My Garmin Nuvi 200 GPS Review...
+ Reply to Thread
Results 1 to 8 of 8
Thread: My Garmin Nuvi 200 GPS Review...
  1. #1
    TV Guru Extreme Forum Supporter CTRider's Avatar
    Join Date
    Apr 2005
    Location
    Connecticut
    Posts
    11,778
    Default My Garmin Nuvi 200 GPS Review...
    I recently bought a Garmin Nuvi 200 GPS. This particular model has been discontinued, so I was able to get it for just over $100. It's been replaced by the 200W, which has a wider screen a few extra options.
    Some of the features:
    - Audio voice prompts that tell you when a turn is coming up. Unlike higher end models, it does not speak the street names. It only tells you to make a left or right turn. It does display the upcoming street name or route number on screen, though.
    - Like many models, it has a built in battery, so it doesn't require external power.
    - It has a MicroSD (cell phone type card) card slot so you can store photos and other files (it doesn't play music).
    - It allows you to add points of interest and choose things to avoid, like toll roads, highways, etc. You can also choose between "fastest" and "shortest" routes.
    - It displays your speed and the estimated time until arrival at your destination.
    - It logs average speed, maximum speed, time spent stopped, etc.
    - It's compact enough to fit in your pocket, so you can easily take it with you when you leave the bike.
    - It can automatically switch between "Day" (black and color graphics over a white background) and "Night" (white and color graphics over a black background) modes. You can also select the modes manually. It's very easy to adjust the brightness, volume level and zoom level.
    - The unit allows you to view a text list of all the directions in the trip with a single touch.
    - You can download a wide range of icons to represent your vehicle. There are options for both a cruiser and a sport bike. I chose the cruiser.
    - The unit can automatically rotate the map so forward is always up.
    - The unit has 3 modes of operation: Car, bicycle and walking. This allows the unit to choose routes based on the practicality and safety of them.
    To start off, I purchased a handlebar mount for the unit. While the suction mount holds very solidly, I wanted a little more confidence that it would stay put. The unit came with a cigarette lighter power adapter. There are optional adapters for connecting the unit to a computer or an AC outlet. However, I had those items already from other devices that had the same power requirements, so I didn't need to purchase them.
    The audio prompts, when the volume is turned all the way up, can be heard up to about 45MPH with the shield on my full face helmet lowered. The unit only has a built in speaker - no headphone adapter or Bluetooth. However, most of the times I needed to worry about turns were when I was going less than 45MPH, so I could hear the prompts with little trouble. In fact, when going under 30MPH, the prompts are almost embarrassingly loud - probably audible to pedestrians in town. Everyone in the immediate area will know you're supposed to "turn left now".
    The unit is very readable in sunlight with the brightness set at 75%.
    The speed listing is very accurate as is the estimated time of arrival. The unit responded quickly to route changes, though a few of those were caused by my turning onto the wrong road when there where two of them close together and the unit was telling me to turn. The unit was giving me correct directions, but I simply misunderstood and turned early. This is where a unit that vocally says street or route names would be very helpful. The couple of times I made a wrong turn were mostly due to the small amount of lag in the satellite data as the united counted down the distance to the turn. Once I missed the turn and two other times, I turned early.
    The battery life listings are greatly overstated. The web site indicates up to 5 hours while the manual states up to 4 hours. I topped out at just over 3. However, I found I was able to stretch the battery life by turning the unit off when there were no upcoming direction changes for more than 10 miles. The unit powers up in under a minute, so I would simply turn it back on a few miles before the next turn and the unit would quickly find my location and make all the adjustments. Once powered on, the unit required me to click the "OK" button for the disclaimer and press the "view map" button to get back to the route view. By turning off the unit when it wasn't needed for any length of time, it lasted nearly the entire 5 hour trip back home. By the time the battery was pretty much dead, I was only a few miles from home and well into familiar territory.
    The unit seems durable enough. I actually dropped it the second day I had it. I did end up with a small ding in the screen, though. Lesson learned: don't set your GPS on your bike seat when starting it up.
    One thing I don't like is how the unit seems to randomly make use of road names and route numbers. For example, it listed route 79 and 206, but called route 10 by its road name. A better system would be to call rural highways by their route numbers and surface streets by their names. That would make it more consistent. It also would make it easier to know when you would be going through town verses out in the open road.
    The unit seems to randomly call those Y interchanges "turns". Other times, it doesn't list them at all, even when there is a stop sign. Still other times, it tells you to "keep left" or "keep right". A couple of times, it called a Y interchange a turn, when it was readily apparent that the main route veered one way and a much small road simply branched off. That aspect actually made it more confusing for me since I was expecting an actual turn to continue following a route, like when you enter a town as opposed to simply veering left or right.
    You can't program in routes via a computer. This means you have to enter a location to navigate to on the unit. This isn't hard, but it means you can only have one route set up at once. Also, the on screen keyboard is inexplicably an "ABC" style keyboard instead of a "QWERTY" style. It took me twice as long to type with it. The letters were also very small and easy to "fat finger" even with my skinny digits. However, the rest of the touch screen buttons are more than large enough to tap easily with gloves on.
    You can't edit the routes. While the unit seems to do well setting up a route according to your preferences, you can't avoid or travel along a specific route. As a result, one turn put me on an oil and stone road to connect to another route. Thankfully, it wasn't fresh. Likewise, the route to NY set me through the middle of Albany while the route back did not. Granted, I don't think I had the "avoid traffic" box checked in the preferences on the way out while I did on the way back. That probably made the difference.
    It would be nice to have an option for the screen to shut off after a set amount of time of no directions being given. This way, when you're going to be on a route for, say, 20 miles, the unit can shut off the display. It could then turn it back on a couple of miles before the next turn. That's a potentially handy battery saving feature that would be useful for using the unit without external power. Since the unit has bicycle and pedestrian modes, this would be very handy.
    You can't save routes you've programmed in for usage on a later trip. Better models allow this, so keep that in mind when shopping by price. However, programming a route in is not very hard. I can live with that for now, especially based on how little I paid for the unit.
    Finally, the unit is not waterproof - or even water resistant. I kept a sandwich bag handy just in case. The clip that holds the unit can easily clip onto it through a bag. On the trip out, the unit had run out of battery power before the rain hit, so it was safely stashed away by then. Coming back, the weather was clear, so I didn't bother covering it. It is harder to read the display with the bag on, though.
    So, overall, I give the unit an A-. It got me there with only a few minor "gotchas". Eventually, I'll probably upgrade to something a bit more advanced, but this one is very good for the money.
    1983 Honda Nighthawk 550
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Alien Test Subject BTK Expert jaseman's Avatar
    Join Date
    Mar 2006
    Posts
    3,509
    I have the 200w, and your review is pretty much spot on. It's a great unit, as long as you understand it's limitations, and are willing to work around them.
    Some ideas for you:
    The 200 is basically designed for drivers to get from point A to point B, but route planning is possible to some extent, with a little creativity. It will allow you to add one "point-of-interest" to your trip. You can use this feature to get you to a specific point out of the direct route it wants to take you. Once you've reached that point of interest, you can set another one, adding a point every time you reach the previous one. It's not perfect, but it's better than nothing. A few days before a trip, I'll program a bunch of favorites, and name them something like "1-Trip", "2-trip", etc.. It's not the same as specific route planning, but it's better than nothing.
    If your gonna use the GPS for longer trips, definitely put a 12v outlet on the bike somewhere. Weather proof ones are relatively cheap at most auto parts stores, and you won't have to worry about battery life. Mounting on your CB might be a bit tricky, but I'm sure you can find a place somewhere on the bike. If your willing to drill into a side cover, that might be the perfect place, or you could do like I did on the Meanie, and mount it to the back side of the triple-trees (just make sure you can turn the bars lock-to-lock- without it interfering).
    Buy a RAM mont for it, if your not already using one. The stock mount is a bit flimsy, and I wouldn't trust the GPS not falling out at some point. Unfortunately, there is nowhere on the 200 to attach a tether, so better safe than sorry.
    Hope some of that helps you out. Enjoy getting lost - and being able to find your way home!!!
    03 MeanStreak
    '90 ZX10
    '04 Honda 599
    Ride it like you stole it!
  4. #3
    Join Date
    Apr 2005
    Location
    Connecticut
    Posts
    11,778
    Quote Originally Posted by jaseman View Post
    Absolutely. For the price, it works very well. There's wishing and there's complaining and I'm definitely not complaining.
    Some ideas for you:
    So you just go from one POI to another?
    That's not a bad idea. I'll have to do some experimenting.
    I actually built a DC power pack that runs off 8 AA batteries for my PDA at one point for when I wanted to view movies on it. The PDA would let me view video for over 10 hours on a single charge with that pack (I tested it by just letting it loop a movie until the pack went dead and the PDA switched to its internal battery). I completely forgot I had the thing. I'll probably use that so I don't have to connect anything to my bike's electrical system. As long as i can get at least 8 hours total between the pack and the internal battery, that's more than enough for my daily needs. Worst case, on a longer trip, I carry an extra set of batteries for the pack and swap them during a meal stop. The GPS is no more power hungry than the PDA, though, so I'd bet I can get over 12 hours between the two batteries. There's no way I'd be on the road more than that in a single day. My a** would never forgive me.
    I thought the same thing, but I'm pretty impressed with how well the unit is held in place. I hit some rather nasty bumps on a few roads and I never feared it would pop out. However, I may consider a RAM box for purposes of weather protection. Radio Shack actually sells stick on tether loops that I've used for other purposes. They hold incredibly strong and would let me tether it if I chose to not use a RAM case.
    Thanks for all the tips. That's why I posted the review. I knew it would a) help others and b) get some feedback from others on their workarounds.
  5. #4
    Forensic Bug Splatter Analyst BTK Expert
    Join Date
    Oct 2008
    Location
    Mesa, AZ
    Posts
    1,712
    I owned a 200W for a while and used it on a trip to SF and I fell in love with it. The affair ended on a trip to San Diego when it was stolen, but I found a new love the next day: the Nuvi 250W, which I like a lot better.
    Speaking the street names is actually a big deal. When you are in town, the instructions "turn right now" can be a little ambiguous. Some times you really need to know the name of the street to turn on.
    I have yet to find a use for the SD card slot. I never use the GPS unit to play back pictures I have taken. My camera has a smaller, but perfectly useful LCD display if I want to review my pictures or show someone else. What is more, my camera has video/audio output jacks and if I wanted to can play back on a TV.
    I would never use a GPS navigation system on battery alone. I like your idea of a battery saver mode though. Personally, I think having it on all the time is very useful. One of the things that I really like about having a navigation system is that it is really nice to be able to say "find me the next gas station" or "where's the closest McDonald's?" Navigating by GPS can be an adventure in the cases where it should be the most useful, so getting directions from it is nice, but I treat them with some skepticism. When you are in a strange town though and need to get a prescription filled, there is literally nothing more convenient or useful than a GPS system. That's what I love the most about the unit.
    Success is not the result of spontaneous combustion. You must set yourself on fire.
  6. #5
    Join Date
    Apr 2005
    Location
    Connecticut
    Posts
    11,778
    Agreed on the photos. I really don't see myself using that feature.
    My wish list for a future upgrade down the road:
    - The ability to edit routes.
    - The ability to plan trips on my computer and upload them to the GPS.
    - The ability to play MP3's while navigating.
    - While I'm fine without it, if I had one that played music, I'd want either an audio output jack or a Bluetooth option.
    - Vocal prompts that include the street name or route number.
    The Nuvi 200 works well without the above, but I definitely see value in the above for next time.
  7. #6
    Join Date
    Mar 2006
    Posts
    3,509
    Quote Originally Posted by CTRider View Post
    ..So you just go from one POI to another?
    That's not a bad idea. I'll have to do some experimenting...
    Yep. As I said, it'll allow you one POI, but once you reach that one, it clears out, and will allow you to set another. Combine that with the 'avoidances' feature (like highway), and you'll get some interesting routing! Only problem is, sometime it'll run you through in-town congestion if your traveling through a populated area.
    ...I thought the same thing, but I'm pretty impressed with how well the unit is held in place. I hit some rather nasty bumps on a few roads and I never feared it would pop out. However, I may consider a RAM box for purposes of weather protection. Radio Shack actually sells stick on tether loops that I've used for other purposes. They hold incredibly strong and would let me tether it if I chose to not use a RAM case...
    For the price, I still might consider the RAM. The design of them allows you to place the unit anywhere you want it (for me, that meant right in my line of sight), and give you a lot of future options for RADAR, video, or whatever else you may want to mount. I will say, the nicest thing, for me personally, was being able to take the GPS from one bike to the other, without transferring the ball mount. But to each their own. If it works for you, thats all that really matters.
    03 MeanStreak
    '90 ZX10
    '04 Honda 599
  8. #7
    Join Date
    Apr 2005
    Location
    Connecticut
    Posts
    11,778
    In my case, if I set the bridge I crossed as a POI, that would ensure it took me that way. The rest of the route it chose that time was fine. Even the oil and stone road wasn't fresh, so it wasn't a big deal - and it was only a few miles, anyway.
    I just don't want it to choose the Albany route again. That sucked.
  9. #8
    Join Date
    Apr 2005
    Location
    Connecticut
    Posts
    11,778
    BTW: to add to the original information, the GPS also has a few handy extra features that could potentially be useful:
    - A World Clock
    - Calculator
    - Unit Converter (Weights, Measures, Distance, etc)
    - A "Where Am I" feature that will give your current location, nearest highways and the nearest Police Station, Hospital and Gas Stations.
    As notice in the above posts, you can use it to find nearby restaurants, gas stations, etc.
    You can browse the map to set a point of interest and customize that POI with a name and other info. You can add it to your favorites as well as your custom address book. The only down side is that you have to click through too many menus to get to them easily. It's not bad, but use caution while moving.
    Finally, you can search any location by GPS coordinates.
    Again, overall not perfect, but still very useful.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Garmin Nuvi 200 GPS Motorcycle Mount
    By SeaBiscuit_SE in forum Kawasaki Cruisers
    Last Post: 06-29-2008, 02:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
