Hi All,
I recently got a hold of a friends 2000 Vulcan nomad 1500 Fi (texas based and ridden) which he had sitting in his garage for 6 years and not started. I've worked through pulling the fuel tank, drain and clean there along with cleaning the fuel pump and flushing it out. I've put all that back, pulled the plugs and cleaned and checked their gap. Pulled and replaced the air filter oil filter and verified that the drive line had oil. I've put it all back together and it runs really bad. Prior to parking the bike he rode it a bunch and it always ran great. There were no issues that he or I am aware of. Now it will start but not idle very well and forget putting it in gear. You put it in gear and it will stall. Additionally it backfires through what sounds like the carbs. Another thing i did notice is that the idle adjustment screw/cable is hanginglose and not in the little cradle/bracket. I'm open to any suggestions. I'm a very long distance from a dealer and don't have a trailer. Any help would be appreciated. |
Will try that. Thanks for the post. Oh and forgot to mention, new fuel filter and air filter was installed.
Does anyone know how to properly set the fast idle? I'm worried this got mucked with while it was parked. Kids played in the garage where it was stored and little fingers have a tendency to fiddle with stuff. |
#4 (permalink) | |
Sit speling cheker
#5 (permalink) |
Can't find time to ride
The idle adjustment has a groove just above the knob that slips into a u-shaped piece on the bracket. Get the bike running properly, then this knob can be used to set the idle speed.
This bike is fuel injected, correct? |
#6 (permalink) |
Yes it is fuel injected. Is there a default way to set the idle speed? ie turn it all the way clockwise or counter clockwise and back off x turns or something? with out a tach it's hard to tell what is a good idle setting.
I pulled the plugs today and they were covered in carbon. I've cleaned them and checked gap again and reinstalled. The bike runs a bit better. I'm headed into town in the AM to get seafoam and will see what that does. |
#9 (permalink) |
You can try this:
MC Throttle Body Cleaning Failing that, a fuel system pressure reading would be in order. Should be 38lbs at idle. If it is low, the bike will never run properly no matter what you do. Last edited by sfair : 2 Weeks Ago at 05:40 PM. |
#10 (permalink) |
Ok cleaned throttle body following those instructions. Have been back over the bike on everything I took off and put back to make sure it's all installed correctly. Bike now starts when cold very well. Will take throttle input and you can rev the bike up nicely. Appears that the injectors are clean and functioning. However, once the bike warms up it dies. Is very very hard to start if at all. Is there something else I'm overlooking that would cause this?
Regards B |
#11 (permalink) |
Check plugs for carbon fouling or gas soak, after it is hot and will not restart. Still could be an injector(s) or fuel pressure problem. A dribbling injector will start fine but runs too rich when hot. High fuel pressure will do the same thing.
Post back with your findings. |
| Fairing for 1999 Vulcan 1500 Nomad | jarhead67 | Kawasaki Cruisers | 5 | 08-14-2008 07:50 PM |
| A Horse, A Chicken and A Vulcan 2000 | CowboyBob | Off Topic | 0 | 03-04-2008 06:11 PM |
| Nomad models | art708 | Kawasaki Cruisers | 19 | 08-03-2007 05:27 PM |
| COBRA Freeway Bars for 1500 Vulcan Classic | kaw4me | Accessory Swap Meet | 0 | 10-27-2005 03:57 PM |
| Vulcan 1500 Nomad Fi exhaust system | Strictly VN 1600 | Kawasaki Cruisers | 4 | 08-27-2005 05:40 PM |
