Go Back   Kawasaki Motorcycle Forums > Kawasaki Motorcycle Forums > Kawasaki Touring and Sport Touring
Old 10-05-2008   #1 (permalink)
num1husker
junior
Default 09 Heat issue
Can anyone tell me if the 09's have the same heat issue as the 08's?
Did Kawi make any changes from the 08's to the 09's?
I have a ST-1050 Sprint and a Falco (SL), but looking at adding a C-14 to the stable.
thanks
jr
num1husker is offline   Reply With Quote
Old 10-06-2008   #2 (permalink)
jlvdo
jlvdo's Avatar
thanks
jr
Funny you should mention this topic. I just reponded it here:
Concours Owners Group - - Membership Web Site by Memberize.com
Here's my opinion:
I've bought an '09 Connie, and YES, there's a lot of heat. I was hoping someone on the site had a solution. I've tried inserting more insulation, but with limited success. I'll try adding even more. I also hear the fuel release valve squealing whenever I stop the bike. I wonder what temp the fuel is reaching? I plan to buy a manual; I suspect some heat insulation between the tank and the head may not be such a bad idea. I read someone say that Kawi oughta' fix this problem, which a problem it certainly is, especially in hot weather. You dang betcha' they oughta' do something. Too late for me, however. I'll have to figure it out on my own, unless someone has found a solution???
Aside from heat, handling, remarkably easy. 1st ride out, definitely NOT trying, came within 1cm of edge of tread! Power- smooth, easy delivery without any shaft weirdness. A pleasure to ride, minus the heat issue, which I will continue to work on.
jlvdo is offline   Reply With Quote
Old 10-07-2008   #3 (permalink)
msa1956
Beast Master
msa1956's Avatar
Send a message via AIM to msa1956 Send a message via Yahoo to msa1956
Presently the only heat issue I have is at my right foot and its from the exhaust pipe, I have no other problems with it. but I only have 700 miles on mine.
09 Concours Black ABS
Accessories, Risers, Grip Puppies & Peg Lowering Kit.
msa1956 is offline   Reply With Quote
Hazard Light Issue on 08 ZZR600 zzrider The Mechanics Corner 2 08-26-2008 08:48 PM
Weird power issue CaseLogic Main Lobby 3 08-10-2008 09:04 PM
Overflowing Gas issue apsteinberg The Mechanics Corner 1 09-08-2006 11:06 AM
Lean issue on my 305 ltd sds67 The Mechanics Corner 2 05-11-2006 02:34 PM
I need a short heat shield! bigmacbkr Kawasaki Cruisers 2 01-29-2006 10:50 PM
