (permalink) |
The "whine" is the front bevel gear assembly.
It is normal for that assembly to whine on decel, though not all bikes do it, but the troubling part is that the whine stops when you pull the clutch in. That is often a sign that the outer bevel gear bearing is failing. Replacing it now, before it damages the housing, is difficult but not expensive if you do it yourself. The manual says to remove the engine, but it can be done by moving the engine to the right in the frame to get enough clearance to remove the housing. If it is not repaired early, the next sign of a problem will be no clutch... the bearing will overheat, and the heat transmitted through the housing will boil the clutch fluid. When the bearing/housing cool, clutch operation will return to normal. The next sign of failure may or may not be visible smoke behind the bike, with the overheated bearing burning oil.... at that point, failure is imminent and it will lock up the drive (and rear wheel).
- Rich 2006 1600 Ultra-Classic Patriot Guard Rider Please put your bike year/model in your sig line or fill in your profile before asking for help. |
#6 (permalink) |
Bridal Boutique Manager
Your clutch may not of needed replacement. The Kawasaki Nomad clutch doesn't release until the last part of its travel and being hydraulic it could be mistaken for a worn clutch. The best method to test would be, to be traveling down the road in a gear with the clutch fully out and then give it "full power", if the engine revs and you are slow to go then maybe the clutch plates are worn out. The gear whine on deceleration is normal, mine did it more in the beginning and now broken in at 31K is hardly noticeable. I don't think my bike actually broke in until 25K.
#7 (permalink) | |
TooTall
#8 (permalink) | |
With the cover off, you could ride the bike and feel for excessive head on that cover and the housing around it... but again, engine oil is circulated through the bearing, so it may not be possible to "feel" the difference (what's the difference between "hot" and "damned hot"?) How many miles are on the bike? This doesn't seem to be a common failure on bikes with less than 50k on them. One of the forum members, Jesus Granados, recently had to replace the bearing on his 1500 Nomad (yes, Jesus rides a Nomad).
#9 (permalink) |
TooTall
My nomad has about 14k miles on it. Believe it or not, I had to get the engine removed about 4k ago because I had a small oil leak were the slave clutch cyliner was at. The oil cap that the clutch rod went through came loose and like an idiot, i remover the rod and hammered that cap right into the engine. STUPID!!! So I ended up removing the engine the get this piece out. I think I saw that cover your talking about. Can I open that cap and look inside. Does the same oil that circulates the engine go through there or does it need its own lub? Since I just replaced my clutch, should I open it back up to make sure nothings wrong there before dismounting the whole engine?
#10 (permalink) |
TooTall
One other thing, Not to go off topic, If I end up removing the engine or clutch, I want to start using synthetic oil, What is recommended for the nomads?
TooTall 2006 Vulcan Nomad 1600 SCRC North Georgia 9 Patriot Guard Rider |
#11 (permalink) |
Ahh... the infamous clutch pushrod seal. My '06 started leaking after 6 months, 4000 miles.
Yes, that is engine oil that is circulated through there, but there is no way to inspect the bearing without removing the housing. You might be able to see part of it by removing the press-in cap, but with the lip on the housing, you would not be able to see any evidence of damage unless you find metal shavings in the area. 14k, I would not expect the bearing to be failing yet. Like I said, I haven't heard of a failure earlier than 50k, and even above that, it's not a common failure. For a fully synthetic oil, I recommend one of the following four: 10w40 for temperatures not exceeding 100 degrees: Mobil-1 Racing-4T (MX-4T is the old packaging) Amsoil MCF 20w50 for temperatures not below 35 degrees: Mobil-1 V-Twin Amsoil MCV http://personal.linkline.com/rlockyer/oil/oil.xls
#12 (permalink) |
TooTall
I know, I feel cursed with this bike. My plans are that tomorrow, I will remove the clutch casing and inspect the clutch assembly, gears, and plates. if that doesn’t fix it, I guess it will be the bevel gear bearing. I will keep you posted on what I find and the result of what the problem ended up being. Thanks for the great advice.
#13 (permalink) |
There's nothing on the clutch side that could cause it.
Also, is the whine consistent with actual speed or with RPM? Everything on the right side of the case is running at engine speed, so if you are decelerating from 50mph in 5th, then downshift to 4th and the pitch of the whine doesn't change, it's on the left side and not the clutch assembly.
#14 (permalink) | |
TooTall
Thanks
TooTall 2006 Vulcan Nomad 1600 SCRC North Georgia 9 Patriot Guard Rider Last edited by otgt : 4 Weeks Ago at 09:14 AM. |
#15 (permalink) |
TooTall
OK I just rode my bike up and down the street and here are a few more details. I doesnt make that noise in 1st gear when decelerating, only 2nd and up. When I press in the clutch, you can still hear it but very faintly. When riding like 60mph and decelerating to lets say 50 or 40mph, the sound is louder/higher the faster your are when decelerating to the pitch goes down as the bike slows down. I tried to listen to see where the sound is coming from but the best I can tell, its either from the front or the left side. Hope that helps.
#16 (permalink) |
TooTall
RichLockyer, I saw another one of your post similar to mine and this is what you said.
http://www.kawasakimotorcycle.org/fo...ing-noise.html "No... it's like a jet turbine winding down. As soon as any throttle is applied (even still slowing down) it goes away... it's from the shaft gears driving the tranny gears." You hit the nail on the head. Is it the bevel gear bearing or what? Should I ride it tomorrow?
TooTall 2006 Vulcan Nomad 1600 SCRC North Georgia 9 Patriot Guard Rider Last edited by otgt : 4 Weeks Ago at 10:13 AM. |
#17 (permalink) |
Mine has done it from day-1.
The concern over failure is if it completely goes away when the clutch is pulled in (which changes the load on the bearing). Doing it all the time? Some bikes do it, some bikes don't. It sounds like yours is normal, I wouldn't worry about it. One thing that'll help to make it easier to hear is to ride right up against (safe distance) a k-rail... try it on both the left and right side of the bike. The concrete rail will reflect and amplify any noise from that side of the bike.
#18 (permalink) | |
TooTall
#19 (permalink) |
You're looking for signs that the outer bearing has been spinning in the bevel gear housing. The bearing is on the outside right under the flat press-in cover.
If the frame had a drop-away on both sides instead of just the right, it would just be a matter of removing the swingarm and it would be a 2 hour job.
#20 (permalink) | |
TooTall
| kz 400 starter on a kz 440? | Alibi | Vintage Motorcyle Info | 8 | 09-30-2008 09:27 AM |
| Is shimming my clutch push rod an acceptable solution? | Neep | Vintage Motorcyle Info | 7 | 08-25-2008 05:20 PM |
| Unwanted noise on my 05 vulcan 800 | stickman | Kawasaki Cruisers | 0 | 07-27-2008 08:45 PM |
| 2006 Electra Glide CLassic vs 1999 Nomad | ThomasE | Kawasaki Cruisers | 16 | 03-04-2007 01:30 AM |
