2007 RED HOT Ninja 650R!
![]() Join Date: Apr 2004
1362.1 THE T-CLOCK INSPECTION: by Art Friedman of Primedia.com
If you buy a new bike, it's worth asking the dealer's tech folks what things you should make part of your daily check. The Motorcycle Safety Foundation created the T-CLOCK mnemonic as a memory and orgaization ad for a pre-ride safety check of a typical motorcycle. Each letter represent a particular inspection category, as follows: T - Tires & Wheels C - Controls L - Lights & Electrics O - Oil C - Chassis K - Kickstand TIRES AND WHEELS Tires: Pressure correct (cold), tread condition. No cuts, bulges, punctures of foreign objects. Wheels: Spokes tight and intact; rims true; no free play when flexed; bearing seals intact; spin freely. Brakes: Firm feel; sufficient pad depth, no leaks or links in hoses or cables. CONTROLS Levers: Pivot bolt and nut; action and position correct; pivots lubed. Cables: Ends and shafts lubed; no fraying or kinks; no binding when handlebar turned; proper adjustment. Hoses: Check for damage or leaks, proper routing. Throttle: Snaps closed freely when released; no excess play. LIGHTS Brake and Tailight(s): All filaments work; both levers actuate brake light. Headlight: All filaments work; properly aimed; no damage. Lenses: Clean; no condensation; tight. Reflectors: Clean; intact. Battery: Fluid level; terminals clean and tight; held down securely; vent tube not kinked or mis-routed. Wiring: Check for pinching or fraying; properly routed; no corrosion. OIL AND FLUIDS Levels: Brake fluid, oil, final drive, transmission, coolant, fuel. Leaks: Check all systems for leaks. Condition: Check color of brake fluid & coolant. CHASSIS Frame: Paint lifting or peeling may indicate cracking. Steering head & swingarm bearings: Lift wheels off floor, grab lower fork legs and pull and push to feel for play; repeat at rear. Turn fork to feel for detents in bearings. Suspension: Smooth movement; proper adjustment; no leaks. Chain or belt: Tension; lube, look for wear. Fasteners: Look for missing or loose threaded fasteners, clips, pins. KICKSTAND Sidestand: Retracts firmly; no bending or damage; cut-out switch operates; springintact. Centerstand: Retracts firmly, no damage. |
| Ride Report: Adirondack Region, New York | Ken | Kawasaki Touring and Sport Touring | 5 | 09-22-2005 07:31 AM |
| Who wants to ride with Scotty Luv? | jukief | Rides, Events and Rallies! | 27 | 07-24-2005 01:55 PM |
| Northern California Ride | dblzr600 | Rides, Events and Rallies! | 4 | 06-13-2005 04:23 PM |
| Feels Good To Ride My Meanie | btreaves | Kawasaki Cruisers | 24 | 11-05-2004 03:10 PM |
| Lube chain with ease | Slicks | Kawasaki Cruisers | 10 | 11-01-2004 09:48 PM |
