Go Back   Kawasaki Motorcycle Forums > Welcome to Kawasaki Motorcycle Forums! > Main Lobby
Old 05-01-2009   #1 (permalink)
connor36
connor36's Avatar
Default 2004 Vulcan Fuel Reserve switch
Whats the best repair manual to find the reserve fuel switch?
connor36 is offline   Reply With Quote
Old 05-01-2009   #2 (permalink)
Classic
Ahhh Crap
Classic's Avatar
Steve
2003 1500 Classic
VROC 11660
RB 139
Classic is offline   Reply With Quote
Old 05-01-2009   #3 (permalink)
CTRider
TV Guru
CTRider's Avatar
Are you sure your bike even has one? If it's FI, it won't. That's what the low fuel light is for.
1983 Honda CB550
About Me
Answers to your Gadget Questions
Gadget Forum
CTRider is offline   Reply With Quote
Old 05-01-2009   #4 (permalink)
jesus granados
Sit speling cheker
jesus granados's Avatar
no can do! FI bikes do not have a reserve valve,switch,gizmo, etc, you need to estimate what's the best range and look at your warning light, if it is a 1500 then you should be able to go about 150 miles quite comfortable, depending on several factors such as wind, altitude, load, tire pressure, tune up condition, the mileage will vary between 35 to 41 miles per gallon, on my 2003 nomad i get a consistant 38-40 miles per gallon, very seldom have i got below 38, i have ridden as much as 180 miles on one tank, but beware! you are sucking fumes at that point. BTW my warning light comes on somewhere between 3,0 to 3.5 gallons consumed.
jesus granados is offline   Reply With Quote
Old 05-01-2009   #5 (permalink)
connor36
connor36's Avatar
Ty
Vulcan 500 starter switch piz The Mechanics Corner 1 04-15-2009 12:54 AM
2004 Ninja 500 r Fuel Problems hdfatboy01 Main Lobby 1 11-18-2007 09:36 PM
Help: 2004 800A Fuel Leak/Discharge from "Fuel Tank Drain Hose" somejarhead Kawasaki Cruisers 10 04-22-2007 12:40 AM
EX500 Fuel Reserve Question Narcisse91 Kawasaki Streetbikes/Sportbikes 13 09-17-2004 07:40 AM
1999 Vulcan 800 Classic fuel problem mycamper The Mechanics Corner 2 05-19-2004 05:20 AM
