Go Back   Kawasaki Motorcycle Forums > Kawasaki Motorcycle Forums > Kawasaki Touring and Sport Touring
Old 3 Weeks Ago   #1 (permalink)
otgt
TooTall
otgt's Avatar
Default Engine cuts off when applying throttle fast.
I recently had to do some motor work where I had to dismount my engine on my 2006 Nomad. After we got everything back together, the engine started cutting off when applying throttle fast from idle. It didnt do this before. It also makes a pop noise out of the air intake (breather) when this happens. It will start fine as long as i feather the throttle. Any ideas?
NOTE: Im currently running cheap 10-40 Non "Energy conserving' motor oil in it to flush out the engine. I dont think that could be it.
My previous issue.
http://www.kawasakimotorcycle.org/fo...tch-noise.html
TooTall
2006 Vulcan Nomad 1600
SCRC North Georgia 9
Patriot Guard Rider
otgt is offline   Reply With Quote
Old 3 Weeks Ago   #2 (permalink)
sfair
Can't find time to ride
Intake popping is usually a sign of a lean mixture. I would look for an intake leak, hose off, etc. Maybe something that got pulled or pinched when you shifted the motor?
Is the FI light on?
It no longer starts throttle off like it used to?
Another sign of a possible vacuum leak.
sfair is offline   Reply With Quote
Old 3 Weeks Ago   #3 (permalink)
otgt
TooTall
otgt's Avatar
Is the FI light on?
I will check for pinched or loose hoses tomorrow. The Fi light is not on. When I first start the engine, I have to give it a little throttle to get it going, then it idols fine. As soon as I apply throttle, it instantly cuts off but starts right back up applying a little throttle. It almost seems like there is a delay in throttle response if that helps. I will pull the tank off tomorrow to check that. Will report back.
TooTall
Patriot Guard Rider
Old 2 Weeks Ago   #4 (permalink)
650hardtail
TRIPLE NUT
maybe check petcock filter for debris...a fuel flow issue ???
TRIPLES/PARTS ALWAYS WANTED
650hardtail is offline   Reply With Quote
Old 2 Weeks Ago   #5 (permalink)
otgt
TooTall
otgt's Avatar
Is the FI light on?
OK problem fixed. It ended up being something stupid we did when putting the engine back together. The plug that plugged into; what I think is the throttle positioning sensor wasn't pushed in. I plugged it in and everything started working. Thanks again.
TooTall
Patriot Guard Rider
Old 2 Weeks Ago   #6 (permalink)
sfair
That would do it. I am suprised that you did not get an FI light on for that, though.
Old 2 Weeks Ago   #7 (permalink)
otgt
TooTall
otgt's Avatar
Yeah, I was thinking the same thing. One day when I have money burining in my pocket, I will get the dealer to check that out to be sure nothings wrong. Thanks
TooTall
Patriot Guard Rider
High Octane Gas Migz Kawasaki Streetbikes/Sportbikes 10 09-13-2009 10:25 AM
carb setting KX125 stevem Kawasaki Motocross and Offroad 6 03-30-2009 05:59 PM
Info on VN1600 engine ping avrgreeny Kawasaki Cruisers 22 03-11-2009 11:23 AM
Engine Running Funny fireman The Mechanics Corner 14 04-10-2005 01:47 PM
Engine cuts out... MaverickGT The Mechanics Corner 2 03-19-2005 08:34 PM
